Question about Hatco C 24 Compact Electric Booster Water Heater
Water Heater Connections
I have bought an investment home that has a Whirlpool E1F30HD035V water heater. There are three connections on the top and one on the side, one on top is clearly the output for the unit, one on top appears to be the inlet, one on the side has the pop-off valve, and I have an additional top connection that had a CPVC hookup that is broken.
I've never seen a side pop-off valve (only on top) so I'm stumped about what the extra top connection is used for and how to connect it.
Thanks,
Mike
    Sergeant:
    Champion:
  • 239 Answers
There is no extra conectio,n it is just a pressure release valve
Posted on Jan 02, 2009
Keystone manuals rv
You would need to buy a propane hot water heater. Unfortunately you can not convert an electric hot water hearter to propane.
I didn't want to use either an electric or gas hot water heater so I invested in a solar hot water heater for my home. Best thing that I ever did as far as saving money. Once it is paid off then the benefits are lower utility bills.
Good luck,
Marty
Jul 15, 2014 | Water Heaters
I have a ot water heater and it needs to be hookedup so does the cold water connection enter the top or the bottom of the tank or the bottom
If your water heater has connections on side of tank, cold is at bottom.
If water heater has connections on top of tank, look for Hot and Cold stamped right into the metal.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2011 | RELIANCE ELECTRIC WATER HEATER
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Wiring an electric water heater
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Apr 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I have a new washer, less than three months old. It has been putting rust on my clothes. I bought this washer because I thought it was the old one. What could this be and how do I fix it?
It could be your water source, especially if you are on a well. It could also be coming from the water heater. They tend to rust over time and also collect dirt and sediment.
One quick test may reveal if it is the water heater.
Fill a large clear jug with smooth sides with water. First from the cold, then from the hot.
If you see discoloration from the hot water only, it is your water heater. This can often be solved by flushing the heater thoroughly at the drain until all discolored water is gone.
If you have discoloration from both sides, you may want to invest in a whole house water filter.
Oct 03, 2009 | Kenmore 24032\24036 Top Load Washer
A2 error on Bosch tankless water heater
  1. Check continuity of the flue gas limiter (see Fig. 63, page 46 of manual). Go to steps two and three to determine air box temperature sensor fault and replace it.
  2. Check for flue gas leakage around the top and bottom seals of heat exchanger as well as the viewing window.
  3. Check that venting is within specifications (see Section 3.3 of manual). Long vent lengths, venting with more than three elbows, blocked vent or combination venting may cause this failure.
  4. Check that flue gas limiter connector and spade connections are secure.
  5. Unplug heater and check the two main plug connections inside the control board.
Jan 22, 2009 | Bosch & Tankless LP Hot Water Heater
Need a diaphragm for my rinnia water heater reu 56es
Sounds like tank froze with water in it. Have you checked the connections on the top of the heater they could be leaking also i would check water lines around that area for tees or 90 degree fittings. You can pull heater out and try to check it out. you can fill water heater with water to check to see if heater has a crack in it.
Jan 18, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Whirlpool water heater pilot light does not stay lite
I have a Lowe's Whirlpool water heater. I've experienced the same problems as I've seen described here. My pilot light started going out several times a day. It was not such a big deal, the tank is well insulated so the water would stay warm - I'd just re-light the pilot before going to bed and before going to work. That worked well for about three days, but the problem got progressively worse until it just would not light at all. I replaced the thermocouple with a Honeywell universal thermocouple that I got at Home Depot - that did not solve the problem. I'm very handy, so I decided instead of going through warranty service and having to wait three or four days for replacement parts, I'd buy a new gas valve at Lowes and try that. It cost $54.00 and it worked. By the way, I put the original thermocouple back in and the pilot light stays lit - it was definitely the gas valve and not the thermocouple in my case. It was a real pain to do since I had to drain the tank, but it only took about three hours total. From what I've read, these things last anywhere between six months and two years. That's ridiculous, but at least I have hot water now. If you are reading this because you are considering purchasing a Lowes hot water heater, DON'T!!! I started my search for a replacement gas valve at Home Depot, but they don't stock them. Lowes had 8 on the shelf. That tells you something right there - the water heaters Home Depot stocks don't need to have the gas valves replaced before the tank wears out - there's no demand for the valves so Home Depot doesn't stock them. Lowes probably sells 8 of them a week - all the boxes were shiny and new, not dirty and dusty like some items get when they sit around in home improvement stores.
Nov 11, 2008 | Water Heaters
I have a Whirlpool 30 gal. electric water heater. Model E1F30HD035V, product # 0826237, dual element. It is in a seasonal home. Last weekend June 28 it worked fine. This weekend July 4th, it won't heat. I...
It is not unusual for an element to fail when turned on after non-use.
Turn off the power, and check the electrical resistance of each element. If either is infinite, then it needs to be replaced. Also, if only one is bad, then it can cause the whole unit to malfunction and not heat the water.
Jul 07, 2008 | Hatco C 24 Compact Electric Booster Water...
Hatco C 24 Compact Electric Booster Water Heater Logo
220 people viewed this question
Top Hatco Kitchen Appliances - Others Experts
Craig Butler
Craig Butler
Pat
Pat
Level 1 Expert
Tom Chichester
Are you a Hatco Kitchen Appliances - Other Expert? Answer questions, earn points and help others
