Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
What is a wpa key
Trying to set up the xbox using a wierless network adaptor and have been asked to enter the wpa key for the selected network.
    Scholar:
  • 69 Answers
Hi Robert,
the key you are referring to is like a password for the wireless network and need to be entered in order to get access. If this is your wireless network and you did not set the access key then its most likely still set to the default which is normally one of a string of numbers you will find on the bottom of your wireless router.
You can change the key if you like (to make it easier to remember) by going into the router settings, clicking on the wireless settings portion and changing or even deactivating (not recommended) the need for a password.
Getting to the sett tings menu of a router is different for each brand so any walkthroughs i give you to get to that point would most likely be wrong. That said here's an example for what i do with my personal router:
1- I type 192.168.0.1 in my internet explorer browser but yours will probably be different. check your manual or search for your manual online. they are always easy to find.
2- the router settings pops up
3- i click on network settings then wireless settings
4- i change the password to no less than ten numbers and letters
5- i save the changes then exit the settings
6- i go to my xbox and enter the password i just input
7- i frag everyone i see in Halo including the master chief. :)
I hope this helped, please dont forget to rate me.
Posted on Nov 13, 2008
Xbox 360 wireless adapter doesnt work the light on the back just stays red and i dont get how to make it work
Hi. You just need to configure your adapter. It is not broken, it just needs to be set up properly. For information on how to do this, please see: http://support.microsoft.com/kb/908877
Feb 28, 2011 | Microsoft Wireless Network Adapter Xbox...
Having problems setting up my wireless networking adapter
What is the brand and model of your wireless router?
We need to know the settings (SSID, wireless security, security key/code) on the wireless router to match the settings on your xbox wireless adapter.
On your XBOX, go to System, then Network Settings, then select "Edit Settings".
Select the wireless network name or SSID of your wireless router. For the network mode, select Infrastructure. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
Save the settings then select Test Xbox Live Connection.
I hope this works! Please take a moment to leave a comment if you find this solution helpful. Your feedback is important and very much appreciated. Good luck!
Feb 14, 2010 | Microsoft Wireless Network Adapter Xbox...
I have a persistent red light on the wireless adaptor, but the xbox is not recognising that it is plugged in. There is no option for the xbox to search for a network
Blinking green means initializing, steady green means it's found a wireless access point and connected.
Steady red means it's looking for a wireless network (wireless access point) which means you have to configure your SOHO router with an SSID that's broadcast so the wireless xbox NIC can find it.
I think you may have confused a comment I made - the xbox can be connected to your SOHO router by either a WIRE (ethernet cable) OR Wireless NIC (network interface card). If you're using one, disconnect the other!
If you have wireless enabled on your SOHO (small office home office) router then you should either use WEP or WPA for wireless security WPA-2 is recommended. This means you will have to know the key to attach to the wireless network. If someone else set it up then you will have to ask them for the key / passphrase.
Sounds like the NIC isn't the problem but the attaching to the wireless access point (WAP) is. Try www.xbox.com and search for some support regarding your situation. They have a good how to that details the installation / configuration step by step and it sounds like its one of those steps you're missing, unless I've misunderstood.
Good luck,
Feb 10, 2010 | Microsoft Wireless Network Adapter Xbox...
The light stays red, won't connect.
If the light on adapter is red it means that it cannot establish a wireless connection.
We need to get the wireless settings on the Belkin router and match those settings to your xbox adapter.
Use a computer to access the setup page of the belkin router. In a web browser's address bar type: 192.168.2.1.
It will prompt you to enter your router password. By default, just leave the password blank.
Once you are on the setup page, go to the wireless tab. Take note of the SSID, Broadcast SSID should be enabled.
Then Under Wireless go to Security. Take note of the Security Mode (WPA or WEP), Passphrase or WEP key.
Now, on your XBOX, go to System -> Network Settings -> Edit Settings."
Select the SSID. Select Infrastructure for the Network mode. Select the security type if WPA or WEP and enter the Passphrase or WEP key.
Cant grt xbox360 wireless adapter conected to wireless router on pc down stairs
I assume the wireless router is configured correctly and the PC can connect to the wireless router and the Internet.
The problem could be that the signal is too weak upstairs for the XBox especially if you have a concrete floor between the XBox and the wireless router. Try moving the wireless router around to increase signal strength to the CBox.
The other problem could be the XBox is not configured correctly.
Follow these instructions to configure the XBox.
  1. In the Xbox Dashboard, go to My Xbox and open System Settings.
  2. Select Network Settings, Configure Network.
  3. On the Basic Settings tab, select your wireless settings.
  4. Select the name (SSID) of your wireless network. If your router isn't broadcasting your network's name, select Specify Unlisted Network and enter the name.
  5. If your network has wireless security, enter your WEP or WPA key.
  6. Try to connect to Xbox LIVE again.
Dec 23, 2009 | Microsoft Wireless Network Adapter Xbox...
