Question about Zanussi FJS1225W Front Load Washer
Draw for washing powder won't open
Any ideas? So far I've managed to pull the cover off but luckily the clips haven't snapped. However the draw simply will not pull out.
  • 183 Answers
The drawer will be stuck in by detergent or softener, only way to get out is to prise out from dispenser box, in the past I have managed to lean machine backwards against a wall and poor a kettle of boiling water around the edges of drawer sometimes this will soften detergent other wise only one sollution brute force, soory no other way of getting it out. Regards Advisor
Posted on Aug 30, 2007
I can't find the cord to emergency unlock my washer. What exactly is the dispenser bezel to remove?
that's the draw you put you powder in as you pull the draw out quese the sides of the draw inwards nearest the machine and pull eric
Jan 19, 2018 | Washing Machines
How do I remove the top of the washing powder drawer unit for cleaning
I assume its a front loader? If so, the centre of the drawer (when open) has a clip which you push down to release the dispenser. It should slide straight out.
Mar 12, 2015 | Bosch Washing Machines
My hotpoint wmud843p washing machine is leaking from the detergent draw at the start of the rinse cycle?
Open the draw. Grip it tightly and pull it out. clean the draw and clean the dispenser housing. Usually leaks due to powder etc getting stuck under dispenser draw causing water to bridge across and leak under draw. Also use a pipe cleaner or cable tie to clear any blocked holes in the dispenser.
Sep 23, 2013 | Washing Machines
The detergent draw won't pull in and out easy. You've really got to 'pull' to get it open and 'push' really hard to make it close.
theres is probably soap inside the track where the drawer slides, just clean it out and you should be fine.
Jul 09, 2011 | Asko W6761 Front Load Washer
How do it ake out washing powder draw
Depends on make, most just pull out some at slight angle others have a clip ..good luck
Oct 02, 2009 | Washing Machines
Washing powder and conditioner draw keeps getting blocked
The easiest thing would be to switch to liquid detergent or a different brand of powder. There might be diminished water flow. Try cleaning the nozzles where the water comes into the dispenser at.
Sep 18, 2009 | Washing Machines
Hotpoint wdl540, cant get the draw out
pull it out as far as it will go. Look inside you will see a clip at the top. depress this upwards and pull draw out
Sep 01, 2009 | Hotpoint Aquarius WD63 Front Load...
Philips dvdr 3480 disc draw refuses to open
Illustration:
This usually happens when you close the drawer with no disc in it. There is a strong magnet inside the DVD-drive that keeps the spinning disc in the correct position. But when the drive is empty, the magnet is connected to tough to its counterpart (no disc in between) and the worn out motor and/or transmission (belt) is not able to pull them apart in order to open the disc tray.
How to fix - "brute-force-attack":
Press OPEN and give the disc draw a couple of decent slaps (or snap at the tray cover with your forefinger) until it opens. Repeat procedure, if motor stops before drawer is open.
How to fix - "high-tech-approach":
Disconnect power chord. Locate the slot provided at the bottom of the device, near the smaller, left clip holding the front panel. Insert a screwdriver into it at the far right (when viewing from the front), so you can push a small white plastic-lever-thingy (can be seen thru the slot) to the far left. Now the tray is partly opened and can be pulled out completely.
Future outlook:
Don't you never ever close your old machine with no disc in the tray - or just start over again...
Jul 26, 2009 | Philips Televison & Video
How to remove the drawer on the wmd960
pull the draw out as far as it will go, there is a blue tag in the middle to the back of the draw, push this down and pull the draw all the way out
Jun 09, 2009 | Hotpoint Aquarius WD640 Front Load...
Zanussi FJS1225W Front Load Washer Logo
67 people viewed this question
Top Zanussi Washing Machines Experts
jimorris77
shaun taylor
Marvin
Marvin
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
