Question about Xerox WorkCentre XE88 Laser Printer
No image printing
I was about to dispose of this printer, but wanted to see if the problem was perhaps a resolvable maintenance issue. The printer installs and runs with no error codes, but no image is produced. This doesn't seem to be a toner problem as there is no "low toner" light. The mechanisms seem to be fully operational and it seems to run smoothly, just no image. Is there a part that may fix this issue? Thanks in advance for any responses. I hope this question isn't too vague.
  • Jeff Brazzell Nov 19, 2006
    The paper comes out very warm.
  • 47 Answers
Hi jcbrazz, First question, does the paper come out hot?
Posted on Nov 17, 2006
  • The Dude
    The Dude Nov 21, 2006
    Ok then it's not the fuser. (the fuser "sets" or "fixes" the print on the paper by melting the toner into the paper at about 600 degrees F)
    After rereading your post, it sounds like you're more interested in figuring out if it IS fixable and if it's worth fixing than how to actually fix the unit. Is that right?
    Most problems on most laser printers ARE fixable. New laser printers ARE getting cheaper so deciding if it's worth it or not depends on how old the unit is and the cost of repair vs buying a new one.
    Chances are your problem is the transfer corona wire.
    The transfer corona wire transfers the toner from the drum to the paper by passing a static charge to (or through really) the paper. The toner, which has an opposite static charge, jumps from the drum to the paper. If the corona wire is bad or broken (or the high voltage power supply that powers the wire is bad) the toner never moves to the paper and you get blank pages.
    There are a few other possible problems, like the HV power supply I mentioned or the engine controller, laser shutter, beam mirror...most things are replaceable.
    BTW the FIRST thing I would recommend is changing the toner cart. You could be out of toner or the toner may have lost it's static charge. At the very least remove the cartridge and shake it up to distribute the toner in the cartridge. (and remember just because you hear or feel toner shaking around in the cart does NOT mean it's _not_ out of toner. "dead" toner collects in a special area in the cartridge after excess is cleaned off the drum.)
    Dude
Z6100 banding verticle in black
When you banding vertical do you mean Across paper feed direction OR With paper feed direction?
If its across the feed direction the chances are thje issue remains with the individual printhead, Print out a quality maintenance print to find which Printhead is not working as well as wanted, then replace ( or clean using the plotters control panel under image maintenance.
Errors along the feed direction can be down to Software/ Main Pca /
Mar 11, 2014 | HP DesignJet Z6100 Wide Format InkJet...
Text prints fine. However images are printed smeared. It looks like each image has a mirrored shadow. How can I fix this?
Fist set for default settings, calibrate color.. it will resolve the issue ..even its remin service involment must..
Sep 11, 2011 | HP Color LaserJet 2600n Printer
I would like to perform a few regular maintenace jobs with my HP Deskjet 6940; however, without a current manual (O/S is Windows 7 32-bit) I have no idea what the "toolbox" is that is referred to...
1. Turn on your computer, wait for it to boot up, then turn on your printer and load with paper.
2. Locate the " HP Imaging Director " icon on your computer, it would have been added to your
monitor screen when the printer was installed.
3. Double click this icon and a screen will appear showing the functions available on your
printer.
4. Click on the " Settings " heading, scroll down to "print settings" and over to "printer toolbox".
5. Click on "printer toolbox" and you will be taken to the maintenance window.
6. From this window, choose what you want to do.
Feb 28, 2011 | HP Deskjet 6940 InkJet Printer
When it prints there are many lines missing and unprinted can you advice please how to resolve this issue?
This issues looking printer head problem. check the following Steps for cleaning printer head :
Click on the Start button if you have Windows XP. If you have Windows Vista, click the Windows icon that resides in the lower left corner of your computer screen.
Click on "Control Panel," then "Printers and Other Hardware." Finally click on "View Installed Printers or Fax Printers."
Right-click on the name of your printer and choose "Printing Preferences." This should open a new window; next look for a tab or button marked Maintenance, or something similar.
Find the button that says "Print heads" or "Clean the Print heads" and click on it. You may be asked to choose which print heads; choose them all if you are. Make sure there is paper and ink in your printer, and that it is turned on ahead of time.
Take out the page your printer has printed and see if there are any grids or boxes missing. If there aren't, then you can just exit the program--your print heads are not clogged. If there are grids missing, then click on the "Cleaning" or similarly worded button.
Once the cleaning process has completed, print another page to be sure that your print heads are no longer clogged. If they are still clogged, repeat Steps 1-5 until your printer is printing clearly.
Dec 29, 2010 | Epson Stylus CX5000 InkJet Photo Printer
Kodak esp7 wont print black
Click on menu on the printer,scroll down and choose clean printhead or go to maintenance and then click on clean printhead .After that try to print. If issue persists,call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad
Sep 28, 2009 | Kodak ESP 5 Printer
Won't print envelopes
Please have a look at the manual for your printer here, consult page 31 and make sure you have followed the instructions for setting up the Printer Properties(driver) for your OS. (pg 21).
It may be necessary for you to update the printer drivers on your system to get the machine to print correctly. You can download the latest drivers from HP here.
If this info doesn't resolve your issue, have a look at other similar posts in the HP forums here, and perhaps you will find a solution, but I'm guessing you haven't configured the printer properties correctly.
There is also a problemsolving guide in the manual online that may help you with step by step instructions if you want to troubleshoot the issue from your side.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 23, 2009 | HP LaserJet 1012 Printer
Iron on transfers
what you want is called mirror image. It's on teh layout tab in your print settings (see here)
User manual for your printer here.
Jun 26, 2009 | HP DeskJet 5550 InkJet Printer
Printing in Mirror image
It's likely that you have an old outdated printer driver for your L7590 as this has been a long "known" issue with the L7000 series of MFD's.
To resolve the issue properly you need to uninstall the current driver version and then download the latest version of the software that isn't just driver/basic based.
You can extract the source files including the drivers folder using 7zip if you want to try and avoid installing all the additional bloat that comes with these printers.
Failing that, you need to define alternative quick settings to take over from duplex (two-sided) printing as this appears to have been incorrectly set to use mirror printing. Other quick settings have been implicated as well but the driver update should resolve all of them.
In some instances the driver update doesn't apply properly so you may need to uninstall and reinstall more than once... Remember to delete your printer from the printer listings and unplug it from the USB cable before you uninstall and reinstall to get it to work properly.
Hope this helps.
Martin
May 27, 2009 | HP Officejet Pro L7680 All-In-One Printer
Stripes on Images only - Text OK
Perhaps the CMY color heads need alignment. If you have not already done so, run a head alignment from the driver maintenance section. It will print out a page containing several lines and text, and request you select the closest-aligned images. After this is done, do another image print to check for improvements.
Normally, the printer uses the black cartridge for text and the CMY inks for images (even for black on photo and specialty paper). So when you are printing normal text pages on plain paper, only the black ink is used. A good check for this would be to print a normal text page, but select photo paper in the driver to trick the printer into using the CMY inks to make a substitute black text page. If this looks ok, then you are having issues other than cartridge alignment.
May 24, 2008 | Canon BubbleJet i560 InkJet Printer
Xerox WorkCentre XE88 Laser Printer Logo
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
quennie732
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
