Question about Apple iPod touch
MITONE MITMP22 4GB
I have bought an MP4 player MITONE MITMP22 4GB serial number 2240019 0022. I plug in to my pc and automatically starts Adobe Photo Shop and recogized the device as H. When I try to find the device in MY PC as H I can not find it, so I con not copy file from my PC to the device.
Please help me and send me new drivers for Windows XP Professional English edition.
Looking forward to hearing from you soon my kind regards.
Gian Luca Babando
  • Anonymous Jan 17, 2009
    ho comprato in dicembre 08 un mitone mitmp22, ma รจ stato fornito con window 98, sistema ormai obsoleto e inesistente.. come posso fare? grazie
  • 11 Answers
SOURCE: USB Device Not Recognized/Unknown Device
  1. You will have to update iTunes.
  2. And check your USB.
Posted on Nov 29, 2007
  • 77 Answers
SOURCE: format error
what type of mp4 player is it, and what type of files are you trying to upload?
Posted on Jan 30, 2008
cropp
  • 377 Answers
SOURCE: HELP WITH MY MP3/MP4 PLAYER!PLEASE
hi dear
going here
http://3d2f.com/tags/mp3/rocket/
http://www.mp3rocket.com/indexcb.htm?hop=hiwelcome
oke
Posted on Mar 22, 2008
SOURCE: ipod is disabled connect to itunes
Go on to itunes and plug your mp3 in to your computer
and download it and salect which tunes you want. If it dose not work
there is somethind wrong whith your mp3
Posted on Aug 19, 2009
hunter19_46m
  • 7482 Answers
SOURCE: INSTRUCTION MANUAL FOR 32GB TOUCH SCREEN MP3/MP4 VIDEO
Go to this website and download a pdf user manual for your Itouch. I hope this helped, Please rate me...Thanks
http://manuals.info.apple.com/en_US/iPod_touch_Features_Guide.pdf
Posted on Jan 03, 2010
Testimonial: "Very helpful. Thanks very much"
Sir i have given serial code 1045-1090-6246-8353-3166-2968 in photo shop but it was showing to give authorazation code PH-9038836613
After entering the serial code of your adobe photo shop, another set of numbers will automatically be displayed at the lower installation box. copy and past it at the autorization code box. Have a nice day and hoping this would solve your problem my friend.
Aug 18, 2011 | Adobe Computers & Internet
I have mitone mp4 player (MITMP26) 4 GB . I have a problem. USB device don't see my computer. Windows 7 64 bit. Please help me.
Hi, player not recognized by the computer
This may be caused by one of the following:
1. Minimum system requirements were not met.
2. Corrupted drivers.
3. Computer restrictions.
4. Power issue.
To resolve this issue, try the following solutions:
SOLUTION 1 - For brand new player or first time connecting to this computer.
For Windows XP users: verify the following operating system requirements are met.
- Windows XP SP2 or higher
- Windows Media Player 10 or higher
Download and install the latest Windows Media Player if it's not installed.
For Windows Vista users: If the player is seen in My Computer when using MTP mode, but not showing in Windows Media Player.
- Download the hotfix from http://support.microsoft.com/kb/939211.
- Run the hotfix.
For MAC users, see Sansa player not recognized by a MAC OS
NOTE: If you are trying to connect to a Computer at work that is part of a network, there may be user right restrictions that are set to disable access to new hardware or stop any program installations. You may need to check with your IT administrator to see if this is causing the problem.
SOLUTION 2 - Refresh the driver
STEP 1 - Connect the Sansa player to the PC
The screen on your player should turn on, show 'Connected' and indicate the battery charging or full.
- If the player does not turn on try other USB ports or on another computer if one is readily available. Ensure you are connecting directly to the computer USB port and not to a USB hub.
- If there is nothing showing on the screen and the player does show up in as a storage device in an explorer window, then the screen is just not working.
