Question about HP OfficeJet 6210 All-In-One InkJet Printer
Cartridge replacement Assistance with installation
  • 421 Answers
Download the manual here: http://h10032.www1.hp.com/ctg/Manual/c00369562.pdf
Step by step guide
Posted on Nov 13, 2008
New black ink cartridge
I suggest You Go to Official Brother Printer Page For You Brother Printer Problem On Below Brother forum URL Link: Replace the toner cartridge Brother
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On :Brother Printer Support
Feb 13, 2014 | Brother MFC-290C Printer
Problem with fake ink replacement
you will have to get 4x new color chips. and replace it on the cartrdges
Sep 11, 2012 | HP LaserJet 2700n Printer
E5 what does this mean and how can I get out of it?
Hello and welcome to FixYa!
Error E5 means that the ink cartridge is not installed or the ink cartridges is not installed properly or may be
non-supported ink cartridge is installed.
It may also mean that if you have both cartridges in printer one or both are failed. To solve this problem check print cartridges and replace first color, if not help replace black ink. Install the appropriate fine cartridge and also If the lines are misaligned or resulting output is not satisfactory, carry out the fine cartridge alignment and make it aligned.
I hope this solution helps you
Don't hesitate to let me know if you want any further assistance.
Thank you for using FixYa!
Jul 12, 2011 | Canon PIXMA MP150 All-In-One InkJet...
Printing blank pages after installing a new toner in lexmark 264dn
Remove the entire cartridge, clear any paper or debris inside the printer, then re-insert cartridge. Cartridge needs to be fully seated in printer.
If problem persists, remove the cartridge and check metal tab on right side of cartridge for damage. If damaged or missing, replace PC Kit. Check metal tabs on bottom of Cartridge. If missing or damaged, replace Developer Unit.
If problem still not corrected, contact Lexmark Technical Support for further assistance.
Jul 11, 2011 | Lexmark X 264dn - multifunction Laser...
I have been using an epson stylus color 880 for years. One day it would not print. Replaced the cartridges and still will not print. It goes through the printing procedures but nothing shows up on...
The print head nozzles may be clogged. From the Utility section found in the EPSON printer driver, clean the print heads by performing a head cleaning followed by printing a nozzle check pattern. A head cleaning and nozzle check must be performed as a cycle. After printing a nozzle check, examine the printed dot pattern. Each staggered horizontal and straight vertical line should be complete, with no gaps in the dot pattern. If there are gaps in the dot pattern, continue with another cycle. Perform up to 3 cycles if necessary. If the nozzle check is not printing completely, and if the head cleanings do not help the nozzle check pattern to print completely, try replacing the ink cartridge. Any ink cartridge installed into the printer must have a blue label on top of it. If the blue label has been removed from the ink cartridge, do not install the cartridge. Using an ink cartridge, which does not have the blue label on it, may damage the printer. Caution: If you have already installed a cartridge which is missing the blue label, or if a previously installed ink cartridge was missing its blue label at the time it was installed, and now head cleanings do not help the nozzle check pattern to print completely, your printer may require service and you should contact the EPSON Connection for further assistance.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jul 08, 2011 | Epson Stylus 880 InkJet Color Printer
I have an all-in-one Kodak ESP 3250 printer. Bought it 4 months ago. I'm interested in printing only in black, but now the color cartridge has emptied and it won't let me print with the black cartridge...
The KODAK All-in-One Printer uses an advanced built-in printhead. The system is designed to provide excellent image and text quality, while eliminating the need to purchase new printheads every time you replace ink cartridges, and saving you money. The printing system requires that both the black and color ink cartridges be installed to print. If either cartridge is not installed or is out of ink, the printer or printhead will not print correctly.
Install the color a new cartridge, avoid damage to the print head.
Thanks, Joe
Apr 15, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
I just purshased a lexmart pro 705..How do you install the ink???please help
Replacing ink cartridges
Make sure you have a new ink cartridge or cartridges before you begin. You must install new cartridges immediately
after removing the old ones or the ink remaining in the printhead nozzles may dry out.
1 Turn on your printer.
2 Open the printer.
Note: The printhead moves to the cartridge installation position.
3 Press the release tab, and then remove the used ink cartridge or cartridges.
4 Install each ink cartridge. Use two hands to install the black cartridge.
Note: Install the new ink cartridges immediately after removing the protective cap to avoid exposing the ink to air.
5 Close the printer.
The setup guide is on theCD you received with the printer.
Thanks, Joe
Feb 23, 2011 | Lexmark Office Equipment & Supplies
How to install cartridges
Here's a youtube video on how to install replacement ink cartridges on the Lexmark Pro 205 printer.
If you're doing a new printer install, I suggest you use the installation cd that came with the printer for detailed instructions on how to install the printhead and the ink cartridges. Hope this helps. If you need more assistance, just leave a comment and I'll get back to it. If you want, you can also contact Lexmark Technical Support for further assistance. Thanks.
Jul 01, 2010 | Lexmark Prospect Pro205 Wireless...
How to install ink cartridges #4 & 5 for 2600
Here's the User's Guide (Lexmark X2600, X2630, X2650). This should guide you on how to install/replace cartridges on your Lexmark X2600 printer. Go to Maintaining the Printer, Page 44, to view the instructions. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Apr 22, 2010 | Lexmark X2600 InkJet Printer
Have put in a new colour cartridge but the note on the printer comes up error 50C
Cartridge Error 50C
Your print cartridge has shorted.
  1. Power off your All-in-One and unplug it.
  2. Plug in your All-in-One again and turn it on.
  3. Uninstall and then reinstall your cartridges.
  4. If this does not resolve the issue, try the troubleshooting steps for the other cartridge errors below.
Error: Black Cartridge Missing
The black cartridge is not installed. (Install cartridge PN 82)
Error: Color Cartridge Missing
The color cartridge is not installed (Install cartridge PN 83)
Cartridge Error
Complete the following instructions:
  1. Power off your All-in-One.
  2. Use both hands to lift up the scanner unit until the scanner support holds it open.
  3. Turn the All-in-One on. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy.
  4. Remove the color print cartridge.
  5. Lower the scanner unit until it is completely closed.
  6. If the error message reappears, replace the black print cartridge with a new print cartridge.
    If it does not repeat steps 1-3 and then go to step 7.
  7. Reinstall the color cartridge and remove the black print cartridge.
  8. Lower the scanner unit until it is completely closed.
  9. If the error message occurs again, replace the color cartridge.
  10. If an error message reappears, repeat steps 1-3 and reinstall both print cartridges.
  11. Lower the scanner unit until it is completely closed.
  12. If you receive the error message again, replace both cartridges.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 03, 2009 | Lexmark X5150 All-In-One InkJet Printer
HP OfficeJet 6210 All-In-One InkJet Printer Logo
78 people viewed this question
Seeker5211
Seeker5211
