Question about Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV
Bulb keeps burning out
Why does my bulb keep burning out replace it on this tv 3 times in less then 14 months
  • 320 Answers
There are several reasons for short lamp life. Inadequate ventilation or clogged cooling fans, a bad lamp driver or lamp ballast (they are the same) and the use of non-original Sony lamps, as the aftermarket replacements are known problem causers. Remember too that the number of times the lamp is turned on and off is a BIG factor in how long the lamp will last.
Posted on Nov 13, 2008
Why does passenger side low beam keep burning out?
2002-2003 Altima(L31) headlamp recall - Nissan Forum ' Nissan Forums
forums.nicoclub.com/2002-2003-altima-l31-headlamp-recall-t125981.ht...
Jul 14, 2005 - Owner notification is set to begin August 15th 05. ... I thought I had a bulbburn out, but was able to fix it by making sure the bulb ... I spent about $250.00 a few months ago replacing a headlight bulb! ... I know this is an old post, but my 02altima's passenger headlight keeps burning! it's the 3rd time this year!
Sep 16, 2015 | 2005 Nissan Altima 2.5
2003 honda accord headlight
check the earth wire for dirty /rusted terminal as this is typical of voltage fluctuations the blow bulbs.
Jun 04, 2013 | Cars & Trucks
My samsung bulb keeps burning ouit every 6 months
YOUR TV MUST NOT BE SUROUNDED BY BIG IMPOSSING OBJECTS YOU MUST HAVE AT LEAST 3 FEET FROM BACK WALL THE COOLING FANS MUST BE CLEANED OPEN BACK COVER AND CLEAN FANS IF LAMP STILL BURNES AFTER YOU MAY HAVE A BALLAST PROBLEM
Jul 30, 2010 | Samsung HL50A650 50 in. TV
Headlights keep burning out, every other,
There was a recall for this problem...There is a wire harness replacement they will do for you. I had it replaced and still after about 6 months I had to replace a bulb.
Jan 21, 2010 | 2006 Kia Sedona
Head lamp keeps burning out. replaced head lamp at
You either have a bad ground or the bad electrical connection at the light socket is "simulating" a bad ground. This is putting a high resistance on the bulb and it's taking it's toll by burning out the bulb. I would start with a new socket, and CHECK the ground. If you still have the issue, I would run another complete ground wire and not even worry about checking the ground itself. the Stick
Dec 10, 2009 | 2006 Suzuki Grand Vitara
Replaced the lamp on 50v710 keeps on burning out
You have a bad Ballast. This can be repaired sometimes by replacing the capacitors on the Ballast circuit board.
Jul 29, 2009 | Televison & Video
Headlight keep burning out
you might be using a higher wattage of hallogen bulb. higher wattage bulb must have a relay so it'l stop from burning. and you save money.
Apr 15, 2009 | 2005 Kia Sorento
Wd-57731 bulbs keep burning out 3 bulbs burnt
Contact Mitsubishi. Their is a national recall on that TV. GET then to replace the TV.
MR. TV Sales & Service Inc
Milwaukee Wisconsin 53405
(414) 762-8600
Established 1974
Mar 24, 2009 | Televison & Video
Bulbs keep burning out
I would try a genuine sony replacement lamp. There are some reputable sellers on ebay selling them for a couple hundred dollars...Oh also, you say your TV is under warranty?
If it is under Sony's factory 1 year warranty, I would call them direct. If your on some sort of extended warranty plan, through a 3rd party company, tell them you want the genuine sony bulb. Put up a fight, and if that doesnt work, read the fine print for your 3rd party warranty. My extended 3rd party warranty states that if the TV fails 3 times during the extended warranty period, they will replace it with a new one as per their "Lemon" policy.
Sep 22, 2007 | Sony KDF-E60A20 60 in. LCD HDTV
Sony Grand WEGA KDF-70XBR950 70" Rear Projection HDTV Logo
391 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
