Question about RCA D52W19 52" Rear Projection Television
Takes several minutes to come on
I have a 52" RCA HDTV. When it was working right, I would push the power button on the remote, and the power light on the tv would come on and flicker for a few seconds, and the tv would come on.
Now, when I push the power button, either on the tv, or the remote, the power light will flicker like it should, then go out for a few seconds, the power light will come back on for a couple of seconds, go out again, then come on again for a few seconds, go out, and not come on again, and the tv does not power up.
I push the power button again, and it goes thru the same sequence without the tv powering up.
I do this several times, and the tv will finally come on, but it will have the rolling screen for the first 5-10sec, then everything normal.
After the tv has been on a while, and I turn it off, I can hit the power button, and it powers right up.
Any ideas? Can I fix it myself, or is it time for a new tv?
  • airhopper1 Nov 18, 2008
    Did you find a Fix? I have been in iraq came home yesterday and my TV is doing the exact ting. It finally powered up.. This tv has been a great tv these last 3 and a half years.
  • saar Nov 21, 2008
    I am having the same problem not sure what else to add. I have just been leaving it on if I can get it to work. Not exactly a solution
    Genius:
  • 2,920 Answers
Time for a new tv
Posted on Nov 15, 2008
SOURCE: RCA D52W20 52 in. Rear projection hdtv problems
lighty comes on three times no picture no sound
Posted on Nov 30, 2008
  • 1030 Answers
SOURCE: RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Posted on Apr 04, 2009
  • 1043 Answers
SOURCE: my rca 52'' flat screen tv
It sounds like your TV needs to be aligned. There should be a menu item in your setup menu called "Alignment". Once you choose this the system will either automatically align itself, or the screen will display a graphic that will allow you to align the guns manually. Normally you will move either up or down or side to side until 2 separate lines look like one.
Posted on Jul 14, 2009
Sparko1
  • 167 Answers
SOURCE: Looking for Replacement screen For 52" RCA Projection HDTV
You should call a few TV Repair shops. They will have a few of these TV's junked for parts. They will sell you a screen for cheap.
Posted on Jul 31, 2009
  • 6 Answers
SOURCE: 52" hdtv rca hd52w67
check that board where you replace the fuse on the back look very close at the transformer the big black one and check the soldering it is cracked resolder it and you should be ready to go.. just look very close they are smalllllll cracks need good light.. thats what i had on mine and works good..
Posted on Apr 17, 2010
My 52 in.rca rear projection hdtv tv . i have a hard time turning it on. i keep pushing the power on the remote and tv it will come on and turn off 3 times. i stuggle with it for about ten minutes. then...
no its most likely failed power caps CP150, CP120 and CP114 capacitors on the deflection board are the usual cause of that symptom. You can get the RCA repair kit by the same name from www.tvrepairworld.com under the RCA repair kits category.
Sep 04, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
My 52 rca hdtv takes a while to turn on.. I push the power button a view times to turn on. sometimes it takes 20-30min to turn on. whats wrong with the tv, and is this an easy fix..
Depending on the model of the TV some projection TVs have a soldering problem. There could be a short on the Main Power Supply. It maybe necessary for a professional to do this work if you don't have the tools or if is not soldering issue.
Apr 30, 2010 | RCA D52W19 52" Rear Projection Television
I have a 52 inch projection TV that takes several attempts to turn on. When it first started having problems, it would turn on after puching the on button about 3 times. Now you have to cycle through about...
Thats the same model as the RCA ITC222 chassis . You can get the CP150, CP114 and CP120 repair kit at www.tvrepairworld.com which should solve that issue. The kit contains the parts and the CD with instructions.
Sep 30, 2009 | GE D52GW12 52" Rear Projection HDTV-Ready...
My RCA HDTV D52W23 Will not Turn On!!
Trying installing a new power supply. This is the main problem with tv's with the issue. But if you just bought it I would try to get my money back from where I bought it from. Installing a power supply for a tv is not that hard at all.
Sep 03, 2009 | RCA D52W23 52" HDTV CRT TV
Rca 52 inch power light comes on no pic.,shuts off makes noise
I think you have a shorted hori output Transistor NTE2324 if it makes a low squealing sound also ck capacitor 114,120,150 if 150 is puffed up on top it is bad 2200uf 16v use 25v and other 2 are 220uf 35v.
Apr 06, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button to tv
i have a friend who has this tv and the same problem. i called a repair shop abd i was told it is the high voltage converter. $400 to pick up drop off and repair.
Feb 23, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca hdtv d52 w14 no power remote or manualy push button and green light flickers but thats all. tv was recently moved in the back of atruck so it was jared somewhat in transporting as i was working on tv...
i have a 52" 2004 RCA model and the power light comes on but the immediately shut off same thing if we unplug and replug what's the matter foot ball season is coming and i don't want to miss it
Jul 28, 2008 | Televison & Video
RCA D52W19 52" Rear Projection Television Logo
225 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
