Question about Brother MFC-8440 All-In-One Laser Printer
Brother mfc-8440 printer/fax
I am getting a message .cover open and I can not send any faxes?
    Champion:
  • 320 Answers
You need to buy the left cover hinge, how ever so that you can use the machine, by the cover there is a sensor button, tape it down and you can still use the adf
Posted on Jan 14, 2009
Just installed a new drum unit in my Brother DCP1000, and it's still reading "Replace Drum soon"
heya!
this stands for brother mfc-8440 as in the title.
you need to reset the "drum counter" of your printer..
to do so try one of those
Brother Laser Printers:
After replacing the drum unit, keep the front cover open (make sure the power is on). Press and hold the "GO" button until all four LED's are lit. Once the four LED's light up, close the front cover. Make sure the drum LED is off. The counter is reset!
Brother Fax Machines:
Open the front cover. Press the CLEAR/BACK button. Press 1, when the display shows accepted.
Sep 19, 2011 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC 8440 Automatic Document Feeder doesent feed
Could be a sensor in the ADF, or the hinge on the left rear of the scanner cover is broken.
Jul 21, 2009 | Brother MFC-8440 All-In-One Laser Printer
Two fax machines on one line, one won't send
Buy a double outlet RJ-11 adapter.
Set the one you use for sending only to MANUAL RECEIVE.
Jun 22, 2009 | Brother MFC 8440 All-In-One Laser Printer
Brother MFC-8440, send fax ok, but no receiving fax
The manual has step by step instructions, I'll include a link for the online version. Section four runs through setting up recieving, if it's on a dedicated line follow the first set of instructions to set up automated answering. If it's a shared line(phone/fax) then continue down to the next section.
Note: for a shared line you may need to contact your line provider for a second number that has a "dedicated ring"
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc000219/MFC-210C_UsaEngUsr_B.pdf
Hope this helps FixYa,
Chris
Apr 11, 2009 | Brother MFC 420CN All-In-One InkJet...
Scan from brother MFC 8440 to pc
you need to make sure that the brother printer is et as the default printer
Dec 19, 2008 | Brother MFC-8440 All-In-One Laser Printer
I can fax and copy on the glass with the Brother MFC 8440 but not through the ADF. Any suggestions?
This is usually cause by a broken left hinge on the adf. Lift the lid and look near the back at the hinge. If you need the part email me for pricing jtuminaro@officetechservice.com
Dec 10, 2008 | Brother MFC 8440 All-In-One Laser Printer
I have a brother mfc-8440
I would try to plug a regular phone in the jack to see if you are getting a clear signal/dial tone to the machine, if not, you may need to have the phone company come check it out.
Nov 18, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother mfc 8440
This is commonly a problem with the left hinge being broken on the lid where the adf is. Check that and if it is broken i can give you a part number.
Sep 03, 2008 | Brother MFC8440 Remanufactured Laser...
Sending and receiving faxes problem
you may have a scanner problem, this should be checked by a locaal brother serice cemter. thanks brother tech
Aug 28, 2008 | Brother MFC-8440 All-In-One Laser Printer
Fax only Dial and start
I have known this to be two things most times it is a button stuck (press every(all) keys)
If not and you have ensured it not just a sticky button just post here for more
Jan 03, 2008 | Brother MFC-8440 All-In-One Laser Printer
Brother MFC-8440 All-In-One Laser Printer Logo
67 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
