Question about Bosch WFL 2463 Front Load Washer
Dispenser still full of water and fabric softener
At the end of a wash cycle, the fabric softener compartment within the soap dispenser is always full of water and fabric softener. I tried cleaning the dispenser but this has not helped. I have also tried running a rinse and freshen up cycle but some liquid still remains within the dispenser and leaves detergent residue on the inside of the door.
  • sabera Jun 04, 2008
    I also have the same problem , have tried cleaning the dispenser but it has made no difference.
  • Bosch Master
  • 744 Answers
Fabric softener This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Jul 30, 2013
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 24 Answers
My dispenser was always full at the end of the programme. I took the drawer out and pushed a drinking straw down the hole that takes the conditioner into the machine... this was bunged up with gunge... has been fine since.
To get rid of the residue and get your machine sparkling... 1/2 cup of Washing soda crystals on a 60 degree wash. Run machine with no washing and let it run the full cycle..
Add 1 desert spoonful of washing soda to every wash.. sprinkled in the gap in the door seal to keep the machine in tip top condition and smelling great.
You will find your conditioner smells amazing when you get rid of the gunk...
Posted on Aug 03, 2008
I also had this problem with the fabric softener staying in the draw. After changing the motor brushes this has solved my problem.
Posted on Feb 11, 2008
    Scholar:
  • 97 Answers
Hiya
this could be caused by a faulty cold inlet valve if the detergent is not being taken away. however if the detergent iis being taken away then the valve is working ok as it fills the compartment with water lifting the detergent out and into the washing machine.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Dispenser fabric softener slot
Fabric Softener Compartment Full Of Water - White Goods ...
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a plastic cap or tube at the back for the water to siphon up through. ... Make sure the washer is level front to back as well as side to side. .... If the washing machinehasn't been used since there's always the possibility that the plastic ...
The fabric softener part of my washing machine drawer keeps ...
www.mumsnet.com > Topics > Housekeeping
MumsnetAfter each wash, the fabric conditioner part of the drawer is f. ... The fabric softener part of my washing machine drawer keeps filling with water ... Stopped using thedispenser compartment for fab softener and instead did I separate ... see if that clears it up and also try cleaning behind the drawer in case there is a blockage.
Washing Machine ' Fabric Softener ' Problem ' Won't Empty
Jan 16, 2016 | Washing Machines
Bleach and Fabric Softner Dispenser
Hi
This is a result of the siphoning action and is part of the normal operation of the washer. Water
may be removed by removing the dispenser drawer and draining
water into the empty drum or sink.
Outside
• When washing is completed, wipe top and sides of washer with a damp cloth. Turn water
faucets off to prevent pressure build-up in the hoses.
• As needed, clean the cabinet with mild soap and water. Never use harsh, gritty or
abrasive cleansers. If door or console becomes stained, clean with diluted chlorine bleach
[1/2 cup (120 ml) in 1 quart (.95 L) water]. Rinse several times with clear water.
• Remove glue residue from tape or labels with a mixture of warm water and mild detergent.
Or, touch residue with the sticky side of the tape or label.
• Before moving the washer, place a strip of cardboard or thin fiberboard under the front
leveling legs to prevent floor damage.
Cleaning the Dispenser Drawer Area
Detergent and fabric softener may build up in the dispenser drawer. Residue should be removed
once or twice a month.
• Remove the drawer by pulling the drawer out until it stops. (Figure 1)
• Reach back into the left rear corner of the drawer cavity and press down firmly on the lock
tab (left rear portion of the drawer). Pull out the drawer. (Figure 2)
• Remove the insert from the bleach and fabric softener compartments. (Figure 3)
• Rinse the drawer and inserts with hot tap water to remove traces of accumulated powders
and liquids. Large amounts of fabric softener residue may indicate improper dilution or
more frequent cleaning is required.
• To clean the drawer opening, use a small brush to clean the recess. Remove all residue
from the upper and lower parts of the recess. (Figure 4)
• Replace the insert pressing the "X" to lock it in place. Return the dispenser drawer.
Inside
• Remove items from the washer as soon as the cycle ends. Excess wrinkling, color transfer,
and odors may develop in items left in the washer.
• Before cleaning the washer interior, unplug the electrical power cord to avoid electrical
shock hazards.
• Dry around the washer door opening, flexible gasket, and door glass. These areas should
always be clean to ensure a water tight seal.
