Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
My top load whirpool washing machine leaks during spin cycle.
When in the SMALL load only, the washer leaks in the spin cycle. It seems to come from the top / rear of the tub as if the splashing from the spin leaks out. We have taken it apart several times and have determined that none of the hoses ot valves are leaking.
The machine was purchased in the summer of 2006.
It is just the basic model with a small, medium and and super loads.
  • jag05 Dec 30, 2008
    I have the same problem with my whirlpool washing machine.
  • 324 Answers
It only does it on the small load? does the water drain out before it goes into spin?
Posted on Nov 14, 2008
Why does it leak all over floor after last spin cycle?
my washing machine leaks water onto the floor during each spin ...
Feb 3, 2010 - During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. ... It happened to us due to over loading. ...something can get betwen the two tubs it this all fails your tub seal is ...
Sep 30, 2015 | Kenmore Elite Oasis 27052 Top Load Washer
My whirpool WFS1071BD front load washing machine leaking when spinning
During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find.
Oct 14, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Hi I have a 5 cycle 2 speed top load whirpool washer and it all of a sudden will not go to the Spin Cycle and drain out the water. It stops in the rinse cycle. I need help!
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
Jun 25, 2011 | Washing Machines
Whirpool cabrio won't spin cycle
I just paid $85.00 for a tech to come out and pull some socks out that got stuck between washer drum and outside plastic drum. It took 10 mins. top.
It seems when you pull clothes out of washer small items slip between inner and outer drums. BAD DESIGN.
Jul 07, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirpool Duet Sport Washer still making noise now it s leaking
make sure to look really close all it takes is alittle whole in that seal anywhere to cause a leak try to look close while it is running but first dry everything you can and then run it. also make sure your door glass is clean if it is leaking down the front just alittle dirt or hair can cause a leak aswell
Mar 08, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Washer, Loads become unbalaced in spin cycle.
it has a bad balance ring on the top of the basket no so hard but not that easy either
you have to remove the case to get to the balance ring
go to and go to parts and put in the full model number, under the parts tab in appliances and select view brakedown and it will explain it better with you seeing it
May 08, 2008 | Whirlpool LSR5132PQ Top Load Washer
Whirpool Front Loading HE (GH9400PW4) washer is leaking! Hellllp!
remove the bottom acesss panel and run through drain/spin cycle youll see where the leak is then. perhaps debis has puntured drainline hose or pump housing is leaking
Mar 02, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Leak from maytag top load coin machine during spin drain cycle only
Possible that you would have a tub seal leak if it is only noticable during spin cycle. Possible that it "drips" slightly while in agitation, but not enough to notice it. While in spin mode you have a lot more parts moving as well as a lot more water pressure on the seal itself. Pump could also be leaking, but highly doubtful since it would leak a constant amount at all times. Good Luck!!! Jim
Sep 07, 2007 | Maytag MAT13MN Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
318 people viewed this question
Dan Webster
Dan Webster
Sal De
