Kenmore Elite 45986 Front Load Washer Logo
Posted on Nov 13, 2008
Kenmore he3t drum filling on its own
Drum filling on its own not happening all the time maybe ocne every 10 days or so.
Anonymous
Level 1:
  • Contributor 63 Answers
  • Posted on Nov 14, 2008
Anonymous
Contributor
Level 1:
Answers
63
Questions
0
Helped
53252
Points
88
Replace fill valve under top rear left easy fix dont wait it call flood your house
HE3t leaves water in drum after the wash cycle is complete. Already checked the drain clean out...still leaves water in the drum.
Since we are working on the drain side of things only 2 things can happen to not get the water out of your tub-1 the pump isn't working,something stuck in it- 2 you have blockage which we know is not in the trap-check conection to the tub and the pump and all discharge hoses-cheers Denny
It starts to fill with water than stops to soon and the motor is just running
my Kenmore He3T Stop But Remain have water on the bottom!!!
What happen
1helpful
2answers
F11 code on kenmore frontload washer HE3t
My f11 code is repaired! I got a clamp from Home Depot put it on the ccu unit on the right side tightened it shut and haven't got the stinking f11 code ever since. No more banging it again! I can finally do my wash without the horror beeping sound going off every time.
Kenmore Elite HE3t broken belt, maybe?
Chances are due to the description of your problem, especially the noise you describe, is most likely a serious issue. If it sounded like a jet engine when going into spin, the rear bearing may be shot which breaks the belt. This happens over time from using too much sudsy detergent and it drys out the seal and binds up the basket shaft and pow, it blows out the belt. Forget about fixing it, its a gonner! (Sorry) If you replace it with another High efficency machine, READ THE DIRECTIONS AND FOLLOW THEM TO THE LETTER. Especially the use of He detergents only!!
3answers
Excess water in the drum
Boy, would I love to get an answer to this question. Mine has been doing the same thing!
3answers
Kenmore Elite HE3T washing machine code F11
Kenmore Elite HE3T washing machine error code F28, what does this mean?
Alexander
vince
