Question about Vivitar ViviCam 5386 Digital Camera
Lens I talked my sister into buying this camera. I am trying to figure out what is wrong. When I turn the power on the lens auto goes in and out 4 - 5 times and then the lcd screen goes blank - black
Well, please folks don't use cheap (dollar store) batteries. I changed the batteries out three time with some new ones she gave me (generic) and when I inserted better quality batteries well that solved it!!!
Posted on Nov 14, 2008
Lens error restart camera
  • 1. Begin by turning the power on and off 4 times. If this does not work, remove the battery with the power still on, wait about 15 seconds and replace the battery. Once you have installed the battery, turn the power on. You can plug the audio/visual cable into the camera preventing the LCD screen from powering up. This will allow for more power to be directed to extending or retracting the lens.
  • 2. Try using compressed air to clean around the lens barrel area, this may dislodge the debris that is preventing the lens from extending or retracting.
  • 3. Gently tap on the bottom of the camera while holding the camera with the lens facing the ground. Try using the palm of your hand or the rubber pad on the USB compartment. You want to dislodge any dirt or debris that is lodged within the camera.
  • 4. With the power OFF, place the camera flat on the table with the lens facing the ceiling. While holding the shutter button down turn on the power, this will cause the lens to auto focus hopefully seating the lens barrel guide pins.
NOTE: The next step is the most forceful procedure, therefore use extreme caution when performing. Remember, if a click is heard during this step then stop and check to see if the lens error has been resolved. Clicking sounds may indicate that the lens barrel guide pins have reset.
  • 5. While turning the power on GENTLY twist, pull or push the barrel while the lens is extending or retracting. You want the barrel to move in or out evenly. The idea behind this step is to overcome the friction that is caused by misalignments or dirt within the barrel.
Jun 20, 2012 | Canon PowerShot SD850 IS Digital Camera
Will not power up
There are several reason why digital camera doesn't stay ON even when the batteries are fully charge or use brand new batteries. You can try to do the following steps to make sure that there is something wrong on the camera and not just batteries.
- Remove the batteries from the camera and the memory card
- Make sure that your using a brand new batteries
- Clean the battery contacts with a clean dry cloth
- verify that the batteries are inserted correctly
- Set the camera in Auto then turn it on
[Listen if there is a grinding sound on the lens part of the camera.]
Most Digital Camera turn itself Off when the lens won't zoom. So, if your camera start up and lens moves before it turns off and you can switch it on a different mode and it works. You need to contact your camera manufacturer and have the camera sent for repair. It might be wiring issue on the lens part of the digital camera
Nov 17, 2009 | Cameras
Nikon Coolpix S202
My nikon coolpix s210 had a "lens error" after several months of use. The tapping of the camera against my hand did not work. Eventually i did use the method of putting my nail under the lens and pulling as I tried turning the camera on. I had to apply a good amount of force and was afraid i would break the camera, but after doing this several times, the lens did click back into place.
Jun 01, 2009 | Nikon Coolpix S210 Digital Camera
Nikon Coolpix S202 "lens error"
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
May 28, 2009 | Nikon Coolpix S210 Digital Camera
Canon EOS 40D not working when turned on
I'm sorry to tell you this but you do NOT have anything set wrong. To test my theory turn your camera to full auto. Next make sure your switch on the lens is set to auto. Then just try taking some shots of some objects across the room. If that doesn't allow you to take pictures do the exact same test with a different lens. That way you've taken the lens out of the equation. Sorry I couldn't give you a better answer but I'm pretty sure you'll need to return the camera to cannon.
Dec 28, 2008 | Canon EOS 40D Digital Camera
Lens cover stuck
im having the same prob with mine right now. my little sister had it for a while and she said it started doin it ramdomly but now the lens wont close at all
Nov 04, 2008 | Sony Cyber-shot DSC-S600 Digital Camera
My camera says "Turn the power off and on again"
My sister had the same problem and I was trying to figure out what it was so I googled it and someone suggested to take the camera and hit it (not very hard) with the lens side down on a table.....This may sound completely crazy but I tried it and it made a weird sound so I turned it off then on again and it worked!! Hope it works!
Sep 01, 2008 | Sony Cyber-Shot DSC-W7 Digital Camera
Camera won't talk to lens
Is the lens switch in manual or auto mode?
Feb 25, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Camera Wont Turn on
Please eject camera battery and clean with a pin your battery tip in your camera with care fully.d36f20d.gif
Hope its helpful to you
Oct 17, 2007 | Samsung Digimax L60 Digital Camera
Lens error displayed by coolpix 3700
With the lens facing downward, hit the camera a sharp tap against the palm of the hand whilst simultaneously turning the camera 'ON'. If that fails, tap against a stiffer surface (desk or table), allowing room for the lens to extend and taking care not to damage the body of the camera.
Oct 08, 2007 | Nikon Coolpix 3700 Digital Camera
Vivitar ViviCam 5386 Digital Camera Logo
37 people viewed this question
Top Vivitar Cameras Experts
Tony
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
