Question about LG Studioworks 440SI 14" CRT Monitor
Not working 1024 by 768 pixels resolution
I have an LG 500G 14' monitor which about 5 years old. At present when I want to set the resolution in 1024 by 768, it shows 'out of frequency' message.But earlier 1024 by 768 resolution worked.
40 GB Hard Disk, 256 MB RAM & Windows XP SP2 is in my computer.
  • Anonymous Jan 09, 2009
    lg 15 inchmonitor not supporting 1024/768 pixels resolution
  • kiriomix Feb 18, 2009
  • 558 Answers
Reduce the number of colors until you can get a resolution that works the monitor cant handle the number of colors and the number of lines of resolution this is a common problem with older monitors.
l8r
Posted on Nov 13, 2008
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
LG STUDIOWORKS 500G monitor dead ?
your irf 630 is not original purchase it from proper LG authorised service centre it is costly but never become faulty again duplicate mosfet overheats if your green led is on then measure voltage at E.H.T.connect meter at output transister if E.H.T. is producing then meter should show 1 digit if not then 50v will show take care that signal cable should be disconnected if E.H.T. is not producing then check +vcc at horizontal ic it should be 12v. if 12v is not present then check regulator ic 7812 insmps
Mar 14, 2010 | LG 500LC Monitor
Plugged in a new 23 inch LG LCD Monitor and cannot get picture
In additio to the fine help given by Mister.
If you have a DVI output on your computer get the cable for that and this will greatly increase the quality of your display.
Your graphics card should be able to autodetect a DVI monitor and suggest the best display type.
Sep 16, 2009 | Computers & Internet
I am unable to make resolution 1024 x 768 in lg model 500G
If the monitor is somewhat old and the monitor hardware doesn't support 1024x768 resolution, installing a new driver won't help. You will have to switch to a better monitor.
Dec 21, 2008 | LG Studioworks 563N 15" CRT Monitor
Resolution Problem
go to your desktop display properties then go to setting then go to advance then monitor tab chack your screen refesh rate may be 85Hertz.now change rate to 56Hertz and apply.now you change your resolution 800*600 to 1024*768.
Dec 20, 2008 | LG L1915S 19" LCD Monitor
My studioworks 500G monitor LED blinking with twise colour(Green and Amber)and no display.
1. LOT problem.
2. Horizontal transistor bad.
3. Dry points in neck board, horizontal section.
4. transformer output capacitors problem.
5. IRF 630 ( lot supply fet )
Nov 03, 2008 | LG Studioworks 45 14" CRT Monitor
LG STUDIOWORKS 500g - FULL SCREEN NOT GETTING DISPLAYED
It's Loose contact Problem in Vertical section
Pl corrected dry points all over the vertical section.
Aug 31, 2008 | LG Studioworks 45 14" CRT Monitor
Whenever system restart , led blinking, no display
15" Monitor warranty period 1 year from mfd date.
17" Monitor warranty period 3years from mfd date.
Aug 22, 2008 | LG Studioworks 45 14" CRT Monitor
Lg 500g crt monitor problem
Try checking B+ coil , may be the coil have shorted .
Happy trying
Apr 01, 2008 | LG Studioworks 45 14" CRT Monitor
Screen resolution
What is your monitor manufactoring year? Because old monitor could not set up to 1024x800 pixels. Please check the refresh rate also at the monitor property tab.
Dec 10, 2007 | Gateway FPD2275W LCD Monitor
LG Studioworks 440SI 14" CRT Monitor Logo
302 people viewed this question
Top LG Computers & Internet Experts
Brian Sullivan
Brian Sullivan
k24674
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