If you receive the error "USB Device Not Recognized" on the computer, the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
STEP 2 - Check under Device Manager
1. Right-click My Computer, and select Manage.
2. Click Device Manager on the left pane.
NOTE: Sansa MP3 Players can connect to your computer in MSC or MTP mode. Exceptions are mitone mp4 player Connect and mitone mp4 player Express which only use MTP mode. MTP mode is the recommended and default method for mitone mp4 player Players when used with Windows OS.
The mitone mp4 player player will show up on Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode)
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers.
STEP 3 - Refresh the drivers
1. Right-click the entry with the error mark, select Uninstall.
2. On the top menu, click Action then select Scan for hardware changes.
NOTE: If a device with yellow exclamation point (!) continually appears and disappears, then the player is most likely failed. Additional troubleshooting is unlikely to correct the problem.
SOLUTION 3 - Connect using MSC mode
Connecting in MSC mode will help determine if there is a problem with MTP mode or with the Auto Detect mode feature of the player. You can use Forced MSC mode or switch the player settings to MSC.
If the player is detected in MSC mode but not when set to MTP mode, try to update or reinstall the mitone mp4 player firmware
NOTE: mitone mp4 player Express and mitone mp4 player Connect do not have MSC mode. For mitone mp4 player Connect you can try reinstalling the firmware using the Connect Recovery Mode.
Additional troubleshooting notes:
If you have replaced the mitone mp4 player Player and you still have problems getting it to recognize in the computer, then you may need to try some additional troubleshooting.
- Try connecting on another computer.
- Try using a different USB cable
- Try connecting to the back USB ports which may supply better power.
- If only MTP mode is not working, try reinstalling Windows Media Player
For Windows XP try also download and install the MTP Porting Kit.
Hope that helped And please don't forget to rate me..
Have a nice day....
Feb 19, 2011 | Audio Players & Recorders
Mitone Mitac100 S/No : Mitac 100 BK 00174, purchased at Frankfurt International Airport Taxfree zone on 19 november 2010 with 2 year worldwide guarantee. Connected to my Hi-Fi system but never...
hi there, i also bought my MiTone MP4 player from Frankfurt Airport, and definitely it was the worst product i have ever purchased, from the first day i was defected, it was blinking power ON/OFF as i touch it, i had to keep it fixed beside me to keep it working, after repairing it, i found out it is not charging the battery...
Dec 29, 2010 | Audio Players & Recorders
Serial number for Adobe Photo shop 7.0
6177-3566-2217-3247-0203-1045
1045-0203-3247-2217-3566-6177
Jul 23, 2009 | Adobe Photoshop 7.0 for PC
I have mitone mitmp25 mp4 player When i connect it to pc, it shows 3 folders sls.dir playlist & mic.dir Where ould i copy mp4 files in thesefolders? I tried copying in every folder but the player...
Mitone MITMP25 plays only videos in MTV format, so you should use the software included to convert all videos into MTV format before you can play those. See page 21 in user manual :-)
Jul 02, 2009 | Yifang Digital Easy Mp3 EM01 MP3 Player
Mitone MP4 Player 4GB MITMP22 - software disck empty
MITONE MITMP22 4GB MEDIA PLAYER PLAYS RMVB FILES
TO CONVERT TO RMVB FILE USE WIN AVI (AVI TO RMVB)
ONCE YOU HAVE THE WIN AVI PROGRAMME THEN YOU WILL NEED THIS EXTENSION FILE (HelixSDK0715 win avi rm extention file) AND CHOOSE THE SIZE OF FILE TO SUIT YOUR SELF IN ADVANCED ONCE YOU HAVE SELECTED RM
Feb 16, 2009 | Kenwood KDC-MP4028 CD Player
MP3
I bought a MITONE FLASH MP4 DIGITAL PLAYER. I am downloading files from internet sites in mp3 format but am not managing to listen to them on my Mitone though it seems to be playing them. maybe i dont know how to use it yet. any suggestions please?
Jul 29, 2008 | Sony Write-Once Recordable, 30 spindle...
Adobe Photo Shop 7.0 Serial Number for Down load
you have to pay Adobe about £550 and thay will supply it to you
Jun 25, 2008 | Adobe Photoshop 7.0 for PC
Apple iPod touch Logo
238 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
