Question about Poulan Pro Chain Saw 46cc 20"
Chainsaw How does a sprocket spin?
  • Allen Neal
    Allen Neal May 11, 2010
    NEED TO KNOW MORE ABOUT WHAT YOU ARE ASKING
  • 211 Answers
Hi
with the holes towards you.
regards savumihai71
Posted on Dec 02, 2008
WEN 6014: Motor is running, but chain doesn't move. Chain sprocket seems fine, cogs are only slightly worn, sprocket fits perfectly, no wear. Is there an internal clutch or connector? Motor worn out?
There is a clutch behind the metal housing where the chain sprocket at the engine end attaches to the chain . There are wear parts with springs on them that have to be changed. ChainSaw Shed Chain Saw Parts for Wen Wagner Brand Chain Saws Chains Bars... You can get parts here.
Sep 15, 2016 | Garden
3003 008 8921 will start but the chain will not spin.
1. Check that the sprocket on the bar tip actually turnas and is free from obstruction.
2. Check chain tension is not too tight.
3. Check that you have taken the chain brake off. (pull the front hand guard back until it clicks)
4. If you have checked all the above, check the clutch.
May 05, 2013 | Stihl 3003 008 8921 Rollomatic E Laminated...
Chain on partner 370 chainsaw is permanently engaged so when I start it it is spinning. I think it may be a clutch problem?
Iether the clutch spring has broken, or become weak, or simply the sprocket bearing is dry and need greasing, either way you need to remove the clutch and sprocket, there is a special tool to remove the clutch part no. 530031112, this is a pin spanner that fits into the two cut a ways in the clutch centre so as to jar it off against compression with a 19mm spanner.
Oct 29, 2011 | Garden
Poulan chain saw how to get old chain drive sprocket off.
You'll have to stop the crankshaft from moving. The easiest way to do this is to take the spark plug out, pull the starter rope out a little ways, and stuff some of it into the spark plug hole. Spin the sprocket until it stops turning, that will put the piston at the top where it can't pass TDC and stops the crank. Turn the sprocket until it comes off then put your new one on.
Aug 09, 2011 | Poulan 14" Chainsaw
How does the clutch come off to change the sprocket?
the clutch unscrews from the crankshaft,typically they are left hand thread,check to see what rotion the engine has it spins off in the direction the engine spins
Dec 30, 2010 | Husqvarna Garden
What is a needle bearing in a stihl chainsaw and what does it do
http://www.ecrater.com/p/6962460/024-026-stihl-325-sprocket-w-needle-cage-38076-2?keywords=stihl%20caged%20needle%20bearingthis bearing(on the right) fits inside the sprocket (on the left)allowing minimal friction. Without it, the sprocket spins so fast it would melt all the plastic around the sprocket(seen it)
Oct 07, 2010 | Husqvarna Chain Saw 20" Bar
Have a Stihl 310 chainsaw and the sprocket will not spin freely. Can't turn it by hand, so I removed the e-clip but can't get the sprocket to come off. Any suggestions
Grasp the forward most upper handle and pull it aft. I t may require some additional force at the rear extreme when you disengage and latch the chain brake.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 21, 2010 | Garden
My electric chainsaw used to carve ice, chain stops while motor still spins when cutting ice
Is there some form of tensioner for the chain or do you believe it's the drive sprocket?Gas chainsaws have a bolt you can tighten which takes up the play in the chain.The drive sprocket is either on a key-way or clutch.I would remove the chain and check the drive sprocket.There must be a clutch to allow the motor to free spin until a given RPM would drive the chain.That clutch is suspect.You didn't give any information(make or model of chainsaw)that I could use to search for an answer for you.Try to work on that clutch,re-post if you need more help.
Jan 13, 2010 | Garden
Poulan Pro Chain Saw 46cc 20" Logo
23 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
