Question about Motorola Mobility RAZR V3
Keypad remains lit even when turned off
This began after dropping the phone in the toilet.  I promptly dried with a hair drier, but keypad drains battery in a few hrs whether I talk or not.
    Brigadier General:
  • 7,752 Answers
You need to take the phone to a mobile repair shop and have them service it for you.
Posted on Dec 28, 2008
My phone screen went blank after dropping in the toilet
You should have left it dry instead of turning it on, you probably have corrosion now, find a local place that works on phones to see if they'd work on it.
If you want to try to completely dry it, put it in rice for 24 hours minimum to draw out all moisture.
Aug 03, 2017 | Motorola Mobility RAZR V3
Keypad is jammed
http://www.fixya.com/support/r3771170-phone_water_damage
Aug 23, 2009 | LG Shine KE970 Cellular Phone
I dropped my sgh-d807 in water,the screens blank and wont turn on
u broke your phone becus i did the same thing and had to buy a new phone sorrythat happened
Jul 10, 2009 | Samsung SGH-d807 Cellular Phone
How do you unlock the keypad?
We had this problem with ours, It is the 'control lock' that is on, a child safety 'feature' that can be turned off by holding the air dry or pro dry button for four seconds.
Dec 20, 2008 | KitchenAid 23 in. KUDD01DPPA Stainless...
Nokia 2630 unlock? please help...
take a hair drier and dry your handset first before you switch it on ...
remove the panels and dry ...
while drying dont put the battery ....
dry the battery separately with the hair drier dont impose too much heat on the battery that may leak the battery ....
after drying with the hair drier all the water vapours will be evaporated so by this after that you turn on the phone it will surely work ....
this is the best method to do ..
even the mobile technicians will also use this method only ...
so try to follow this & fix your phone by yourself ...
any doubts you can reply me
i am always here to assist you
thank you
bye
rate my solution
Jul 14, 2008 | Nokia 2630 Cell Phone (Unlocked) - Black
Security code
your keypad was grounded, try to open your phone and check if there was a moist. clean it and dry it using hair blower. good lack
May 05, 2008 | Nokia 6230
No display screen
u must let your cellphone dry up b4 u turn it on,1st thing to do dismantle your cellphone case then u can use a hair blower to dry it up. then try to turn it on. if its not working maybe your cellphone suffers a shortcercuit
Dec 18, 2007 | Motorola Mobility RAZR V3
Motorola V3m keypad problem
open the phone and clean the keypad connector really good
Dec 11, 2007 | Motorola Mobility RAZR V3
Dropped razor in toilet
Sounds like it is done for, yes. I know a way to save electronics if they are dumped in water, but it requires to fill it with water replacing fluids. Putting it in pure alcohol right away (remove battery first) might save it, as ir should replace the water and then evaporate completey when you take it out. Some contacts have probably corroded in your phone, so unless you are (or know) a repairman of electronics you'll probably need a new phone. :-/
May 16, 2007 | Motorola Mobility V600
My phone is brok
You need to remove all the varistor that is on the keypad teh components that has a "V" on it look beside the "LED" on the keypad. Also before doing that soke it in Vodca its a good alcohol to clean with, use tooth brush and scrab scrab scrab! Good luck
Jun 12, 2006 | Samsung SCH-a670
Motorola Mobility RAZR V3 Logo
43 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
