SOURCE: Maxtor OneTouch III Mini Edition 80 GB - one touch button not working
Instal cd with maxtor programs on comp.
SOURCE: Where do I fund a manual, guide, instructions for use
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/installation_guides/onetouch_iii_mini_win_mac.pdf
SOURCE: maxtor one touch 4 mini 250GB hard drive beeping
I had the same problem and the Maxtor/Seagate website did not have any solutions. I finally got in touch with Tech Support and got a fix. I was using it with a Dell tower and plugging into a USB port in the front. I also was using an after market cable.
I learned the Maxtor is a power hog and beeps and shuts down when it is not getting enough power. I did not know but the USB ports on the front of a desktop/tower computer do not provide as much power as a port on the back (the back ports are sometimes directly connected to the motherboard). I got a USB extension cable and connected it to a USB port in the back and it solved the problem.
I also learned that most laptop USB ports are not powerful enough to run the Maxtor. Mine would also not work if you attempt to share it by using an unpowered USB hub. I have gotten it to work with a powered desktop USB hub (Belkin).
I believe that this may explain why you get a "Y" cable with the drive. I could not find an explaination for the cable or how to use. There may be an accessory to purchase that attached to the cable and powers it.
SOURCE: I have a Maxtor one touch 4 mini. I plug into
There are a few reasons this would happen, The options are a faulty driver in your PC, a failed circuit board in the enclosure or a failed circuit in the drive itself.
First try the drive on a different PC and see if it works. If it does reply back and we can look into the failed driver. If it doesn't then take it to your local PC shop and have the technicians move the hard drive into a new enclosure.
If it works in the new enclosure buy the enclosure and your on the way. If it doesn't, then the hard drive itself is the problem. If that is the case you will need the help of a data recovery pro to retrieve your data. If this is the case reply with your location(Country, State and City) and I will assist you in finding a reputable pro to assist you.
Hope this helps FixYa,
Chris
SOURCE: Can't open Maxtor one touch 4 mini
If the external hard disks is plugged to a USB port and is not detected anymore, try uninstalling the USB Root Hub devices in the device manager. They will automatically be reinstalled on reboot and that can help fix detection issues.
But did you look in the Disk Management module of Windows to see if the disk is there? Right-click My Computer and select Manage.
