Question about Nokia 6300 Cellular Phone
An irregular blue mark on screen after a fall on ground
After falling down a bluedotted ,irregularly spread mark of about 5 mm is permananantly displayed which obstructs the screen letters to some extent. How to get rid of that?
  • 101 Answers
Hi. It sounds like you've damaged the LCD screen. The blue dot is basically the ink in the screen leaking. There's a guide for replacing your screen here http://www.formymobile.co.uk/6300disassembly.php
Posted on Nov 13, 2008
Belt slipping during agitation
Bearings are damaged or drum spider damaged .
Oct 04, 2017 | Maytag SAV5910 Top Load Washer
When starting the vehicle and remain at low revolutions, revolutions are not stable, they rise and fall. It feels a sound like a belt was loose
Check your plugs and ignition wires, timing belt if dry cracked, worn, or loose. usually dips in idle or irregular idle is caused by unstable fuel pressure, worn plugs/wires (misfiring 30 out of 100 fires)
Nov 14, 2011 | 1996 Mazda Protege
My camera has developed small cluster of dark spots on the LCD screen interface, the pictures however are fine with no such marks when developed or viewed on any other media device. At first, It was one...
Mine has been doing this too! The spots are getting so large that it covers 1/4 of the screen. I'm sending mine in to get repaired because it came with a 1 year warrenty.
May 10, 2011 | Olympus SP600UZ Digital Camera
I have a grinding noise coming from my front left tire! Sounds like the front end is gonna fall out from under the truck. Could that be ball joints, tie rod ends? When it makes this noise it feels like the...
Sounds like the noise is a bad bearing to me. If the ball joints or tie rod ends were bad, you would have irregular steering or in an extreme case, the front end would fall apart and you would lose steering abilities.
Oct 18, 2010 | 2004 Dodge Ram 1500
TV stopped working
Yeah. It sounds like the television transformer is damaged. This can happen due to irregularities in voltage supply, lightnings etc. Try having your transformer replaced. It is very cheap and you should be careful to get the best thing available there as this thing can fall faulty at any time if it lacks quality.
Apr 07, 2010 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Flashing alarm light after battery change. Car wont start,
System operation
System arms 5 seconds after switching ignition OFF. Switch ignition ON. Ensure clock LED illuminates for 3-5 seconds. If LED flashes rapidly at regular intervals for approximately 1 minute, then flashes at irregular intervals: Key code not recognised. Remove key and try again.
Programming
When
System malfunction: LED illuminates for 1 minute, then flashes at irregular intervals. Key(s) added or replaced.
NOTE: Replacement keys MUST have blue mark. Keys with red mark are NOT compatible with this system.
How
NOTE: Programming method using vehicle keys can be deactivated using diagnostic equipment.
Obtain 2 programmed keys (A and B). Insert key A into ignition switch. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key A. Insert key B into ignition switch within 5 seconds. Turn ignition switch to position II. Wait 1 second. Switch ignition OFF. Remove key B. Within 10 seconds: Insert key to be programmed into ignition switch. Turn ignition switch to position II. Wait 4 seconds. Switch ignition OFF. Wait 5 seconds. Start engine. If engine does not start and clock LED flashes: Switch ignition ON. Wait at least 20 seconds. Switch ignition OFF. Repeat programming procedure. Repeat above procedure to program remaining keys. Keys can also be programmed using diagnostic equipment
Mar 08, 2010 | 2000 Ford Focus
Gray cloud
If the stain is irregular and static that is a faulty LCD display. The repair is expensive. Contact Polaroid at the number listed on owners manual as the TV has one year factory warranty cover.
May 15, 2009 | Polaroid TLA-04011C 40 in. LCD TV
Blue ghost image on left side of screen
The Optical Block Assy would have to be replaced, same part that causes Blue Dots, not considered to be user replaceable.
Mar 14, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Craftsman 15.5 h.p. riding mower won't start
Try this,follow the positive battery to the part it's attached to,that's what is bad,remove it and take to Lowe's,they have one and it's not expensive.
Jun 21, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Nokia 6300 Cellular Phone Logo
205 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
