Question about Sony KV-32S26 32" TV
No video, continuous blinking status light. Audio OK
I have seen people post issues very similar, if not exactly the same, as mine. Turn the TV on, status light begins a continuous blicking (no pauses), can hear audio, but picture never appears. Started about a week ago where the picture would be fine and then all of a sudden would shrink upwards towards the top of the tube until none of it was visible. It is not as if the whole picture moved up (imagine Hor-Hold on an old set), as the top resolution lines remained stationary and the lower lines seemed to compress onto one another until the whole picture vanished. Was able to turn the TV off and then back on to get picture once again but as of this past weekend, even that is not working anymore. I have seen people suggest the problem is anything from cold solder connections, dried up capacitor, to Jungle IC. The problem I am running into is no one wants to give you an estimate for repairs unless you pay them a diagnostic fee (which they will apply towards repairs if you decide to repair it). I am trying to determine if it is even worth paying to have it fixed or if I should just upgrade to a new LCD (Which will have a sharper picture and won't feel like its encased in lead!). I understand that the cost of repair can vary based on root cause and parts/labor to repair it, but I just want a ballpark figure. Could any of you please assist here?
    Problem Solver:
  • 6 Answers
Continuous Blink Once A Second, No Pausing As Discussed Above--- No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective
Posted on Nov 16, 2006
SOURCE:
What are the lg 32lk330-ub tv hard reset tv blinking codes tv comes on then shuts off in about 5 mins red led light blinks continuously
Have seen similar in sets with blow projector bulb.
Suggest obtain owner's manual and follow the steps.
Dec 31, 2017 | LG Televison & Video
Tv won't turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
May 26, 2016 | Mitsubishi Lt-40164 40 Hz 120 1080p...
Magnavox 37mf231d will not turn on, only have steady flashing led light-continuous
I just fixed mine that had a very similar symptom to this and it was a bad part on the main board. I made a video showing what part and how to replace it. I also added a link below to the part I ordered. L5973D STMicroelectronics Mouser
Aug 07, 2014 | Toymax Magnavox 37MF231D 37 in. LCD TV
Mitsubishi wd 62527
hello there it could be a loose connector that u may have disturbed or broken look again inside if it worked before with
sound the chances are its ok
Jan 21, 2018 | Televison & Video
Red standby light came on and no picture sound is ok .Next. time tv came on it played approx one hour everthing ok. then the picture gradually faded away . Red standby light came on again. Still no...
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV. The self-diagnostic function of the TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue.
Few examples are given below; some of the issues may be resolved without the need for service.
1 blink / 2 blinks / 5 blinks: - This indicates that there may be a power-related problem with your set.
3 blinks: - This indicates that there may be a power-related problem with your set. The set will need to be serviced to allow a technician to determine the specific issue that needs to be repaired. If the power light flashes three times in sequence in a Lamp TV, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
4 blinks: - This indicates that there may be a back light or lamp power problem.
6 blinks: - This indicates that there is some kind of audio problem with your set.
7 blinks: - This indicates that there is a temperature problem with your set. Please check to make sure that the air vents on the sides and back of the set are not blocked or clogged and there is adequate ventilation around the television. We recommend that you check and clean the vents periodically to make sure the set receives adequate air flow. If the problem continues, the set will need to be serviced.
8 blinks: - This indicates that there may be a video-related problem with your set. If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Jul 08, 2011 | Sony Televison & Video
My panasonic hdtv th-42pz80u has a red power light that blinks on and off and the tv will not turn on. how do i fix this?
How many times is that light blinking? For example a 7 blink error code would blink 7 times pause 7 times etc. What is your's blinking?
Dec 10, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
B;inking lamp light and tv wont turn on
Usually when light continues blinking the main board is OK but, your video boards or other boards may have an IC problem. I've seen where some have tried to fix these problems themselves only to make problems worse. I think you'll be better off having a Service Tech fix it. They will have your TV operating in no time at all.
Oct 26, 2009 | Hitachi Televison & Video
No sound and the power light is blinking
I had similar issue with power light blinking 3 times and no audio/video.
The problem was a burnt resistor and gone convergence ICs. I replaced both ICs (safer bet unless you know exactly which IC covers what guns in your specific TV) and the burnt resistor by myself and the TV looks good as new.
Apr 06, 2008 | Panasonic PT-56HX41 56" Rear Projection...
Monitor
i had a similar issue with my dell E172FPB, I have never seen a E173FP but this link might help you
http://syscon.wordpress.com/2007/07/13/dell-dell-e172fpb-lcd-backlight-repair/
Oct 21, 2007 | Dell E173FP 17" LCD Monitor
Sony KV-32S26 32" TV Logo
82 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
