Question about Thermador SC302T Electric Double Oven
Broil element of top oven of a double wall oven does not work
Hi:
1.i have a bosch/thermidor-double wall oven
2. i changed the control display and the relay board
3. double checked all the wires etc
4.everything works except the upper oven broil element
5.everything was working prior to my repair so I believe there is something i did not connect properly
6. the bottom oven broil and bake elements works perfectly and the bake element on the top oven works fine also
7. wasnt sure what connections to test to see if element is bad or whether the control connections are bad
8.any help would be appreciated
  • joecialone Nov 13, 2008
    i need to know what wires to test--
    the oven is a thermidor SC302T double wall oven
    Master:
  • 505 Answers
Well im not terribly familer with thermadors wiring but pull the top off and find the tech sheet then look for a device call a thermal fuse or tco thermal cut off most times they are on top or on the back of the oven yours should have one for each oven bet the one for the top is open can happen if there installed in to close a space
Posted on Nov 13, 2008
  • Indrajit Roy
    Indrajit Roy Nov 13, 2008
    If oven does not heat check heating element and oven control. Follow also suggestion below:
    " It won't bake Usually, when an oven won't bake, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
    It bakes poorly Here are two instances of when food "bakes poorly:"
    • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
      You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
      If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
    • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
      If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
      Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
      Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
      If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
    From repairclinic
    Sergeant:
    Novelist:
  • 196 Answers
It's either the switch that supplys power to the broiler element or it's the element itself (probably the element itself). I'd go after that first as it's not that expensive.
It's not a thermostat because if it was, the bake element wouldn't work either. The broiler element is not supposed to come on except when in the broil mode or cleaning mode
  • 1 more comment
  • mmechanics Nov 13, 2008
    the wire may be slightly burnt
    remove the back panel to re-wire to the burnt wire. The hardest part about this
    job will be access, the repair is easy.
  • It's not getting any power at the outlet...DUH!
  • Well, maybe it's burned out. Attaway, Hoss, just go ahead and replace it
    with the assumption that nothing else could cause a no-bake condition. How 'bout
    checking
    the continuity
    of the element? Whoa, there's a brain flash, ya hey? Should
    read in the range of 20 to 40 ohms. More help on how to troubleshoot it on this
    page
  • 'Course, it could also be a burnt or loose wire to the bake element. I've
    seen it alot.
  • Could be a bad function selector switch, too.
  • Kids and visitors are great for screwing with the mechanical clock "start" or "stop" knobs and pushing them in
    so the oven doesn't work.
  • The oven
    sensor
    could be open. You'll need to ohm it out with... wait for it... your
    ohm meter
  • Your electronic range control (ERC) board could be fried. Usually, there are
    self tests you can do for this and the wiring diagram has the key sequence.
  • The thermal cutout switch might be open.
    http://fixitnow.com/sbrvrs/ovens.htm
    click this link for more help
    thanks.
    • 734 Answers
    As you say ever thing is perfect. I think there is sum wire misplaced in the control display
    • futureloginn
      futureloginn Nov 13, 2008
      Plz. Mention the model number
    • futureloginn
      go to this web site and you can request an owners manual--
      Sits
    How do i test a control panel of a frigidaire wall oven
    Good Morning Friend,
    I understand that you want to know how to test the control panel on your Frigidaire wall oven, model# FEB386WECH, due to the bake element not working. I also see that you have changed the bake element and only the broil works. Typically, this is not a do it yourself job, as there are no step by step instruction manuals. I suggest contacting your local authorized technician for further assistance. They have been trained on your appliance and should be able to diagnose your appliance and determine why the bake element is not working. Hope this is helpful.
    -Best Regards-
    WP
    Jul 07, 2014 | Frigidaire 30 in. Electric Gallery Series...
    Clean between the glass on double wall oven
    Unscrew the handle and screws at the bottom. Carefully separate the outer panel from the frame
    Apr 09, 2014 | Frigidaire FPET2785KF Professional Series...
    Why has both top elements stop working at the same time
    Hello kimberlymaso - If you are referring to the bake element, but the broil element works then you would need to just replace the bake element. If both your bake and broil element does not work, then there might be a problem with the wiring communication. However, if the oven does not bake and/or broil but the cook top works; contact a professional to diagnose the EOC (electronic oven control).
