Question about KitchenAid KCMS185J Microwave Oven
The turntable on my model kems307dbl4 has stop turning
Can I fix it?
    Problem Solver:
  • 19 Answers
The turn table in the mirowave in turning based on the motor I am assuming with a tiny belt. Either the belt is broken or motor is shut. Or sometimes motor can get stuck. You have to opened it up and check it out. Usually when the door is open you can not turn the microwave on. Do not turn on the microwave when you have the cover off. It will cook you.
Posted on Jul 31, 2009
    Scholar:
  • 181 Answers
Remove the glass plate carefully.and check the gears it they are cracked or damaged it has to be replaced.if any thing is blocking the gears clean them.
Posted on Nov 13, 2008
How to fix a Samsung microwave turntable
The drive motor underneath probably has failed.
Nov 17, 2016 | Samsung Microwave Ovens
My microwave turntable stopped turning but the microwave still heats up and works, otherwise.
You didn't say what model microwave you have, but most that I have seen have two separate circuits inside. One operates the magnetron (which makes the microwaves) and the other operates the other things like the turntable or the inside light etc.. It is quite possible that you have a problem in that second circuit. This allows the heating without the turning. To fix this type of problem, if indeed that is the case, requires some skillful trouble shooting inside the microwave which I don't recommend your try unless you are a skilled technician, because of dangerous voltages. Go ahead and post the brand and model number and I can be more specific as to what action to take.
Dec 24, 2015 | Microwave Ovens
How do i fix a sanyo microwave
call ser. tch. ur motor might be spoiled already . its a added function mabe of the unit if ur turntable motor not wroking so does ur microwave
Feb 21, 2015 | Sanyo Microwave Ovens
Microwave turntable stopped turning. Can I fix this?
The turntable motor will need to be replaced, this type of repair is tricky not to mention the lethal voltages it carries. I strongly recommend a professional for this job.
Jun 24, 2012 | Emerson Microwave Ovens
Turntable has stopped turning
Remove the turntable plate from the oven. Put a cup of water inside the oven, away from the turntable drive gear. Turn the oven on and look through the door to see if the drive gear is turning. If not, then the motor is probably defective and needs to be replaced.
Nov 15, 2009 | Sharp R-303CW Convection / Microwave Oven
My LG Microwave LRM2060ST turntable has stopped turning. This is a 1200 watt 2.0 cu ft countertop model.
If the oven is heting and turntable not turning, then the problem is either the turntable coupler or the turntable motor.
The faulty part must be checked and replaced.
Sep 09, 2009 | LG LRM2060 Stainless Steel 1200 Watts...
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Frigidaire microwave gallery series turntable is not turning
This co. has one for $19.99
http://microwaveglasstrays.com/shop/microwave-turntable-motor-st16fe-ex73saaa3-p-214.html
I am also looking elsewhere
Mar 04, 2009 | Frigidaire FMT116E1B Microwave Oven
Microwave stopped working
to indutolia
The original problem was probably a bad turntable motor, which is pretty easy to replace.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Now I'd say you have a bad door switch (whether upper or lower depends on the model number) or a problem with the door switch mount.
This is a pretty simple problem to fix, too: http://www.microwavedisplay.com/doorsw.txt
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
to lostonisland - Your problem is different enough that it should be a separate post. Please include your brand and model number when you repost.
Dec 10, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker XL 1800 Turntable malfunction?
You can find helpful exploded views and buy the replacement turntable motor at http://tinyurl.com/gv383 Need safety tips? See http://tinyurl.com/yzjozk
Jan 14, 2007 | GE JVM2070 Microwave Oven
KitchenAid KCMS185J Microwave Oven Logo
80 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
