Question about Mitsubishi WD-52525 52" Rear Projection HDTV
No power i have a wd62327 tv and the status light blinks red. i had sears tv servce out and without turning it on or anything, he calls someone and tells me the capacitors are out. the service code blinks 36 but he said that didnt mean anything. where are these caps located at.
  • ddlc56 Nov 18, 2008
    it wasnt the caps! it was the cooling fan
  • Mitsubishi Master
  • 8,617 Answers
They are located on the power pwb There are four 1000uf 16V two 3300uf 16V and two 2200uf 35V that need to be changed
Posted on Nov 15, 2008
I have a 2005 Mitsubishi WD62327 62" rear
Yes, this kind of symptoms is not costly to repair. I can assist you which part gone bad on this error code. Click here.
Jdvillanueva
Oct 03, 2011 | Mitsubishi Televison & Video
I have tried to turn my television on and the status light blinks for about a minute, you can hear the TV try to start up and then the whole system shuts down without anything actually powering up. Also...
Unplug the tv for about a minute - plug it in and press the reset button on the front of the tv - hold it until the light blinks. The set should come on in a minute of two - if not try the same routine again.
Jan 16, 2011 | Mitsubishi WD-73827 73" HDTV DLP TV
Toshiba 61 inch hdtv has a blinking red light by the on off switch and wont turn on
The blinking of the status light signals the fact that the power source of the tv is in protected mode: another part has failed the big way and now it acts as a short; because of that it draws a lot more current that it should; this is detected by the safety system of the power source and it automatically shuts it down to protect it and the rest of the tv.
The only way to fix that is to open the tv, test it, identify the failed part and why it failed, fix the cause and replace the failed part. This is a job for someone with electronics experience - if you're not one then it's time to call a repairman.
Dec 16, 2010 | Toshiba Televison & Video
HELP! I changed the bulb already. My NEC VT 470 won't turn the bulb on. The green power light comes on, then the status light blinks green about 12 times, several rotations. Then the fan comes on, the...
Sounds like you lamp ballast has gone bad. I good way to verify this is, when you press power on the projector look inside the lens. If you see a small amount of light, then the ballast is good, and the lamp is bad. If there is no light then chances are the ballast is bad.
Apr 14, 2010 | NEC VT470 Multimedia Projector
I have a mitsubishi tv model #wd62327 it was on
Your user manual should give you the diagnosis... it is probably available on line if you don't have it. I would guess the fan is making noise and needs to be cleaned, lubricated or replaced. I hope this is helpful to you.
Oct 26, 2009 | Televison & Video
STATUS LIGHT SOLID RED ON 73 DLP MITSU MODEL WD73735
The colorwheel is your problem. To confirm this, unplug the tv, then listen thru the air vents in the back as you plug the tv in. You will probably hear a ticking sound. If you do, that is the colrwheel. If the colrwheel is working, youwill be able to hear it "spin up". It will be a sudden high pitch whine. Let me know if I can be of further assistance
Dec 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Status light on, tv will not respond
if the "status" light is blinking red than you most likely have a fan failure going on inside the set. there are 5 fans in the tv and it could be any one of them.
Apr 01, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Panasonic th-42pz77u 42ed
Pin 93 of the MPU IC9003 monitors the status of the SC, SU, SD board. During normal operation, the photo-coupler PC6480 outputs a low to pin 93. If the SC, SU, or SD board becomes defective, a high is provided to pin 93. As a result, the unit shuts down and the power LED blinks 7 times.
Jan 07, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
