Jwin JD-VD502 DVD Player
Problem for Jwin JD-VD502 DVD Player
JWIN JD-VD502
By pking on Nov 15, 2006
I am having the "DVD playing in black and white" problem. I do not have a "switch" on the back of my DVD player. I just hooked it up for the 1st time and I have a HD Flat screen plasma. Is there something else I could have done wrong? And if there really is a switch, I think they forgot to put it on my DVD player. Can you give a little more info as to the exact location?
Thanx!
Same Problem
Jan 08, 2009
-   I have the same problem! I just hooked up my JWIN JD-VD502 and I am getting a black and white picture! Can anyone help?
Thanks.
-   luchybeaty
Dec 01, 2008
-   I'm trying to play my xbox on the dvd player but there is no output/input on it. Is there some other way to to this?-   app813
Mar 09, 2008
-   I'm having Problems hooking up this DVD player. My husband is out of town and I have ** idea what I'm doing. I can't get the color on and it only play's dvd's in black and white. Can you help?
-   Honidean
Solution #1
posted on Nov 16, 2006
Somewhat Helpful)
rally
Rank: Apprentice
Rating: 76%, 16 votes
Sounds like a PAL/ NTSC problem which you must fix on either your TV input or DVD player output or settings. This should fix the problem if you alter the settings.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Sep 10, 2007
Not Helpful)
Envisage
Rank: Apprentice
Rating: 55%, 1 votes
Go into 'menu' then 'setup' then 'line'. It should say you are set up for 'S Video'. If it doesn't, change it to 'S Video'.
Was this helpful?
Yes
No
Solution #3
posted on Jan 20, 2007
Not Rated)
Planet Guam
Rank: Apprentice
Rating: 0%, 0 votes
I have a JVC DVD reorder and when I record something on the right blank DVD-R it won't play back... Please note the player is a DVD-R format recorder
Was this helpful?
Yes
No
Solution #4
posted on Jan 02, 2007
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
I had a problem like this before.
My movies were playing in B/W.
I found one of the pins on the S-Video
cable was broken.I replaced the cable all was good.
Solution #5
posted on Dec 28, 2006
Not Rated)
twlangley
Rank: Apprentice
Rating: 0%, 0 votes
I found that one of the pins on my S-Video cable connecting to the back of the DVD Player was bent. Once I straightened it out, and all of the pins connected properly, the B/W issues was resolved.
Was this helpful?
Yes
No
Popular Solutions for Jwin JD-VD502 DVD Player
Questions and Unsolved Problems for Jwin JD-VD502 DVD Player
Do you recommend Jwin JD-VD502 DVD Player?
Answer
Answer
I have a total control universal remote and I forgot the steps to set it for my dvd player can... (More)
Answer
i have jwin jd-vd503 it does not work it shows 'wrong region
Answer
trying to setup dvd player with comcast remote but need a setup code for the dvd player. does not... (More)
Answer
tried eveything to get color back, pls any suggestion????
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Jwin JD-VD502 DVD Player:
Top DVD Player Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more DVD Player Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
