Question about Acer Aspire 5315 Notebook
Acer Wireless Card Drivers --- Many Thanks!!
You saved my 6. Thanks so much for the tip to get the Broadcom drivers from Gateway's site. It works!
I have a Acer Aspire 3002NLC, and I need to install wireless driver, but cant find anywhere drivers for this model. Not an expert in it, but please, some suggestions...Thank you
@petra_hrg
If you have the Broadcom or Atheros wireless card, you can get the driver at the Acer support site by clicking here.
Good luck.
Sep 06, 2011 | Acer Aspire 3002LCi Notebook
I can't get the network controller drivers to install correctly. I have installed the drivers for my acer aspire 5742g. The FN+F3 can't activate the wireless as a result
Have you installed the correct driver? The 5742G could be installed with an Atheros or a Broadcom wireless card, and these use different drivers.
You can either visually check which make of card is installed in your laptop, or try both drivers and see if either one works.
The following links will initiate a download:
Atheros:
http://global-download.acer.com/GDFiles/Driver/Wireless%20LAN/Wireless%20LAN_Atheros_9.0.0.202_W7x86W7x64_A.zip?acerid=634176982033714605&Step1=Notebook&Step2=Aspire&Step3=Aspire 5742G&OS=721&LC=en&BC=Acer&SC=EMEA_27
Broadcom:
http://global-download.acer.com/GDFiles/Driver/Wireless%20LAN/Wireless%20LAN_Broadcom_5.100.249.2_W7x86W7x64_A.zip?acerid=634176982752697291&Step1=Notebook&Step2=Aspire&Step3=Aspire 5742G&OS=721&LC=en&BC=Acer&SC=EMEA_27
Failing that, perhaps your wireless card has physically failed in some way and needs replacing.
Jul 23, 2011 | Acer Computers & Internet
NO GETTING WLAN DRIVER FOR MY ACER ASPIRIE 5500Z LAPTOP FOR WINDOWS VISTA .
Depending on the wlan model, you need one of these drivers
Ambit
Atheros
Broadcom
Intel
As this is an older model, the drivers may not be compatible to Vista.
If none of them are working, either try to install Windows 7 (with 7 i had the WLAN already installed with windows on a travelmate 5520) or revert to windows XP, for which one of the drivers I gave you works for sure.
Mar 05, 2011 | Acer Aspire 5500 5570-2609 Laptop
My gateway laptop cant connect to the internet. _When I plug a cable, the red light in the port does not respond _ The WIFI does not respond
Hello John,
It seems that: 1. Your LAN controller and the WiFi controller could be disabled in your BIOS setup.To re-enable them, if applicable,
  • Press the F1(or F2 ) key repeatedly after restarting the computer to enter the BIOS setup.
  • Navigate through your BIOS and locate the settings for LAN conroller and wireless, and select Enabled to enable them.
2. You may not have the appropriate drivers installed on your laptop for your network controllers. Upon further investigation, your laptop runs on the following network hardware:
  • ActionTec IEEE 802.11b network card installed in Mini PCI expansion slot
  • Broadcom BCM94306 IEEE802.11g network card installed in Mini PCI expansion slot
  • Broadcom BCM94300 IEEE802.11a/g network card installed in Mini PCI expansion slot
Download and install your drivers for the hardware above from: Wireless Drivers(Broadcom BCM94306) from http://www.soft32.com/download_175098.html Broadcom BCM94306 10/100Mbps LAN drivers from http://www.broadcom.com/support/ethernet_nic/downloaddrivers.php
Hope this solution helps.Good day.
Jan 14, 2011 | Gateway M305CRV Notebook
Hi I have reformat my Acer aspire 3050 and he delete my drivers what should I do to get them back?
