Question about RCA F36649 36" TV
Channels just automatically started changing themselves and will not quit
We can get to the menu and the guide but because of the continous changing of the channels we cannot get it to stop on anything to make the changes such as Language,etc. We have looked through the other problems and could not find one such as ours. We do have the TV unplugged and are awaiting info hopefully from you to help us. Thanks Tadpole
    Scholar:
  • 119 Answers
I have seen this befor, 1st. take batteries out of remote to make sure that no buttons on the remote is causing this problem. If the problem presists then the fault is the buttons on the front of the tv.power,vol,ch, etc. if one is bad I replace them all. if you can remove the front board, ( it usually clips in and out hard, try not to break the clips) if the wire/cable dissconnects you can take it somewhere that sells switches. the originals are $5.00 to $10.00 each, price adds up fast. or replace one at a time & take your chance. good luck.
Posted on Nov 16, 2006
How do i program my channels
Hello
Your Toshiba tv can be automatically tuned to all stations. The procedure follows.
Programming channels automatically
Your TV can automatically detect all active channels and store them in
its memory. After the TV has stored the channels in its memory automatically,
you can add or erase channels manually.
To add channels automatically:
1. Press MENU, then press "left arrow" or "right arrow" button to display the SETUP menu.
2. Press "Up arrow"or "down arrow" until the TV/CABLE
selection is highlighted.
3. Press "left arrow" or "right arrow" button to highlight either
TV or CABLE, depending on which you use.
If you use an antenna, choose TV.
If you use cable, choose CABLE.
4. Press "down arrow" button until the CH PROGRAM selection is highlighted.
5. Press "left arrow" or "right arrow" button to start channel programming. The TV will automatically
cycle through all the TV or Cable channels (depending on which you
selected), and store all active channels in the channel memory.
While the TV is cycling through the channels, the message
"PROGRAMMING NOW-PLEASE WAIT" appears.
6. When channel programming is complete, the message "COMPLETED"
appears.
7. Press CH UP or DOWN button to view the programmed channels.
OK.
Dec 14, 2010 | Toshiba 26HF85 26" TV
I have a lio pdp42010ea1 and have quit the tv services and now want to learn how to search the air and find the channels that are on channels 5, 24 ect.I also need to know if you have to have a tv antena...
Unless your television comes with an auto tuner you will need to attach an antenna.
If you do have an autotuner...go into your menu of the television. Look for setup/settings and find input option...make sure this says antenna or auto tuner, they usually start the scan automatically or just press enter/select to start.
You should be all set:)
Nov 21, 2010 | Televison & Video
I just bought a new dynex 32 inch that did not come with a manual. I attached the cable into the correct area however I am still unable to see my cable channels even when changing the input. What am I...
Check this link to download the user's guide or quick setup guide. Press menu > channel, go down to TV source change it to cable and go down to auto scan and press > to start programing the channels into the LCD memory.
Sep 14, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
My brightness and contrast keeps on changing continously. please solve it.
I'm not sure what you mean by your problem. Do these keep changing by themselves at random?
I would first borrow another monitor and see if the problem is the same. If not, then your monitor is going bad.
There should be a reset button on the monitor--perhaps a menu item on the monitor menu--that says to reset the monitor values. That might work, but the symptoms you are describing are pointing to either the power inverter or the circuit board on the monitor.
Jan 11, 2010 | IBM E74 Monitor
Dose anyone have any codes,for N*L Dublin 19/12/08?
New codes are:
NTL
B0 B8 4F 04 E6 5F 87 80
A3 EB EC 07 D6 49 D2 EB
(How do you do this? Using your remote, click Menu, press 1570, then change the codes using your remote as your keyboard with the buttons=characters/#s on the screen as guide). Then Exit.
2. Goto menu, select Installation, Select NTL, then select Automatic Scan. Once finish exit and check if channels are ok.
If the channels are still showing nothing..
3. Press Menu again. Choose factory settings, enter 0000 as code. then press OK to delete/reset.
4. when your back to the Menu, press 1570 then set EMU to On again. Exit.
Dec 19, 2008 | StarTech.com StarView SV211K 2-port KVM...
