Question about Garden
Flotec pump model#FPOS1775A stops pumping
Pump stops while water is still in hole. It starts and shuts off. Bastment is still getting water in. I thought pump would stay on as long as water was still in window well.
  • 1 more comment
  • BlackToe Jan 02, 2009
    Just installed the same unit in my crawlspace. The manual states it will cycle for 15 minutes, and then run normally. It's been 30 minutes, and the pump is still cycling on/off, even though it's sitting in 4 inches of water.
  • mzzz1 Jan 07, 2009
    Related problem - my FPOS1775A will not shut down, even when it is sitting on dry floor.
  • Anonymous Mar 04, 2009
    same problem and soes not pump water out
2 Suggested Answers
  • 4 Answers
SOURCE: my Flotec pump runs 5 seconds shuts off for 30
fully submerse pump in bucket of water, tilt to get all air bubles out,(keep hose off) plug in and it should work fine
Posted on Apr 03, 2010
Flotec Model FP4012-D8 stopped pumping water. I took pump apart except for small impeller housing edge break I can see no reason for no suction?????
Hi jandh40...
You have an air leak somewhere in your piping, housing of the pump or maybe the mechanical seal and that is causing your pump not to pump.
Try to disconnect the piping and hook a water hose up to the pump and turn the pressure on, it should show you where the air leak is by spraying water out of the leak area.
Please take time to rate me
Aug 15, 2011 | Flotec Corrosion Resistant Shallow Well...
I have a Flotec FP0S1775A Utility Pump. It is in a section of my basement (flat) that is about 1.5 inches lower than the rest. Today is the first day the pump is being used and for the most part it is...
1 inch of water is probably not enough water to set off the pump. The water level must be high enough to float the switch ball beyond 90 degrees of level before it will activate the pump. The pump will not evacuate all of the water there will always be some water left in the tank this prevents the pump from a dry start.
Mar 07, 2011 | Flotec 1/4 Horsepower Sink Pump System
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
I have the FPOF 360 AC model - 1/12 HP 350 gal/hr. The motor is working, but it is not suctioning any water. Thanks. Karen
I would take a drill and drill an eighth inch hole in the discharge pipe of the pump. I always do this
when installing a new pump, because sometimes the pump will get air in it, the little hole will vent
out the air. There will be water squirting out the little hole, but that doesn't hurt anything.
Hope this helps.
Oct 30, 2010 | Flotec Plumbing
Flotec pump model FP 4112-08 will not pump over 35 psi
If it stops pumping at 35psi you need a new pressure switch. If it just continues to run but doesn't build more pressure the problem is more likely a plugged point or air getting in due to the water table dropping.
Jul 14, 2010 | Flotec Corrosion Resistant Shallow Well...
I have a Flotech Model FP0S1775A intellipump utility pump. It is supposed to be just plug it in and it works automatically but that is far from true. I am having all sorts of problems with it and I dunno...
flotec intellipump does not work,new,out of box.does not detect water under any conditions.as we have flooding in r.i.,i thought i got lucky to find this pump in home depot in dartmouth mass.now i find i have a basement full of water,and a hastle trying to get my money refunded.
Mar 30, 2010 | Flotec 1/4 Horsepower Sink Pump System
I have a 1 month old Model FPOS1775A Flotec pump. The discharge hose is 3/4 inch with a level run of 20ft.It pumps water but only at 2 and a half minute intervals even when fully submerged!!! I now have a...
If the pump is only pumping for a few seconds at a time it may be a problem with the control board. On two of mine, the 10mf 100v smd capacitor came loose. Resoldered and potted with hot melt glue. One of them is working with the other yet to be tested. Don't recall what the exact symptoms were, only that it wasn't continuously pumping water while submerged.
Unit is oil filled so should be dismantled in the upright position.
Feb 23, 2010 | Flotec 1/4 Horsepower Sink Pump System
My Flotec pump runs 5 seconds shuts off for 30
Dec 02, 2009 | Flotec 1/6 Hp 1260 Gph Utility Submersible...
Schematic for wiring in a Flotec Pump
Remove end casing of Flotec motor housing they have a 115v/220v switch, turn to 220v, see website flowtec water. Flotec parts 1-800-365-6832
Jan 31, 2009 | Flotec Corrosion Resistant Shallow Well...
Garden Logo
668 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
