Problem related to bios setup
I have by mistaken disabled 32bit mode in bios setup in the hard disk configuration in "Windows Vista Home Basic" but the computer was normally started . I want to know that whether the 32 bit mode should be enabled or disabled in the boot up menu so that performance of computer is not affected????
Now what should i do, I should enable or disable 32 bit mode in the boot up menu in "Windows Vista Home Basic"????
    Genius:
  • 1,605 Answers
It doesn't matter. if you are running 32 bit operating ssytem. you can get majority of the hardware drivers.
however, if the operating sytem is 64-bit, you can't run it on a 32-bit machine. that is what determine by the BIOS.
since you have install the sytem and it seems running fine. I would just leave it alone.
Posted on Nov 13, 2008
XP will not install "Setup
That is because it was designed for Vista not the obsolete XP. There are no hard drive drivers suitable in XP.
Re install Vista or install Win7.
Hope that helps.
Jan 22, 2011 | Computers & Internet
Tip
Windows XP setup disk says disk not found.
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
on Apr 15, 2009 | HP G60-120US Laptop
I have a dell dx280 when I start the pc. I can see some simbols in the bios screen, after that I try to install windows xp and in the process appear a blue screen with error message about hardware problem....
First refix RAM memory . then try to install windows xp 5 times untill you can.
i also face same problem it is due to memory related so i refix RAM and try winxp install 3 times and i succeded.
Jul 16, 2009 | Dell Optiplex GX280 (99301) Motherboard
Hard disk not found error during Clean XP home Install
Jul 04, 2009 | Toshiba Satellite A35-S1592 Notebook
No internal hard disk found
Hi there.
Use the Vista CD to create the new partition, but first you have to delete the old partition first, (the 220GB partition not the 10GB one because that will be the recovery partition).
Get a calculator and work out your new partition, for example 50GB is 50x1024MB so that will be 51200MB.
When you have deleted the 220GB partition select NEW and input your newly worked out partition and carry on from there, to activate the other partition just format it.
Please post back with the results and for anymore help if needed.
Good luck and thanks for using FixYa!!
May 24, 2009 | Dell Inspiron 1525 Notebook
Install xp on vista home basic toshiba satellite L-40
Yes, Vista Home Basic is junk!
1.Vista is considered an upgrade, compared to Windows XP. Therefore, Vista is not just going to let you install over it.
2.You have to get your Windows XP drivers back.
This is a pretty intricate operation, but once you have detailed information, it becomes do-able.
Below is a link with detailed information, and concise clear illustrations. I felt it would be better to give you this link, to avoid any confusion, and/or misunderstanding of information from me.
Should get you on your way!
http://www.howtogeek.com/howto/windows/resolving-setup-did-not-find-any-hard-disk-drives-during-windows-xp-installation/
May 16, 2009 | Intel Gigabyte GA-8IDX 845 AGPset P4...
How to install windows xp sp2 on compaq v3239tu
Mar 14, 2009 | HP 417068-001 Compaq Presario V3000...
I have a lifebook t2440 i tired to put windows xp home editon it went to setup and started sherching for a pervious operating system and it came back and said no hard disk drive found.what versions of...
Jan 16, 2009 | Fujitsu LifeBook T4220 Tablet PC
Sata
You must disable the native mode for the SATA in setup mode.
***NOTE*** be sure that you have all of your drivers for the SATA and all drivers for windows xp before beginning.
Mar 12, 2008 | Computers & Internet
Open Questions:
Toshiba technical support customer care number +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 25, 2018 | Toshiba Computers & Internet
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
