Question about D-Link DES-3052P 48-Port 10/100 Managed Network Switch with PoE and 4 Gigabit Ports + 2 Combo SFP
How to hide connections tabs,privecy tabs,advance tab which is showing or reflecting after click on tools tab way-- Internet explorer---Tools-----Internet options------CONNECTIONS OR PRIVECY OR ADVANCED TABS PLZ GIVE ME QUICK REPLY AS SSON AS POSSIBLE THANKS UUUUUUUUUUUUUUUUUUUUUUUUU
    Scholar:
  • 118 Answers
If you are useing windows XP. install a litter software named "gpmc.msc" DOWNLOAD
Go to RUn >>> gpmc.msc >>>> "here you can apply policies in the internet explorer's "menue"
regards,
Posted on Dec 03, 2008
When I log in to yahoo mail, did not show anything, but keep loading
What browser are you using?If internet explorer, you can try optimizing the browser, click on Tools or alternatively hold the ALT key in the keyboard and press R, select Internet Options
-General tab, click Delete, untick preserve favorites website data, tick all the other options
-Security tab, click Reset all Zones to Default Level (if greyed out,skip this step)
-Connections tab, Never dial a connection should be ticked or there should be a dot on it
Click LAN Settings, make sure no options have tick.
-Advance tab, click Restore Advance Settings at the bottom right.
Click ok, close all Internet Explorer that are open and the reopen a new one.
Hope this one helps. Thanx.
Mar 30, 2011 | Yahoo Mail
Proxy server is refusing connection,how can I fix it?
Heya
According to the description of the problem , m assuming that its something to do the proxy settings of the browser your using.Now if your using INTERNET EXPLORER Follow the steps mentioned below-:
open IE
Click on tools and then internet options
Then click on connections tab
Then lan settings
Now uncheck all the options starting from bottom including BYPASS PROXY SERVER FOR LOCAL ADDRESSES and USE A PROXY SERVER FOR YOUR LAN..
Click on apply ok
Restart IE
Now you ll be connected
Now if your using MOZILLA FIREFOX
Click on tools and then options
Click on advanced
Click on network and then settings
Select NO PROXY
Click ok and ok again
Restart Mozilla and u ll be connected
Now if your using a different browser let me know..Hope this fixes your problem if it doesn't please reply
Thanks & Regards
LOnG LIvE tHe GeEKS!!!!
Dec 12, 2010 | Computers & Internet
When i open internet explorer the internet connection is terminated and a message appears- the tab has been recovered. Website restore error is written on the tab.
Open up internet explorer , click on tools, click on the advance tab, then click on reset button at the bottom, follow the prompts, close internet explorer, and then try to re-open it and see if it works.
Oct 21, 2010 | Microsoft Internet Explorer 8
There are several songs that are on the m240 that are not showing when you look at it's files - how are these hidden?
If you added songs to the device in MSC mode, then switch to MTP mode, you will not be able to see the songs added in MSC mode and vice versa, though the space used on the player will still reflect their presence. Switching modes should make the files show up. For example, switching from MSC to MTP mode or vice versa.
For older players - e200v1, c200v1, c100, m200 - the files become hidden files if the modes are switched. An easy workaround is to edit the folder options to show hidden files.
STEP 1 - Edit the folder options of the computer to show the hidden files
Windows XP:
1. Double-click My Computer.
2. Under the Tools menu, select Folder options, then click the View tab.
3. Under Hidden files and folders option, select Show hidden files and folders.
4. Uncheck the Hide protected operating system files (Recommended) check box.
5. Click Apply, then click OK.
Windows Vista:
1. Double-click Computer.
2. Click the Organize button on the upper left corner.
3. Click Folder and search options.
4. Click the View tab and select Show hidden files and folders.
5. Uncheck the Hide protected operating system files check box.
6. Click Apply, then click OK.
SOLUTION 2 - Perform a Check Disk.
STEP 1 - Switch to MSC mode
1. On your Sansa player, switch the USB mode to MSC.
2. Connect the Sansa player to the PC.
STEP 2 - Perform Check Disk
1. Locate the Sansa player under My Computer.
2. Right-click the removable drive associated with the Sansa player, and select Properties.
3. Click the Tools tab, and then click Check now.
4. Click to select the Automatically fix the file system errors and Scan for and attempt recovery of bad sectors check boxes.
