Question about HP Compaq dc5100 Small Form Factor PC Desktop
No sound on my hp dc5100
I have no sound on my hp dc5100. is there a sound card in this machine or is that optional? other research says there is line out, sound card and one other i can't recall.
  • Anonymous Dec 27, 2008
    No solution but I can say it has a sound chip made by analog devices on the mother board.
    I have the same problem however. Says there are no mixing devices available and all the audio stuff is grayed out. Several attempts to fix it have yet to result in any success although I have reinstalled sound drivers and other things some usual some not. It's still mute however. Unyielding audio trouble seems to be a somewhat consistent problem with XP.
  • HP Master
  • 4,806 Answers
Hi there.
You can get the drivers from HP support here>>>>
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=uk&prodNameId=447291&taskId=135&prodTypeId=12454&prodSeriesId=447279&submit.y=0&submit.x=0&lang=en&cc=uk
Choose your operating system and download the drivers you need, you will need to install the chipset drivers for the audio to work properly.
Good luck and thanks for using FixYa!!
Posted on Mar 17, 2009
I cant get windows 7 sound and graphics drivers for hp compaq dc5100 mt
the HP web page don't have the driver for windows 7
i found those 2 dirver after 5 hours
here are the graphic an audio drivers. Audio have a install program. But with
te video you haver to select update driver in the device manager and select the
directory with the drivers. good look
https://www.dropbox.com/s/8f9jc8048f8rqdf/HP%20Compaq%20DC5100.zip
* My PC is working perfect with those driver. without aero style because the
video card can't run it. Stock computer
Jun 17, 2012 | HP Compaq dc5100 PC Desktop
HP intel dc5100 Intel Video Driver required windows seven
Hi
The motherboard in this PC does not seem to support Windows 7.
See here for confirmation:
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?prodNameId=447280&lang=en&cc=us&taskId=135&prodSeriesId=454811&prodTypeId=12454
Since windows 7 has a large database of drivers built-in, most of the devices on the motherboard may have found compatible drivers in the Win 7 Driver Database, with the exception the on-board graphics.
The best option is to upgrade to a dedicated Windows 7 compatible PCI Express graphics card, which you can easily install to bypass the on-board graphics.
A dedicated graphics card will also free up system memory previously borrowed by the on-board graphics.
Hope this helps.
Aug 23, 2011 | HP Compaq dc5100 Microtower PC Desktop
I have a dc5100 sff and legacy drivers. The device manager is saying that the device is working properly but still no sound if I try to play a cd, dvd, or music from my external hardrive. Even if I go...
All you will need to do is download and reinstall your audio drivers.
Head over to the HP downloads center to download the latest audio driver for your PC.
Once it is downloaded, install it and reboot your system.
Feb 10, 2011 | HP Compaq dc5100 Small Form Factor PC...
Machine has 4 beeps at startup
From what I've found in researching this problem you have a power supply problem. Are they 4 single beeps? What happens after the beeps? Do you have a manual? You might call the manufacture for support even if it costs you a bit. Something like this isn't easy to diagnose without more information. This isn't a solution, but it's all I can give you.
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c00281919/c00281919.pdf
http://h10010.www1.hp.com/ewfrf/wc/document?lc=en&dlc=en&cc=us&docname=bph07107&printable=yes&product=447278#N904
Sep 08, 2010 | HP Compaq dc5100 Small Form Factor PC...
No sound coming out from my computer. My machine is hp compaq dc 5100 microtower.Another problem is that there is no multimedia audio driver. pleae help me! Thanks
download audio driver from this link http://drivers.softpedia.com/get/SOUND-CARD/OTHER-SOUNDCARDS/HP-Compaq-dc5100-Audio-Driver-51214070.shtml
Aug 06, 2010 | HP Computers & Internet
Does this hp dc5100 use sata drives
Yes it uses Sata drives.So if you are planning to use sata drive then you can.Your hp dc5100 uses sata drives.
Please rate me if this solution works for you
Thanks......Have a great time.
Jul 20, 2010 | HP Compaq dc5100 Small Form Factor PC...
I had to reload windows xp and when I did I lost my sound card. I mean I can hear systems sounds but I cant play music or hear the radio over windows media player or from any other sorce. My machien keeps...
Go to your CONTROL PANEL
then select SYSTEM
then select DEVICE MANAGER
This page will list all your computer's devices.
Locate your sound card
*a yellow triangle indicates errors*
Double click on your sound card, this will bring up another window
First tab GENERAL shows if device is working properly
Click on DRIVER to update/check on drivers, if you need drivers, it will search and locate them for you.
You may need to restart.
Hope this helps.
Feb 28, 2010 | HP Compaq dc5100 Small Form Factor PC...
Hi, Did you install your sound drivers etc. If you havent done the instalation then your sound card will not work. Follow this process Right click on mycomputer, then properties Device ,manager and then check if ur sound drivers etc. are installed.
Jul 05, 2009 | HP Compaq dc5100 Small Form Factor PC...
HP Compaq dc5100 Small Form Factor PC Desktop Logo
1,260 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