HI friend
click here to download your drivers
Realtek - Audio audio.png Acer Aspire 3050 Realtek Audio Driver for Windows Vista Enterprise 32bit
Filename: Audio_Realtek_6.01.5334_Vistax86.zip
File size: 33.3 MB
Version: 6.01.5334
broadcom.jpg Broadcom - Bluetooth bluetooth.png Acer Aspire 3050 Broadcom Bluetooth Driver for Windows Vista Enterprise 32bit
Filename: Bluetooth_Broadcom_6.0.1.3500_Vistax86.zip
File size: 19.5 MB
Version: 6.0.1.3500
bison.jpg Bison - Camera camera.png Acer Aspire 3050 Bison Camera Driver for Windows Vista Enterprise 32bit
Filename: Camrea_Bison_1.0.0.14_Vistax86.zip
File size: 9.3 MB
Version: 1.0.0.14
suyin.jpg Suyin - Camera camera.png Acer Aspire 3050 Suyin Camera Driver for Windows Vista Enterprise 32bit
Filename: Camera_Suyin_1.0.0.8_Vistax86.zip
File size: 22.4 MB
Version: 1.0.0.8
ene.jpg ENE - CardReader no_image.png Acer Aspire 3050 ENE Card Reader Driver for Windows Vista Enterprise 32bit
Filename: CardReader_ENE_5.1.2600.3000_Vistax86.zip
File size: 627.3 KB
Version: 5.1.2600.3000
conexant.jpg Conexant - Modem modem.png Acer Aspire 3050 Conexant Modem Driver for Windows Vista Enterprise 32bit
Filename: Modem_Conexant_7.62.00_Vistax86.zip
File size: 2.1 MB
Version: 7.62.00
synaptics.jpg Synaptics - TouchPad touchpad.png Acer Aspire 3050 Synaptics Touchpad Driver for Windows Vista Enterprise 32bit
Filename: Touchpad_Synaptics_9.1.0_Vistax86.zip
File size: 22.9 MB
Version: 9.1.0
ati.jpg ATI - VGA vga.png Acer Aspire 3050 ATI VGA Driver for Windows Vista Enterprise 32bit
Filename: VGA_ATI_8.332.0.0_Vistax86.zip
File size: 110.4 MB
Version: 8.332.0.0
atheros.jpg Atheros - Wireless LAN wireless_lan.png Acer Aspire 3050 Atheros Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: Wireless%20LAN_Atheros_7.2.0.152_Vistax86_A.zip
File size: 2.8 MB
Version: 7.2.0.152
broadcom.jpg Broadcom - Wireless LAN wireless_lan.png Acer Aspire 3050 Broadcom Wireless LAN Driver for Windows Vista Enterprise 32bit
Filename: WLAN_Broadcom_4.102.15.61_Vistax86.zip
File size: 2.9 MB
Version: 4.102.15.61------------------------------------------------------------------------------
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Mar 30, 2010 | Acer Aspire 3050 Notebook
WLAN wont work after reformatting
http://support.acer-euro.com/drivers/notebook/ex_4620.html  use this link there two hardware of wlan  intel and broadcom under vista. try them.
let us to know  it works.
May 29, 2009 | Acer Extensa 4620 Notebook
Aspire 4310 Broadcom wireless
ok...
the drivers are not getting installed properly and i am sure that you are installing the right drivers,
what you can go is go to device manager and then right click on the drivers and go to properties,
once the properties box opens go to the tab that says drivers,click on update drivers and then go ahead and folow the wizard to update the drivers(make sure you download a fresh set of wireless drivers)..if it still gives a yellow triangle,
go ahead and right click on the wireless drivers,click on uninstall and then restart the computer and checked if it still has the yellow bang..
the link for website is
http://support.acer-euro.com/drivers/notebook/as_4310.html
once you downlaod the drivers its a zip file,download in the desktop,right click on it and then click on unzip,once the files are unzipped go to the unzipped folder and then click on install for the setup..and in this webpage go ahead and choose wireless broadcom as the option as it shows lan broadcom and wireless broadcom,u can also try installing wireless intel because it might be that you have intel card in you computer and not broadcom..
try it out..
vedhick
Feb 12, 2009 | Acer (D10709-002) (D10709002) 802.11g/b...
Acer extensa 4420
Well, I did the same thing, replaced vista with XP Pro, and couldnt get the wireless to work (the xp runs incredibly faster on this machine, B.T.W).
After days and days of trying to figure out this same problem, I finally found the driver. I found it at gateway...the link is here... http://support.gateway.com/support/drivers/search.asp?param=Wireless_Broadcom_4312_v4.170.25.12_XPx86&st=kw
Hope this helps all of you who did the same!
Peace...
T...
Oct 02, 2008 | Acer InviLink 802.11b (91.49C10.002)...
WI-FI problems
Are you sure you have the right drivers? The 3610 comes with more than one type of wireless card. Check on the bottom of the laptop, there should be a white label with the details about your card on it. Match it to the card on Acer's site, download and install.
Hope that helps.
Nov 08, 2007 | Acer Aspire 3610 Notebook
Acer Aspire 5315 Notebook Logo
46 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