    Sep 25, 2012 | Frigidaire 30 in. Electric Gallery Series...
    BOUGHT A HOME IN UNION NJ WITH THE GE DOUBLE WALL OVEN TOP PART DOES NOT WORK BOTTOM PART BURNS THE FOOD NEED REPAIR PLS CALL ME AT 908-391-8942
    The heating element in top unit may be loose or burned out. Push the element toward the back and see if it engages. If it is already engaged, you'll need to replace it. It is simple to remove it.Just give a firm tug and it should come right out. To replace with a new element, simply push it in firmly.
    With the bottom unit, are controls set for bake? If they are set for "broil" you are using direct heat and it will cook foods more quickly.Also, is bottom unit a convection oven? If so, foods will cook in 1/4 to 1/2 the time for a conventional oven, so you'll have to adjust your temperature down about 25-50 degrees and shorten your cooking time.
    Nov 01, 2010 | GE Built-In 24" Double Electric Wall Oven
    I have a double oven. Model WW27430. The top oven will not heat. The bottom is fine. I was told that is was the relay board. which I replaced and I am still having the same problem. Could both...
    Looking at the schematic I see 2 possibilities:
    1. I think the most likely cause is a failed "limit switch" aka "thermal fuse" aka "temperature cutout". For each oven there is a limit switch that feeds power to both elements. So the upper limit switch is probably tripped which would kill power to the upper bake and broil elements. The limit switch is usually located on the back wall of the oven cavity.
    2. There are a relay board for each oven. Be sure you changed the right one.
    Best Regards,
    Bruce
    www.fixyourboard.com
    Jun 19, 2010 | Jenn-Air WW27430P Stainless Steel Electric...
    Bake and broil top oven not functioning with system
    While the control board could be faulty, it is certainly not what I`d suspect initially. Do these symptom`s follow a self clean cycle of the upper oven ? Is your oven actually a SC302 double wall oven as the post header implies ?
    I ask because the symptoms you describe are a common occurrence when the hi-limit has tripped. The display will indicate the oven is indeed "on" but it will not heat do to the circuit being interrupted by the hi-limit ( which is what it was designed to do ).
    Fortunately if it is tripped, they are the manual reset type and are accessible behind the black grill/vent just above the door and just below the control panel next to the lock latch assembly.
    With the power off, you should be able to remove the grill and push the red button in the center of the thermostat and that should fix your problem...if indeed the hi-limit is tripped you`ll know immediately because you`ll feel it click as you push it down.
    Let me know if I can assist you further. If this solves your problem please rate the solution accordingly, if not let me know and I`ll try to guide you through other possible scenario`s.
    Thanks for visiting "fixya" and good luck.
    macmarkus :)
    Apr 01, 2010 | Thermador SC302T Electric Double Oven
    The oven, which is mounted on the wall next the the stove, doesn't get hot. I had an elecrician in and he said it wasn't the heating element. In fact he said the heating element for the broiler is working...
    1. There are 2 elements, bottom one is the bake-element, top is the broil. Does the bake element glow when it cycles on?
    2. The temperature sensor could be faulty.
    3. The control board may have failed. We see this symptom frequently due to a control board problem. We repair these at www.fixyourboard.com
    Oct 08, 2009 | Kenmore Ovens
    Heating element on upper oven of a wall Thermador Oven
    The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
    Jan 30, 2009 | Thermador Ovens
    Broilers suddenly stopped working
    gerrie824 look at the elements and see if there is cracks in them. If so then yes they failed. During bake the broil elements come on in 1/2 power to brown the top of what you are baking. If there isn't a break in the elements, then the issue could be a burnt wire, failed relay, or such.
    Feb 02, 2008 | GE JKP45 Electric Double Oven
    Open Questions:
    See all Thermador SC302T Electric Double Oven Questions
    Thermador SC302T Electric Double Oven Logo
    Top Thermador Ovens Experts
    Dan Webster
    Dan Webster
    Oloyede Monsuru
    Are you a Thermador Oven Expert? Answer questions, earn points and help others
