Question about NetGear PS101 Mini Print Server Print Server
Why so slow?!!!??
I bought the ps101 got some help from netgear and my IT guy hooking it up to 3 seperate PCs for printing. All of them print just fine, but it's so slow.... It probably takes a full minute after I tell it to print before it starts. Is that just the way it is or is there a solution?? Please help, Matt C.
    Problem Solver:
  • 4 Answers
Matt C., I bet that your 'IT guy' installed the Netgear software on each PC. He should have installed it on only 1 PC and used it to set the IP, Subnet Mask and Default Gateway on the PS101. Use the 'Printers and Faxes/Properties/Ports' tab of the printer to get the IP, you'll need it in a minute. Download and expand the appropriate Drivers for the printer, or have the CD ready. Remove all instances of the Netgear software from the PC's if your PS101 is configured (Use the 'Control Panel / Add-remove software') Once the PS101 is configured, you can install the 'network printer' on all 3 PC's using the following method (assuming WinXP): Click 'Start' Click 'Settings' Click 'Printer & Faxes' Click 'Add A Printer' When the 'Wizard' opens up, click 'Next' Make sure the option for 'Local printer attached to this computer' is selected, but DO NOT select 'Automatically detect and install my Plug and Play printer' Click 'Next' Click 'Create a new port' Using the 'drop down' select 'Standard TCP/IP port' Then click 'Next' twice In the field 'Printer Name or IP Address' enter the IP that your 'IT guy' assigned during the initial setup (You should have that from the 'Printers and Faxes/Properties/Ports' that I referenced earlier. Click 'Next' You should see 'Standard: Generic Network Card', if so click 'Next' then 'Finish' The 'Add Printer Wizard' should open. Click 'Have Disk' and browse to the folder that you expanded the drivers for the printer into. Click 'Print Testpage' Click 'Finish' You should be printing a lot faster. Let me know if this doesn't work, or isn't clear!
Posted on Nov 18, 2006
  • James Carson Nov 18, 2006
    Just adding some extra steps, my wife interrupted me before I reviewed the steps!
My netgear ps101 went sleeping, cannot be ping. But after power on/off it's ok, then not long after that it went sleeping again.
Somewhere in the setup instructions type the ipaddress of the router in internet explorer and if you have the correct credentials to get in this device you may set the sleep time or shut that off
Jan 27, 2011 | NetGear PS101 Mini Print Server Print...
Hello, How do I connect my Epson stylus PHOTO px700 to my laptop?
NETGEAR’s 54 Mbps Wireless Print Server with 4-port Switch allows you to connect one or two printers to your existing wireless network, without using unsightly Ethernet cables. Simply place your printers anywhere in your home or office that works best for you, plug them into the print server’s USB ports, and the Smart Wizard set-up function automatically guides you through configuration. Then you can send your business documents to a high-end color printer, and your kids’ homework to a black-and-white printer. The print server also acts as a wireless Ethernet bridge, connecting a cluster of up to four PCs and laptops without requiring dedicated wireless adapters. I t employs powerful WEP Encryption and WPA-PSK to keep your wireless network secure, and interoperates with all standard b and g wireless devices. All this in a sleek, space-saving stand-up case.
Mar 22, 2010 | NetGear WGPS606 (WGPS606NAR) Print Server
I had a PS101 hooked up to an older wireless router. It was working fine on my new Vista Machine. The router died and just installed a NETGEAR WGR614 Wireless Router 802.11g. Now it doesnt see the print...
This was more hastle than it was worth. So I bought a new print server (twice), neither worked either. Might be the router, but after spending 2 hours on the phone with INDIA, I said forget it and took it back, bought a parallel card and gonna hook it up with a cable!
Jan 01, 2010 | NetGear PS101 Mini Print Server Print...
Vista
Re: Vista and Print Server check out a reply from 2006 at:
I need HP Printer Driver for Vista - DriverHeaven.net
gave hint to use hp deskjet 5400 driver instead of the hp business inkjet 2230 driver i have been trying for days with my Netgear PS101 print server (v1?). Finally works, at least for a complete looking test page and the preferences for the 5400 printer seem clearer than those given for the 2230. maybe that is why print servers and printers are not working...it is the driver supplied by HP is wacko for vista?
Jul 12, 2008 | HP Business Inkjet 2230 Printer
Installation assistant cannot detect print server
Results of attempting to connect the Netgear Wireless Print Server WGPS606 and the Canon MF6550 multifunction laser printer. I was on the phone for several hours last evening (March 9, until about midnight EDT) with a very competent support agent from Netgear (actually in the Philippines). The Netgear setup Wizard software would not connect the Print Server to my Verizon FiOS wireless G router automatically, so the Netgear support agent walked me through it manually. The Print Server connected that way, for sure. Then we manually attempted to connect the Print Server to my Canon MF6550 and subsequently, my HP 932C Deskjet. Neither printer is on the WGPS606 compatible list, nor is either on the known incompatible list. Now we know - both printers are INCOMPATIBLE with the Netgear WGPS606. I bought both the Netgear Print Server and the Canon MF6550 at Staples on Sat., March 8, 2008, based upon the assurance from Staples staff that it would all work. The question now is whether ANY brand of wireless Print Server will work with the Canon MF6550, or do I have to return this printer and get either a Canon with built in networking (ethernet or wireless) or switch to the Brother equivalent (MFC 8870DW). If I get a (multi-function) printer with built-in Ethernet networking, does the Ethernet capability bypass the USB incompatibility problem, or will the problem remain?
Mar 10, 2008 | NetGear WIRELESS PRINT SERVER 54MBPS...
Problems with netgear ps121 print server
is your firewall blocking your print? If so, you need to set the firewall to trusted for the printers and print servers ip address
regards ontheedge
Nov 26, 2007 | NetGear PS121 Print Server
Print server
Check the port configurations on both XP machines. It should have the IP address of the print server connected to the plotter.
Aug 01, 2007 | NetGear PS101 Mini Print Server Print...
ALERT LED light - Blinking Amber - Nothing prints, printer not recognized
The blinking amber light means there is a hardware problem. Got that from Netgear's website because we have a similar problem here. I don't know if it means hardware problem in the print server or in the printer. We put the print server on a UPS Uninterruptible Power Supply and that problem seems to be gone. We are in an old factory and the wiring is not so reliable. Maybe you could try this same fix.
Nov 28, 2006 | NetGear PS101 Mini Print Server Print...
NetGear PS101 Mini Print Server Print Server Logo
403 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
