I WANT TO KNOW ABOUT HLOOKUP IN MS EXCEL. - Computers & Internet
  • 57 Answers
HLOOKUP is an excel function to lookup the horizontal row value you specify.
Posted on Nov 18, 2008
What is vlook up & what is hlook up?
The VLOOKUP and HLOOKUP functions contain an argument called range_lookup that allows you to find an exact match to your lookup value without sorting the lookup table
I have posted below link to know more .Please have a look..
http://www.howtodothings.com/computers-internet/how-to-use-the-vlookup-and-hlookup-functions-in-microsoft-excel
http://support.microsoft.com/kb/181213
http://office.microsoft.com/en-us/excel-help/vlookup-HP005209335.aspx
http://www.timeatlas.com/5_minute_tips/general/learning_vlookup_in_excel
Please rate & vote if you like soution..
Thanks
Sandeep
Mar 14, 2011 | Microsoft Excel for PC
Hello i want to use h LOOK UP
Hi !!
How to implement Hlookup function:
  • Select your data and sort it in ascending order
  • Then type '=HLOOKUP(lookup_value,table_array,row_index_num,range_lookup)'.
    Lookup_value is the value to be found in the first row of the table. Lookup_value can be a value, a reference, or a text string. Table_array is a table of information in which data is looked up. Use a reference to a range or a range name. The values in the first row of table_array can be text, numbers, or logical values. If range_lookup is TRUE, the values in the first row of table_array must be placed in ascending order: ...-2, -1, 0, 1, 2,... , A-Z, FALSE, TRUE; otherwise, HLOOKUP may not give the correct value.
    If range_lookup is FALSE, table_array does not need to be sorted. Uppercase and lowercase text are equivalent. You can put values in ascending order, left to right, by selecting the values and then clicking Sort on the Data menu. Click Options in the sort dialog box, click Sort left to right, and then click OK. Under Sort by, click the row in the list, and then click Ascending.
    Row_index_num is the row number in table_array from which the matching value will be returned. A row_index_num of 1 returns the first row value in table_array, a row_index_num of 2 returns the second row value in table_array, and so on. If row_index_num is less than 1, HLOOKUP returns the #VALUE! error value; if row_index_num is greater than the number of rows on table_array, HLOOKUP returns the #REF! error value.
    Range_lookup is a logical value that specifies whether you want HLOOKUP to find an exact match or an approximate match. If TRUE or omitted, an approximate match is returned. In other words, if an exact match is not found, the next largest value that is less than lookup_value is returned. If FALSE, HLOOKUP will find an exact match. If one is not found, the error value #N/A is returned.
  • If HLOOKUP can't find lookup_value, and range_lookup is TRUE, it uses the largest value that is less than lookup_value.
  • If lookup_value is smaller than the smallest value in the first row of table_array, HLOOKUP returns the #N/A error value.
  • If range_lookup is FALSE and lookup_value is text, you can use the wildcard characters, question mark (?) and asterisk (*), in lookup_value. A question mark matches any single character; an asterisk matches any sequence of characters. If you want to find an actual question mark or asterisk, type a tilde (~) before the character.
  • In the example in the Excel training video the sorted data represents the density of water at different temperatures. The left most column gives the temperature in degrees and the top column specifies the 'decimal' degrees
  • We looked up the density of water at 5.4 degrees celsius using the Hlookupfunction.
Still have problems, Check this video on the you tube.
Hope this would help,
Thanks,
Anurag Shukla
Sep 04, 2009 | Microsoft Excel for PC
HLOOKUP and IF formula netting problem
The value of C7cannot be found in the range - Hence the error.
Feb 04, 2009 | Microsoft Office Excel 2003 for PC
What are uses of vlookup n hlookup?
An implementation of the vlookup in Excel could be:
You have an Excel table with student names and their grades.
You wish that you could somewhere in the sheet type a student name, and immediately retrieve his grade (based on the data in the table).
To achieve this, you can use "Vlookup": the function will look for the student’s name in the first column in the table, and will retrieve the information that is next to his name in the second column (which is his grade).
Hlookup is the same excpet it is for data arranged by rows instead of columns.
Dec 29, 2008 | Microsoft Office Home and Student 2007...
Plz tell me sir. about in vlookup and hlookup.
Here is a GREAT Link with a lab that you can test on so you do not mess up your own data. Let me know if this helps ya!!!
http://office.microsoft.com/en-us/help/HA010563201033.aspx
Dec 02, 2008 | Microsoft Excel for PC
What is vlookup & hlookup?
1024x768 Normal 0 false false false /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} These are Excel functions for Lookup tables. The purpose of Lookup tables is to bring a value to the table, find the closest (or exact) match, and then return another value.
An example is the federal income tax table. On your tax return you get your gross income and number of dependents, go to the Lookup table, and find your taxable income.
The V in VLOOKUP means that the table is vertical; HLOOKUP has a horizontal orientation.
If you use the Insert Function button in Excel and paste either function, the dialog box will explain each required field separately with examples.
HLOOKUP IN MS EXCEL
lookup value = value searched
table array = database
topmost row of lookup array must contain the data IDs and all IDs must be sorted in ascending order.
row index number = row number containing data to be shown; first row = 1
hlookup(x,tablearray,y) will look for x on the first row of the lookup table and return the value in the cell on the yth row
if formula cannot file exact x, it will look for the value closest to. but not greater than x
Nov 13, 2008 | Computers & Internet
H look up
Hi vrusha,
Your right hlookup is very simular to vlookup, the key difference is it searches along the top row of the table, finds the matching data and gives you one of the below cells (depending on how you write the formula), just think of a vlookup on it's side.
The formula works like this:
=HLOOKUP(lookup value, table, row_index_number, range_lookup)
lookup value = is the value you want to match against the table i.e. ABBA
table = the range of cells that make up the table you want to search i.e. A1:D300
row_index_number = the number of rows from the top of the table you want to get the value from, 1 is the top of the table, 2 is directly below
range_lookup = if you want an exact match type FALSE, if you want the nearest match type TRUE
Jul 17, 2008 | Microsoft Office Professional 2007 Full...
Computers & Internet Logo
71 people viewed this question
David Payne
David Payne
