Question about HP OfficeJet 7310 All-In-One InkJet Printer
Won't scan nor fax
When I open HP Director, select "Scan Document", I receive an error stating "An error occured communicating withthe scanning device. Please ensure that the scanning device is connected properly and try again". Everything is connected properly and no error lights on. I have even tried to reboot the computer and see if this helps...it does not.
Yesterday I had the exclamation on the front of the printer keep flashing and an error message on the printer screen stating unable to connect to scanner device. Try turning printer off then back on again. This never cleared up the error. So i unplugged the power and USB cable and this seemed to have cleared the error message. Now I have the 1st error message which I mentioned in the beginning of the email. I hav run all of the updates for the HP software but to no avail. I am using windows xp. Would greaty appreciate any assistance you can lend me!
Thank you,
Robin
  • rcal379 Nov 15, 2008
    Go to hp .com they will tell you a code to inter if it doesn't help they will tell you to have it serviced , that is what i'm going to do.Rob
    rcale@sc.rr.com if you have any soluitons
  • lbales Feb 01, 2009
    I am able to fax, but can't scan from either HP Director or from printer. HELP! This isn't the first time it has happened, and previously we had to hire someone to help.
    Problem Solver:
  • 14 Answers
HP multi units are notorious for scanner failures. It is just a weak component in their machines. I have seen this time and time again. The only solution is to change the scanner out or purchase a different machine. Just keep in mind the notoriety HP has which failed scanners. If you want to venture into the replacement of the scanner the following website might have the product you are looking for. Otherwise, search around the net for a scanner assembly unit for the OJ7310. But, be prepared scanner units are not cheap.
Check here first...PrinterFixer.net
Posted on Nov 14, 2008
When I scan a document and choose 'save a copy' to the desktop, it is in pdf format. Instead I need to scan and have jpeg. How do I do this?
  • open hp director (click on the hp director icon) on the computer
  • select the option SCAN PICTURE to automatically set output type to jpeg
  • if that does not work,click on settings on the top,scan settings and preferences,select scan document settings or scan picture settings or the scan preferences menu
  • change output type from there
Jul 27, 2011 | HP PSC 1510 All-In-One InkJet Printer
I have a hp psc 1410 all in one printer and when i starting to scan a document or a picture ,an error message appears that saying an error occurred communicating with the scaning divise. Please ensure that...
Try this simple step first,
Disconnect the Power cord from the back of printer (while printer is on)
Wait for 10 seconds,
Connect the cord back and wait till it initializes.
Close HP Director or HP Solution Center,
Try to Scan, It should work.
Jul 06, 2010 | HP Office Equipment & Supplies
How do you scan a picture?
simply installoffice 2003 and there will be microsoft office tools select microsoft office document scanning select scan new document.....first of all u have to install printer drivers my dear friend
Mar 11, 2010 | HP PSC 1210 All-In-One InkJet Printer
When I touch the Scan Menu button, and choose scan to computer I get a message that states: No Scan Options I have been scanning for a year. This happened suddenly and I can't figure out why
Hi
Thanks for using FixYa. Due to any reason when the HP Communications process fails the HP Scan application won’t work. To resolve the issue you’ll need to follow the procedure as given below---
  1. Force Quit HP Communications (if running)
  2. Force Quit HP Scan (if running)
  3. Turn the printer off
  4. Turn the printer on
  5. Select Scan Picture from the HP Director application
  6. When the HP Scan application complains, press Reset
  7. HP Scan will then hang, but HP Communications will restart
  8. Force Quit HP Scan (again)
  9. Select Scan Picture from the HP Director application (again)
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Nov 28, 2009 | HP Office Equipment & Supplies
HP Scanjet 3570c not scanning
Scanning Without HP Hardware
1. Click Start
2. Control Panel
3. Click Scanners and Cameras
4. Click on the Icon and follow the Scanner and Camera Wizard instructions.
5. Select the HP scanning device from the TWAIN source list
6. Click File and then Scan New .
Feb 08, 2009 | HP ScanJet 3570C Flatbed Scanner
Using hp scanjet 3970 Just loaded hp scanning software and the large install of the 3970 drivers. When I enter the program the scanner opens and scans te image on the tray. (I am trying to scan a...
Have you checked the cord from the scanner lid to the scanner base. if that doesn't work I would try uninstalling the scanner and then reinstalling it. It sounds like a problem with the twain driver for the scanner.
Dec 20, 2008 | Computers & Internet
Scan to computer
Several ways to control your scanner:
From this HP link
Changing scan settings in HP Director
Scan settings include resolution, output type, and file type. These settings can be changed using HP Director.
  1. Open HP Director, if it is not already open:
    • Windows 2000: Click Start , click Programs , point to HP , and then click HP Director .
    • Windows XP: Click Start , click All Programs , point to HP , and then click HP Director .
  2. In the Select Device list, select your product, if it is not already selected.
  3. Click Settings , and then point to Scan Settings & Preferences .
  4. Click the scan setting menu that corresponds to the type of file you are scanning.
    • Scan picture settings : Designed for scanning pictures, including any type of non-text image, such as a drawing, logo, or photograph
    • Scan document settings : Designed for scanning documents
    • Scan preferences : Control scanning preferences, such as automatically straightening crooked images
    • Button settings and Scan to... setup : Control the defaults for the scanner buttons on the control panel of the product
    After selecting the appropriate menu, the corresponding window opens.
  5. Change settings as appropriate, and then click OK . The scan setting window closes.
  6. Click Scan Picture or Scan Document HP Director to scan with the changed settings.
From this HP link
Using the Advanced Scanning Features of the HP Solution Center Softwaretoo large to paste - just follow the link above :)
Here the main site for the scanner - click here
Nov 18, 2008 | HP Office Equipment & Supplies
Connection issue between XP Pro and HP C6180 all-in-one
Hi Lynn,
Unfortunately, HP.com doesn't have a very satisfying online solution to your problem. Still, there are a few things you can try.
The first is a general diagnostic check of your scanner. HP provides a doc that takes you through some steps, many of which you probably already tried, to see if it's a simple fix:
An error occurred while communicating with scanning device
The next document is a set of diagnostic steps to address errors trying to scan to a PDF:
An error occurred while trying to scan to a PDF
I don't know if the current situation was created by a fault in the device or some recent change in your configuration settings. I do know you can use the HP Director software installed on your computer to set the scan destination settings:
Settting "Scan To" Destination using HP Director
Those were the most relevant solutions I could find for you. I hope some of this information is helpful. Good luck.
-Trip
Oct 07, 2008 | HP Photosmart C6180 All-In-One InkJet...
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
HP OfficeJet 7310 All-In-One InkJet Printer Logo
406 people viewed this question
Ben Johnson