How do i tune my philips 3590H philips dvd recorder into digital
The User Manual for your DVD Recorder is available here... http://www.p4c.philips.com/files/d/dvdr3380_05/dvdr3380_05_dfu_eng.pdf
Info related to your specific problem is as follows...
Setting your TV channel
programmes
Before the recorder can start recording
the TV channel programmes, you need to
search for the available TV channels and
store them in the recorder.
Note: Make sure you have successfully
made all the required connections to the
recorder, the TV and Satellite Receiver/
Cable Box (if any) and switched them on.
Tuner settings can only be changed
when there is no disc in the disc tray.
A Press SYSTEM-MENU on the remote
control.
�� The system menu appears on the TV.
B Use ���� keys to highlight
{ System Menu - Channel Setup }
and press ��.
Modify Channel Information
Sort Channels
Channel Search
Edit
Sort
C Use ���� keys to highlight { Channel
Search } and press OK.
�� The automatic TV channel search
starts. This process may take several
minutes. Once complete, the total
number of channels found appears on the
TV.
Automatically scan all the receivable analogue local TV
channels and store these channels on the recorder.
�� Use ���� keys to highlight { Channel Search } and press OK.
�� The automatic TV channel search starts. This process may take
several minutes. Once complete, the total number of channels found
and stored appears on the TV.
Modify Channel Adjust a stored TV channel to your preference, improve the
Information reception and the sound quality of that TV channel.
1) Use ���� keys to highlight { Modify Channel Information } and
press OK.
�� The channel menu appears.
2) Use ���� keys to select one of the options.
{ Name } – You can use the numeric keypad 0-9 to select
the channel preset number which you wish to
change.
– Use ����keys to change alphabet/ number and
use ���� keys to select different entry fi elds, then
press OK to confi rm.
{ Scan Mode } – Select TV channel search mode based on
channel allocation or frequency.
– Use ���� keys to select { Frequency },
{ Channel } or { S-Channel } (Special Channel),
then press OK to confi rm.
{ Frequency } – Shows the frequency of the current TV
channel.
– If required, use ���� keys to start the automatic
frequency search and press OK to confi rm.
{ TV System } – Set the TV system that produces the least
distortion of picture and sound.
– Use ���� keys to select a suitable sound mode,
then press OK to confi rm. (See chapter “TV
System Guide” at the back of this manual for
more information).
{ NICAM } – Turn on or off the digital sound transmission
system which improves the sound quality of the
TV channel.
– Use ���� keys to select { On } or { Off }, then
Dec 12, 2008 | Philips DVDR3380/05 DVD Recorder
Starview the box 2 lost channels
Press menu
type 1570
scroll to nagravision menu and press ok
scroll down to start of line 00
enter codes
press ok to save
scroll back to line 00 under provider code and press right arrow to change to 01
scroll to code line and enter codes
press ok to save
press exit a few times to get back to viewing screen
if you entered the correct codes then your channels should be working.
Hope this helps
Dec 01, 2008 | StarTech.com StarView SV211K 2-port KVM...
DIGITAL/HD CHANNELS
hi there, i have the LG 50in Plasma and just updated the channel connection by doing the following:
1. Make sure your remote is in "TV" mode.
1. Press the Menu button.
2. Highlight "Auto-program" (Should be the first item on the Menu)
3. Scroll over to "To Start" and press OK.
The TV will automatically search for all available analogue, digital and HD signals and may take a few minutes.
Once complete, it will return to the last program you were on and you will find all channels available.
To check the guide or the time, you need to press the "guide" button. Make sure your remote is in "TV" mode. Alternatively, pressing OK at any time shows you the time and channel that you are on.
Hope that helps!
jp
Sep 20, 2008 | LG 50PX4DR 50 in. Plasma TV
Changing channels
mamarabbit-It sounds like you have to autoprogram your tv channels,go into the menu and try to find setup or autoprog.Sometimes if your tv is unplugged for awhile,the plugged in it will automatically start autoprog.Try this out let me know how you make out. cooltek Mar.04/08
Mar 04, 2008 | Protron PLTV-37 37 in. LCD Television
Rca guide plus gold 32'
pull the ac plug for about 5 min and start your set up again paying atention to the features you want and don;t.set the menu to suite your requirements.
Jan 16, 2008 | RCA 32F531T 32" TV
RCA F36649 36" TV Logo
106 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
