Question about Motorola Mobility RAZR V3
Phones goes off and it is fully charges
Phone was between bed and wall for 12 hours
  • Anonymous Dec 29, 2008
    fghgfhgf
    Brigadier General:
  • 7,752 Answers
Well take the phone to a mobile store and have it checked to determine what the cause is
Posted on Dec 28, 2008
Mt bettery goes down quickly
You may need to replace your battery. It sounds like it may be going bad.
Before you do, plug your phone in for at least 12 hours to charge it fully. If it continues to go down quickly, you may wish to try another (New) battery.
Jan 24, 2011 | Cell Phones
Less batterry backup
let the battery drain off fully, remove and clean the contacts and battery contacts. replace and put the phone to charge, once fully charged , allow it to remain for 12 hours.
Now check this out, if the timing has changed, if so repeat,
Other wise the battery needs a replacement.
Sep 19, 2010 | LG Cell Phones
I always charge my phone before i go to sleep and when i wake up it says it is charge but when i unplug it .. it says 75 percent what do i do??
First, every phone battery has their own required / maximum time of charging. Charging it before going to bed will over charge the battery.
Since you're getting 75% of the battery status, it means that the battery is now starting to become defective. The best thing that you may do is to buy a brand new battery for your phone.
Most brand new batteries requires 6 to 8 hours of charging. After the initial charging, the next charging will be 3 to 4 hours only. BUT, you have to make sure that the battery runs out of charge before plugging it in to the wall socket. This will make the battery life lasts long.
Thank you and good luck!
Aug 18, 2010 | Cell Phones
Battery goes flat very quickly
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you use a car charger, use a wall plug instead and replace the battery; because a lot of car chargers can harm battery life…especially if that is all you’ve ever used. Also check the settings on the phone, if you have disabled power saving features that dim the screen after so many seconds then the backlight will drain the battery very quickly. Use name brand batteries and not the ones that come with the phone. If you have not tried to buy a new battery yet, the ones that come with the phone can often ****. Finally, make sure that you do not have a short in your wall charger and that the first time you use a new battery you charge it fully to begin with and don’t charge it again until it is completely depleted. Supposedly newer batteries do not have to be primed, but I find it is a good practice anyway.
Oct 02, 2009 | LG KU990 Viewty
My phones (philips cd445) will not hold a charge for more than a few hours off the cradle...yes I have replaced the batteries, twice. once with disposables, once with rechargeables
You might have what is called "memory'. If you continue to replace the phone on it's charger after each call the battery will "think" it's empty, giving you s short charge time. Next time you replace the batteries (rechargeable) FULLY charge them then leave the phone off the charger until you go to bed at night.
Sep 18, 2009 | Philips CD4452S/05 Digital Telephone and...
I charge my LG KU990 full over night within 12 hours the battery
You just have to charge it fully but not for long as soon as it turns full battery then swithch ur phone off then take the battery out for a sec then put it back on then turn ur phone on then it will work for a longg timeee kk..
Nov 13, 2008 | LG KU990 Viewty
LG VX5400 cell phone power problem
try replacing your battery
Jul 29, 2008 | Cell Phones
Charged cell phone
do not charge your mobile battery each night for best battery use, you need to charge the phone only when the battery is completely dead.
You should take the phone and have it fully check and service
Jun 28, 2008 | Motorola Mobility RAZR V3
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
Motorola Mobility RAZR V3 Logo
16 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