XBOX 360 WIRELESS ADAPTER
I have plugged in a wireless adapter for the 360 but...
A red steady light on the adapter means it is ready to be connected to a wireless network. If it fails to connect then the WPA key is not correct.
WPA automatically changes keys on a frequent basis for security purposes. So you need to take note of the SSID (wireless network name) and the Wireless security settings (WPA and passphrase) from the wireless access point/router.
Once you have the wireless network settings on the access-point/router, go to the System area to enter those settings.
If all settings are correct, exit the System area. Your console should now be connected to your wireless network.
Hope this helps! Good luck!
Oct 01, 2009 | Microsoft Wireless Network Adapter Xbox...
My wireless has a WPA key and Abox is asking
  1. Plug in the Microsoft Xbox 360 Wireless Adapter to one of the USB ports on the back of your Xbox 360.
  2. Turn on your Xbox 360 and navigate to "My Xbox" and then "System Settings."
  3. Go to "Network Settings" and then "Configure Network."
  4. Select the appropriate settings for the wireless network you will be connecting to on the "Basic Settings" tab.
  5. Enter the name of the SSID of the wireless network you will be connecting to. If the SSID is not broadcast, select "Specify Unlisted Network" and enter in the SSID of the network manually.
  6. Enter in the wireless security key (WEP or WPA) so that your Xbox 360 can access the network.
  7. Select "Test Xbox Live Connection" back on the "Network Settings" screen to verify that your Xbox 360 is now connected to the wireless network and ready for use.
Should work for either WEP or WPA
Sep 24, 2009 | 2wire (1000-000005-002) 802.11g/b Wireless...
Limited or no Connectivity WG111v2 SBG900
Limited or No Connectivity on Windows XP
Limited or no connectivity indicates that the computer cannot acquire a valid IP address. This is due to incorrect network key you have entered. We need to check the correct WEP key in your router's setup page. Here are the troubleshooting steps we recommend you try:
Note: You need to use a computer hardwired to the router to check the wireless settings.
1. Please open any web browser like Internet Explorer or Netscape Navigator.
2. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field. Please click Enter or Return key.
3. A window will prompt for a user name and password. The default username is "admin" and the default password is "password".
Note: If it does not take password as the password, you might have changed it when you have run the NETGEAR Setup CD so please try other passwords. If you cannot remember the password, you need to reset the router and run the Setup CD to reconfigure it.
4. Click on Wireless Settings under Setup page.
5. Take note of the SSID.
6. Scroll down, look for the Security Options and check whether WEP (Wired Equivalent Privacy) or WPA (Wi-fi Protected Access) is selected.
7. If its WEP is enabled, copy the value of the selected Key number. If WPA is selected, take note of the Passphrase.
8. To configure the computer with wireless adapter, please consider the following:
Configuring the NETGEAR adapter and Saving the Profile
a. Open the NETGEAR Smart Wireless Settings Utility icon located at the lower right portion of your computer screen. It will then open the Settings tab.
b. Change the Network Name SSID to match the one on your router.
Tip: As an alternative to typing in the SSID, you can use the Network tab to view the available wireless networks. Double click on the desired network.
c. Click the Apply button to activate the connection.
d. Enter a name for your profile (e.g. NETGEAR to Home Network) and click the Save Profile button to store the current settings.
Note: The above procedure applies only if you are trying to connect to a wireless network with no wireless security.
If the computer is using Windows built-in wireless program to manage the wireless adapter, please follow the steps below:
For Windows XP Service Pack 1
a. Please right click on the Wireless icon on the right lower end portion of your computer. Then click on to View Available Wireless Networks.
b. Click on the Advanced tab.
c. Please delete all the preferred networks then click on OK.
d. Right click on the Wireless icon again and click on View Available Wireless Network.
e. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Please type in the Network Key and then confirm it.
f. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Network.
5. Select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. The network key will be the Key or Passphrase you have copied from the router setup (refer to step 7). Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use windows to configure my wireless networks" on the Wireless Networks tab. Please ask assistance from the wireless adapter vendor for configuration if using a proprietary wireless utility (non-NETGEAR wireless adapters).
Feb 28, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
Wireless network adapter
there could be a problem with the adapter, a faulty connection in the cable or something else, or it could be your router. The adapter only works with type A B & G routers. I know a few people who have N routers and it wont work with them. 1st check to see if your router is a typer A B or G then make sure that the wireless signal is set to a frequency that the receiver can find usually channel 6 or so. 2nd, try disconnecting the adapter rebooting the console, then reconnecting it with the power off. if all else fails, then it might be that it is a bad adapter. Also if you use a wireless encryption, make sure that you have the key entered in the wireless setting on your console, and try using a WEP key as it is easier for the adapter to read then WPA.
Jun 26, 2008 | Microsoft Wireless Network Adapter Xbox...
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
651 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Brian Sullivan
Brian Sullivan
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
