Question about Toshiba CX36H60 TV
Toshiba CX36H60 Cold start woes
When I turn the set on the picture is totally fuzzy and unwatchable. After some time (20-30 min) the picture is perfect.
Any thoughts?
Check the capacitor in the SMPS and around Mr. Flyback
Posted on Jun 02, 2009
Back light problems
This tv has far too many options. Toshiba like to make one set for all markets.
Here is the manual.
http://www.toshiba-om.net/PDF/English/Country_Specific/AV615-1922263237-English-Specific.pdf
Start over, as if from the box, and set everything to default
Mar 18, 2014 | Toshiba Televison & Video
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
Hi My toshiba CX36H60 has a problem -- no picture but sound is good. what could be the issue and how to rectify it. Please suggest.
As sound output is ok, main board is correct with respect to sound output, video IF and ther stages. The fault lies on the horizontal output section. It may be LOT fault. Check it further for horizontal oscillator stage, and horizontal output stage. Check the collector voltage at the horizontal driver transistor. If you have a frequency meter, check the frequency of that point. It should be somewhere near 15625Hz. If the frequency there is Ok, then proceed to horizontal output stage. Check the horizontal output transistor. If it seems to be faulty, replace it with similar type and number. If the replaced horizontal output transistor heats abnormally within seconds after swich on the set, surely LOT has troubel. Replace it also with same model mumber and type.
Oct 16, 2010 | Toshiba CX36H60 TV
For a few months it took a while for the Tv picture to harm up, it was all shaky and unwatchable, now there is sound but no picture.
this is common for this set your will need a tech to replace 10 caps located in the
hyper board there is a service buliton on the toshiba site nice set when running
Nov 24, 2009 | Toshiba 50H82 50" Rear Projection...
Toshiba 42 WH36 P REAR PROJECTION
You have a convergence problem. Need to replace convergence IC's.
Jun 02, 2008 | Toshiba 42H81 42" Rear Projection...
Toshiba cx36h60
check the sound section if there's a 12volts supply of the sound ic or check the speaker.
Jan 09, 2008 | Toshiba CX36H60 TV
Toshiba Color Television CF32G50
I have a toshiba cx36H60 sound no picture
Dec 17, 2007 | Toshiba CF32G50 32" TV
Toshiba 42 inch rear projection TV
You likely have a bad hyper board.  As time goes on the lenght of time it takes to get a clear picture will increase and eventually the picture will never clear up untill the part is either repaired or replaced.
Oct 23, 2007 | Toshiba 42H83 42" Rear Projection...
Toshiba model Cx36H60
Yes, I have been seeing a lot of those Toshiba IR receivers bad lately. Replacing it with a new one should take care of your remote problems. If you have never replaced small parts on PC boards then have a qualified tech handle it for you.
Aug 09, 2007 | Toshiba CX36H60 TV
36" tube tv. picture fuzzy and out of focus
It sounds like you may have a G1 intermittent short in the picture tube, which unless it is still in warranty would not be worth repairing.
Jan 02, 2007 | Philips 36PW9525C 36" TV
Televison & Video Logo
91 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
