Question about Kenwood Audio Players & Recorders
My Kenwood UD301 Hifi, disc player(X-3B) sometimes does not read disc when in. Does this alot. Where can I source spare laser and optics for system?
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: Kenwood RXD25 CD player intermitent??
Hi jenoss
Sounds like the unit has either a failing load belt to the cd drawer mechanism,not allowing the transport to fully load the cd. Give the unit a gentle tap just after the drawer closes and see if it resolves the problem.
OR a faulty spindle motor, you will have to take the lid off and after pressing play, give the disc a gentle "kickstart". If it then begins to run, then the motor is the problem.
If you find it is neither of these, get back to me here and I we shall go further
regards
Graeme
Posted on Mar 16, 2008
tech48
  • 624 Answers
SOURCE: Replacement unit for hifi player
I work at a service center in the U.S. and I have a lot of trouble getting any Phillips parts. My service center has given up on Phillips, we have had too many problems with them. Sorry to give you this bad news. You might want to look on ebay for one with a disc loading problem or some other problem not related to the cd player. Sometimes you can find them cheap. The laser would cost you in the range of $50 to $75 US if you can find one.
Good luck,
Dave
Posted on Jul 01, 2008
issy2
  • 460 Answers
SOURCE: Ive got a kenwood hi-fi
what did u mean by cd's jumping... is it physically jumping.. or is it skipping ...?
Mostly it wud be the wear and tear of the rubber inside.. rubber inside in the sense the motor's belt..
Posted on Sep 16, 2008
  • 4234 Answers
SOURCE: i have installed a new
Laser assemblies are shipped with a shorting solder bubble. Did you remove it before installation? If not, then the laser is effectively disabled and won't read anything.
Dan
Posted on Oct 01, 2008
Connect tv to hifi speakers
It doesn't lokk like your TV has an analog out for your Kenwood system. It might have an optical out but unless the Kenwood has optical in then you'll need to upgrade to a Home theater system with HDMI.
Feb 03, 2015 | Samsung Televison & Video
What does utoc error mean on a Kenwood mini disc player
Well, what it means is
TOC errors often mean the recording head/optical block is cooked. A cleaner might work, but often it's the end of the MDR.
Are you sure the battery is correctly (fully) charged? Try removing the battery and running on (only) the charger.
try cleaning the lens with a minidisc lens cleaner.
open the unit and check the laser position - it should be all the way to the left. that's where it should start to read the disk.
Read these:
https://groups.google.com/forum/#!topic/alt.audio.minidisc/63uCBegyG8A
http://www.minidisc.org/repair_q2.html
http://forums.sonyinsider.com/topic/21439-fun-with-the-sharp-702-utoc-error-fixed/
http://www.mazdas247.com/forum/showthread.php?98358-TOC-Error-on-brand-new-disc!
http://www.borus.de/minidisc/303.htm
Jul 07, 2014 | Sharp MD-MS702 Personal MiniDisc Player
What cables do i need to connect to a t.v. to get surround sound please
It depends what the source of the sound is. If you are using a dvd player or hifi/dvd combo that has surround, dobly pro logic, surround simulation or cinema sound...it will have HDMI, Optical, Digital outputs. The newer items use the HDMI to send Audio and Visual signals to the Hifi. If not...you will either have to do the simulation on your hifi if it has that feature. You can also use the SPDiF or Optical cable from your source to the hifi. If all that is missing...the standard 3-way RCA cable (Yellow,Red and Black) will do where yellow is video and the red and black is the stereo source of sound.
Apr 24, 2014 | Technics SC-DV290 System
CD player will not read disks
The problem is in the laser pickup assembly, over time the laser becomes weaker until it can no longer read the disc, the whole assembly must be replaced since individual parts are not an option, but first! buy a CD cleaning kit and follow the instructions, sometimes this will give more life to the player.
Mar 10, 2012 | Kenwood XD-655 CD Shelf System
When I insert myDVD disc, the screen shows loading for a minute or so--then reads incorrect disc and bad on the player. This is a disc I have used before and has the label that shows it is the disc this...
It seems that optical laser block gets fail to read data on disc and possible cause could be dirty/ clogged lens or optical laser block failure.
Put lens cleaning disc in unit to clean optical lens and check DVD playback, if that does not solve the issue then optical laser block would be defective and requires replacement that would cost approx new player price.
Hope these info will help.
Thanks.
Jun 29, 2011 | Toshiba SD-K220S DVD/CD Player w/Built-in...
I have a kenwood dvd player
Are you sure it´s the laser the problem?
Because sometimes the motor disc spindle are the guilty of the failure of the dvd.Good luck
Jun 12, 2009 | Kenwood DV-505 Multi-disc DVD Player
Sony hifi wont play cd's
Optical lens requires cleaning.
Please put cd cleaner in tray and check if it cleans dirt on lens. Still same problem, then unplug unit from AC outlet, take off top cover of hifi system and clean lens with good quality cotton bud. hope this will resolve problem.
Jan 26, 2009 | Audio Players & Recorders
Good luck,
Dave
Jun 26, 2008 | Audio Players & Recorders
70 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
