Question about Acer Aspire T310 PC Desktop
To sandrew there are no beeps when computers turned on, should i still check hard drive and windows xp? thankyou for your help
    President:
  • 2,961 Answers
If there are no beeps, try removing one of your memory sticks to see if it will boot, no beeps means no memory check.
Posted on Nov 16, 2006
  • andrew pester
    andrew pester Nov 16, 2006
    are you able to get into the bios(press F2 or DEL on boot up) and in the standard bios settings at the bottom of the list should be 'halt on all errors', you need to dissable this, then save settings.
    Allow a re-boot and it should carry on though the p.o.s.t and then tell you the problem.
    If it says cmos checksum error it may be that your cmos battery is in need of replacing, a sure sign of this is your system time being wrong.
    But the main problem seems to be a memory fault as there has to be beeps.
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
Beeping and flashing light and battery icon, can not turn computer off with on off switch. What is causing this? Checked all plugins.
hi this problem cauld be a number of things you may have to elimonate .......... memory if you have 2 sticks of memory in take 1 out and try 1 at a time .... the beeping if constant is your hard drive whitch is dead..... have you tryed reinstalling windows xp or what ever windows you use may solv the problem......please reply
Nov 10, 2010 | HP Compaq d530 SFF PC Desktop
I am trying to install win xp with sp2 on my laptop. i was using vista on it before . it show this error message; A problem has been detected and windows has been shut down to prevent damage to your...
If you want both OS you need to do a partition on the HD to proceed.IThat what i can figure from your quest.But if you just want XP just do a clean installation of it.
Perform a clean install of Windows XPA clean installation consists of removing all data from your hard disk by repartitioning and reformatting your hard disk and reinstalling the operating system and programs to an empty (clean) hard disk. For more information about important things to consider before you partition and format you hard disk and how to partition and format your hard disk by using the Windows XP Setup program, click the following article number to view the article in the Microsoft Knowledge Base:313348  (http://support.microsoft.com/kb/313348/ ) How to partition and format a hard disk by using Windows XP Setup programTo perform a clean installation of Windows XP, follow these steps:
  1. Back up all important information before you perform a clean installation of Windows XP. Save the backup to an external location, such as a CD or external hard disk.
  2. Start your computer from the Windows XP CD. To do this, insert the Windows XP CD into your CD drive or DVD drive, and then restart your computer.
    Note To boot from your Windows XP CD, the BIOS settings on your computer must be configured to do this.
  3. When you see the "Press any key to boot from CD" message, press any key to start the computer from the Windows XP CD.
  4. At the Welcome to Setup screen, press ENTER to start Windows XP Setup.
  5. Read the Microsoft Software License Terms, and then press F8.
  6. Follow the instructions on the screen to select and format a partition where you want to install Windows XP.
  7. Follow the instructions on the screen to complete the Windows XP Setup.
If you have successfully installed Windows XP, you are finished. If these steps did not help you install Windows XP, go to the "Next Steps" section.
Oct 06, 2010 | Promise SATA300 TX2plus...
Have a Dell Computer that was purchased in 2005 with Windows XP Home Edition installed. The computer had an alarm sounding and then just shut down and we cannot get it to come back on. We have tried...
kindly let me know the beep code sequence (the alarm) which you are getting. Just switch on the computer and carefully listen the alarm one long continuous beep or short beep or one long followed by one short. This information is necessary for providing you the solution. Online chat would have been more helpful to restore your pc.
Sep 25, 2010 | Computers & Internet
My lacie harddisk doesn't show up in windows XP. Power is ok. Light is on and he makes normal operating noise like always. I have another one for which I use the same USB-chord and that one is working...
1. right click the my computer
2. go to properties
3. click hardware tab
4. and click Device Manager
5. show the Device Manager and click disk drives
6. your hard disk is show or not.
7. it's show then go my computer properties
8. select manage and show computer management window
9. then click disk management
10. your hard disk partitionis show right click the partition add driver letter (ex: h:, i: ..)
11. after open the my computer the partition is show
thankyou
Sep 15, 2010 | LaCie F.A. Porsche (301177) Hard Drive
When i turn on pc it won't load windows. it beeps
open the CPU and refix the RAM sticks.. blow off the dusts from the board.If its having more than one RAM, put one RAM and check.do the same way with another RAM.If you get same beep sound from the both RAM, that means you will have to change RAM sticks.
Aug 23, 2010 | Microsoft Windows XP Home Edition
Ntldr is missing, press any buttom to start
Hello, NTLDR is the main file of windows XP to boot it properly. You can recover this file without installing the full windows XP. Follow the given steps to recover the NTLDR file from windows XP CD.
First insert the Windows XP bootable CD into your CD-drive and reboot your computer. When your computer prompted a message to press any key to boot from the CD, press the any key.
Once in the Windows XP setup menu press the "R" key to repair Windows and now log into your Windows installation by pressing the "1" key then pressing enter.
Here you will be prompted for your administrator password, enter your that password then copy the below two files to the root directory of the primary hard disk. In the below example you are copying these files from the CD-ROM drive letter "E" to drive c. This letter may be different on your computer.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad);
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
Once copy both files, remove the CD and reboot your system.
Thankyou
Skype Id:- amit.bhardwaj4
May 08, 2010 | Microsoft Windows XP Professional SP2
Problem loading Windows XP
You need to start windows in the safe mode, press F8 at boot up.
Remove al the drivers that you've installed on you previous computer system, usualy this is is a conflict between wrong drivers and your hardware.
If you can't remove the old drivers, reinstall Windows XP, do a clean install
by booting your computer up with the Windows xp cdrom, from the Windows XP cdrom you're also able to repartionate your hard drive.
First remove the old partition(s) en make a new one, the setup does then format your harddrive, after that you're ready to install windows xp on the new partition.
Jan 19, 2010 | Microsoft Windows XP Professional
Bought HP Pavilion dv2910tx,not able to install Windows XP. Help
If the install cannot detect the hard disk then the hard disk is faulty and needs replacing or the disk controller is faulty.
You can check if the hard disk is faulty by :-
Go into the BIOS and check if there a hard disk diagnostic.
If not then remove the hard drive and connect it to an USB hard drive adapter and plug it into a working computer's USB port.
If this computer see it as an external hard drive and you can view the contents of the drive then it is OK and the fault is the disk controller on the laptop.
To setup XP.
You insert the Windows CD and boot up the laptop with the CD.
You have done this correctly to get the hard disk error message.
Apr 15, 2009 | HP Pavilion dv2000t Notebook
I purchase a FreeAgent Go 160gb,getting started it does not do anything. the diolog window does not come up,unit just beeps...
If this is an External USB Hard-Drive, your problem is insufficient power provided by the USB Port.
1:- Try Another USB Port If You Have One.
2:- If you have a 2 into 1 USB Cable, connect 2 into 2 individual USB Ports ( On Computer ) And 1 into Hard-drive Unit.
If none of this works, your drive is faulty.
Mike @ Compurepair.
** Please do not rate this, until your problem has been resolved ** Thankyou for using Fixya.
Feb 27, 2008 | Computers & Internet
Acer Aspire T310 PC Desktop Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
