Question about HP Photosmart C6180 All-In-One InkJet Printer
Hello iam using hp printer cC6180 All-in one and i having ink system erroor 0xc18a0001 so i cannot print or copy and i need a help thanks
I believe I had the same problem at one time. Just by memory---I think I had to disconnect whole printer from power source--let sit about 10 minutes and then when I started back up---it took forever to reset, but then worked.
If that doens't do it, try to read the troubleshooting in the manual or do more research via online. But I believe I figured that out via the printer website under troubleshooting or FAQ.
Posted on Nov 15, 2008
Error Oxc 18a00001
you may need another print head with that error code message. I would contact HP Total Care (1800-474-6836) and check to see if your printer or print head is in warranty, and it could be replaced.
Error 0xc18a0001
Jan 20, 2016 | HP Photosmart D7260 Printer
ERROR 0xc18a0001 Ink system has failed Quite new
Try the link below. This error is related to air in the lines between the print head and the cartridges. It is quite common and HP are very aware of this.
I hope this helps. Regards GM
Apr 16, 2011 | HP Photosmart D7360 All-In-One InkJet...
Ink system failure
This is a very common problem if you use refilled cartridges or let your ink run really low. The "Ink System Failure" error is causes by air in the ink feed tubes. We have a step by step guide purging the air from the feed tubes posted on our web site. Go to our site at: , click on the printer repair link and then the HP link. Follow the steps and you should be back printing in no time at all.
I hope this helps, If so please rate our solution.
Corporate Computer
Jan 05, 2010 | HP Photosmart C5180 All-In-One InkJet...
ERROR 0XC18A0001
Press the On button to turn off the printer.
Unplug the power cord and universal serial bus (USB) cable from the back of the printer.
Wait for 30 seconds.
Plug the power cord back into the printer.
Press the On button to turn the printer on.
If Ink system failure does not display, the issue is resolved; reconnect the USB cable and resume using the printer.
If the previous steps have not cleared the message, let us update the printer Firmware and check.
Please click on the below provided web link :
Once you open that web link, please follow the steps provided below :
Installation Instructions
1. Disconnect all other USB devices from the PC.
2. With the HP Photosmart 8250 series printer directly connected to the PC, click on "FirmwareEnable_Release.EXE"
3. If the ink system failure condition returns contact HP to service the printer.
Note: Do not use this patch if there is any visible ink around the product. In this case contact HP to service the printer.
This should resolve the issue.
Good Luck!!
May 06, 2009 | Office Equipment & Supplies
HP Photosmart C6100 All-in-one Series
I want to print a 4 x 6 inch photo on the 4 x 6 inch photo paper but not using my memory card. I no longer have what I want on the memory card but I have a copy of the photo I want to print in a computer file. How can I get it to be pinted on the 4 x 6 paper rather than printing on an 8 1/2 x 11 page and having to cut it out.
Jun 20, 2008 | HP Photosmart 8250 InkJet Printer
HP Photosmart D7460 problem
*** Fix your HP Photosmart D7360 (Reset Code/Master Reset) ***
1- Turn off power and unplug from power source.
2- Open right side of printer (looking at the front).
3- Disconnect,by pulling gently, both white flat ribbon cables off the main circuit board.
4- Plug in power source and turn printer on. Wait till you get a error message and push "Ok".
5- Unplug power source.
6- Reconnect the flat ribbon cables by aligning and carefully pushing into the conectors on the main circuit board.
7- Plug in power source and turn printer on (Printer preparing occurred).
8- voila, the nasty error message 0xc18a0001 "Ink System has Failed" is now gone.
May 15, 2008 | HP Photosmart D7460 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
164 people viewed this question
Ben Johnson
