Question about Kenmore Elite 45986 Front Load Washer
Drum filling with water after cycle is done
Drum fills byn itself over night, it appears to be clean water
  • 63 Answers
Replace bad fill valve its bleeding throw under top left rear easy
Posted on Nov 14, 2008
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
Samsung b1113j washer
Kelly, try this. Let the machine auto clean. Then run a full cycle without a load at Normal setting. good luck
Dec 30, 2013 | Washing Machines
Water draining as it is filling the drum
The drain hose is not high enough and it is siphoning the water out. Get the highest point of the drain hose above the water level in the washer.
Nov 12, 2009 | Washing Machines
I have water leaking out of the bottom of the drum. We came home one night and the floor and carpet were all wet after running a load of laundry. My husband and I,after cleaning up the mess, investigated...
Could be damage to drum ie hole in it .Pour some water in to it with a kettle or alike, this should tell you..Is it quite old or has damage happened due to coin,,Kind regards...
Sep 29, 2009 | Maytag PAV2300 Top Load Washer
My washer continually fills with water
your fill valve is stuck open replace fill valve
Sep 28, 2009 | Kenmore Elite 45986 Front Load Washer
Water appears in drum after wash cycle is finished.
if you remove the front cover there is a drain plug that holds change and lint paperclips etc, it fills up and gets plugged and wont go throught the drainig pump. if you find this and clean it out you will be good for another 6 months...its important to check pockets before washing
Sep 09, 2009 | Washing Machines
Water in the baskedt
yes it is the problem replace the water inlet valve
this is done by removing the top you will see the valve that the fill hoses connect to
make a diagram of the connections so that you get it right when you reassemble the unit
May 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
WD62 drawer leak
remove drawer clean it make sure flap is free on drawer compartment
Nov 24, 2007 | Hotpoint WD62 Front Load Washer / Dryer
Kenmore Elite 45986 Front Load Washer Logo
122 people viewed this question
Sal De
 Brian Main
Brian Main