5. Click Start.
See also this tip on what it all means http://www.fixya.com/support/r3774047-solve_mp3_player_connection_problem
Jan 02, 2010 | SanDisk Sansa m240 MP3 Player
IE cannot display webpage eventhough wireless network connection is excellent on a brand new asus ee PC
Open IE then in the tool bar click on tools then internet options.
When the internet options box opens click on the advanced tab, at the bottom of the box click on restore advanced settings and then click on the rest tab
close IE then try and see if it works
Hope this helps
Dec 21, 2009 | ASUS Computers & Internet
Explorer problem
Hi
I suggest to restore the settings of your internet explorer to defaults. There could be bugs during your windows update.
1. Open internet explorer, go to tool --> Internet Options ---> Advanced tab ---> Reset.
Reset all the settings then restart your computer. In case you cannot open internet explorer because it will just give you a white blank page. try the following steps below.
1.1a Click Start -- type msconfig on start search box (for vista only). Click Run (for xp only). a pop up box window will show up (System utility configuration). Look for the tab Services.
Under services tab, put a check on the box that says "Hide all microsoft services" at the very bottom screen. Click apply then close. Restart the computer.
After restarting the computer follow step 1.
Keep me posted
Regards
Oct 18, 2008 | Microsoft Windows Vista Ultimate Edition
Vista problems closing window in email
try opening "new" pages in Tabs and when you want to exit said page just close the tab.
Jul 01, 2008 | Microsoft Windows Vista Ultimate Edition
Can't Connect to the Internet
Two things you can try before trying your browser/Internet connection:
1. Right click on the Wireless Network Connection Icon, click on Repair. Allow the computer time to repair its WiFi connection and some other settings;
2. Right click on the Wireless Network Connection Icon, click on Status. Click on properties button, select TCP/IP (Internet Protocol), click on Properties button, verify that the option "Obtain IP address automatically is ticked, OK, OK.
3. In your browsers, verify/modify settings:
In Mozilla, click on Tools, Options, Advanced tab, Network tab, Settings button, tick "Auto-detect proxy settings for this connection, OK, OK;
In IE, Tools, Internet Options, Connections tab, LAN settings button, check "Automatically detect settings" (& pls make sure there is no check mark on the Proxy server), OK, Advance tab, check Use HTTP 1.1 through proxy connections.
In Opera, Tools, Preferences, Advanced tab, Network, Proxy server buttons, check "Enable HTTP 1.1 for proxy, OK, OK.
Pls post back how things turned out or should you need additional information. Hope that this be of some help/idea.
Good luck and kind regards.
Nov 17, 2007 | D-Link Air DWL-122 802.11b Wireless...
Settings for my browser
If you use Internet Explorer: Go to Start, Settings, Control Panel, Internet Options, Connections, and the LAN Settings button. Clear all checked settings in this window. Then, open your browser and select the Tools menu. Under Internet Options, click on the Connection tab and make sure that "Never dial a connection" is selected. If possible, remove all the connection settings. If you use Netscape Navigator: Go to the Edit menu and select Preferences. Go to Advanced, Proxies, and click "Direct Connection to the Internet." Also check for the following. If you are running Windows 95 or 98 or ME: Click on the following tabs and write down the settings you find. Right-click on Network Neighborhood and select Properties. Select "TCP/IP" for your network adapter. Then click Properties. Click the IP Address tab and select "Obtain an IP address automatically." Under wins configuration, click on use DHCP for wins resolution Click the Gateway tab. If there are any "Installed gateways," highlight them and click Remove. Click the DNS tab and select "Disable DNS." Click OK If you are running Windows NT: Write down any settings you see throughout the tabs for future reference. Right-click on Network Neighborhood and select Properties. Click the Protocols tab, highlight TCP/IP, then click on Properties. Click the IP Address tab and select "Obtain an IP address automatically." Remove any gateway settings you see. Click OK. If you are running Windows 2000: Right-click on My Network Places. Click on Properties. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK. Go the the advance tab, click on wins, check the box use NetBios settings from the DHCP server. If you are running Windows XP: Click on My Network Places. Click on view network connections. Right click on the Local Area Connection icon that connects to the Router. Click on the Properties button. click on the advance tab, make sure the internet connection firewall is not checked, click ok,Highlight TCP/IP, then select "Obtain an IP address automatically." Click OK.
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
How can i verify??
Feb 16, 2006 | Belkin (F5D5230-4) Router
D-Link DES-3052P 48-Port 10/100 Managed Network Switch with PoE and 4 Gigabit Ports + 2 Combo SFP Logo
114 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
