Question about HP Pavilion dv6000z Notebook
My screen is flickering
Hi, I my laptop's screen is flickering pretty badly. It's mainly the left side, but it's getting worse. It flickers more when the charging chord and/or plug is touched or moved. It was used and was fine all day yesterday, and only started doing this late last night. I thought I just had it running too long and turned it off, but after turning in on this morning it's still doing it. It hasn't been dropped or got wet either. I'm currently typing an honors project paper for school snd the flickering is giving me a headache, so if anyone can help me I'd be eternally grateful.
  • kelly 87 Nov 17, 2008
    Thank both of you so much! I don't know how to do anything involving video drivers, and it's a lot worse now (the whole left side of the screen is dim like when its running only on bettery power) so I'll probably take it to a service center somewhere tomorrow. Maybe I'll call Geek Squad. Again, thanks for the help.
  • 50 Answers
This is probably because of something wrong with your lcd invertor or your lcd panel, the best solution anyone can give u is to get this laptop to a service center and ask them if the invertor is good. if not the lcd panel is faulty. u need to replace the lcd panel if thats the situation
Posted on Nov 13, 2008
  • HP Master
  • 4,806 Answers
Firstly try reinstalling the video drivers, if that doesn't work either the inverter is ready to give up or the monitor connector has somehow worked loose from the socket
My TV has a severe flicker/jitter in the bottom left quadrant of the screen. How do I fix it?
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 27, 2017 | Samsung LN-T5271F 52 in. LCD Television
Hp 2509m screen flicker
Hi Kevin,
My daughter has the same problem with her laptop, do you find that when you move the screen slowly back and forth it either stops or gets worse ?
You will need to take your laptop in to an HP dealer and let them have a look at it.
Regards :)
Feb 06, 2012 | Computers & Internet
I have a gateway kav mini laptop when I turn it on the left side of the screen show ok but the right doen't. It has a shadow box and it that side of the screen flickers. How can I get the screen back
Try doing system restore..check if that works else contacst gateway..your laptop's lcd needs to be replaced at 800-846-2301 for further help contact me again thanks
Nov 05, 2011 | Computers & Internet
I have an IBM T40 that worked great until yesterday. When I powered it up, the 4 lights (battery, etc) flickers but the laptop does not power up. I removed the battery, paused, tried with and without the...
There are a few things left you can try. First take the battery out and make sure the unit is unplugged. Next push the power button a few times to discharge any power inside the unit. Now put the battery back in and while plugging in the unit see if the charge light comes on or flickers at all.
If it flickers and goes out, you have a bad power cord or worse a bad jack on the laptop's main board. If it never comes on, you have a bad power cord or mainboard. The battery is probably dead (doesen't have a charge left in it.)
You said this happens regardless of if the battery is inserted. Have you tried powering up the unit with no battery installed and just the power plug?
I'd see about gettting a replacement cord first. If that doesen't do it you probably have a bad board.
Oct 17, 2010 | Computers & Internet
Screen flickering
it sounds like the backlight inverter is on the way out. if the laptop is under warnty get it back to the shop and get it send away for a new screen
Jul 17, 2010 | Dell Vostro 1510 Laptop
Screen flickering
Not likely a bad monitor...
The monitor cable on the back of the computer is loose.
Could also be the screen setting that is difficult to achieve and maintain.
If the cable is already tight on both ends, you might try a lower resolution setting for the monitor.
1. Right-click anywhere on the desktop
2. Go to "Properties" on the drop-down menu
3. Select the "Settings" tab
4. Slide the Resolution knob to the left a little (1024x768 or 800x600) and press [OK]
Hope this helps
Sep 14, 2009 | HP Pavilion dv6000z Notebook
Hi my Toshiba M110 laptop model PSMB0A-0IL00D screen flickers some times. It has gone all black few times as well. Is it cheap to fix? will it crash? Cheers Theo
According to the manual for my Toshiba laptop, the price of the screen is about the third of the price of the laptop. Do the math.
Before looking for a repair shop, investigate first the reason foe the Flicker.
I just remembered: all screens flicker. But if they flicker at 50 Hertz you might notice it. The higher the frequency the less noticeable the flicker is. Check your graphics properties to find out if you screen cannot refresh at a higher rate than the current one (60Hz, 75Hz or higher). But beware! if you force it to flicker at a frequency that it cannot handle, you will damage it.
Hope it helps.
Sep 06, 2009 | Toshiba Satellite A105-S4004 Notebook
Lcd Flickering
Sounds like the driver board for the backlight is going bad...is there a spot on the screen part of the case ( usually at the bottom) that feels much warmer than the rest?
Mar 16, 2008 | Gateway 450ROG Notebook
Flicker
I had the same problem with the flicker. Mine was a Flicker followed by a greenish line through the screen. It got worse then after 2 months the tv stoped working the power didnt come on at all. I Im taking it to bget fixed. The guy said it has somthing to do with a burnt out switch in the unit.
Oct 13, 2007 | Daewoo DSP4210GM 42 in. Plasma Television
HP Pavilion dv6000z Notebook Logo
147 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