• When extremely soiled items have been washed, a dirty residue may remain on the drum.
Remove this by wiping the drum with a nonabrasive household cleanser. Rinse thoroughly
with water.
• Periodically, wipe dry the bottom of the flexible gasket to remove lint and other debris.
• The plastic drum vanes may become stained from fabric dye. Clean these parts with a
nonabrasive household cleanser. This prevents dye transfer to future loads.
try this out for more ref check the operations mannual page 7
Dec 07, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Fabric dispenser leaves water in dispenser after wash is done
Jul 9, 2013 - The small fabric conditioner compartment in the soap dispenser drawer has a ... filter at the bottom of my machine is also full of water after every wash my machine is Russell ... My washer flushes out the softener but then leaves the water at the end. ... When the wash cycle has finished the fabric conditioner ...
Frigidaire washing machine fabric softner will not dispense out
Hello - There are several things that could cause the fabric softener to not dispense into the washer. Are you sure the liquid in the dispenser after the wash is fabric softener? If it is fabric softener, the solenoid that lets the water into the dispenser is not working. This solenoid is located on the back of the dispenser. It only gets voltage during the dispense time and fills the fabric softener dispenser with water. The fabric softener dispenser fills while the washer is filling for the rinse cycle.
When the washer begins to fill for the rinse cycle, the fabric softener solenoid is energized and water flows into the fabric softener dispenser cup. When the cup is full the water siphons out and softener and water flow into the tub.
If the liquid in the fabric softener dispenser is pure softener you may need a technician to diagnose and repair the problem. The voltage will have to be tested to the softener solenoid and a volt meter is required.
If the liquid in the fabric softener dispenser is water you probably need to clean the dispenser cup. **** will build up in the siphon tube and stop the liquid from going into the washer tub. The incoming water will dilute the softener and overflow the dispenser cup and run into the tub. The instructions for cleaning the dispenser should be located on page 43 of the use and care guide that came with the washer.
If you don't have the use and care guide these instructions will help. Open the dispenser until it stops. In the left rear corner of the dispenser, there is a release that is labeled push. Press down on the push area and you can slide the dispenser drawer out.
Remove the insert from the bleach and fabric softener compartments. Clean the bottom of the insert and the bleach and fabric softener compartments. Reinstall the insert and put the drawer back inside the washer.
To test the siphon action slowly pour water into the fabric softener compartment. When the water level goes above the maximum line stop pouring. The water should all drain out.
Hope this information proves to be helpful however if it is ineffective please contact a professional to move forward accurately.
Oct 26, 2012 | Frigidaire Affinity ATF7000E Front Load...
My new LG washer always has water in the soap dispenser, bleach dispenser, and fabric softener dispenser after the cycle has finished. Is this normal?
Mine too!! Very annoying, especially since the water then drains down onto to floor and has actually made the door hinges stiff! I just use powdered bleach now.
Aug 22, 2010 | LG Washing Machines
Can I use color safe bleach in my new cabrio, and if so where do I put it?
According to the manual on pages 12 & 13.
1.
Place a load of sorted clothes into the washer. See “Laundry
Tips.”
■ Load evenly to maintain washer balance. Mix large and
small items. Items should move easily through the wash
water.
■ Load only to the top of the basket as shown. Overloading
can cause poor cleaning. Items need to move easily
through the wash water.
2. Pour measured powdered or liquid High Efficiency detergent
into the detergent dispenser. Always use the detergent
dispenser, and do not put detergent directly onto clothes in
the washer.
3. Add color-safe bleach (powdered or liquid) to this dispenser,
if needed. Be sure to match powdered color-safe bleach with
powdered detergent or match liquid color-safe bleach with
liquid detergent.
4. Pour measured liquid chlorine bleach into the liquid chlorine
bleach dispenser, if needed. Bleach is diluted and
automatically dispensed at the proper time during the wash
cycle.
■ Do not overfill. Do not dilute. Do not use more than 1 cup
(250 mL) for a full load. Use less with a smaller load size.
■ Follow the garment and the chlorine bleach
manufacturer’s directions for proper use.
■ To avoid spilling, use a cup with a pouring spout. Do not
let bleach splash, drip, or run down into the washer basket.
■ At the end of the cycle, a small amount of water may be
left in the dispenser. This is normal.
NOTE: Use only liquid chlorine bleach in this dispenser.
5. Pour measured liquid fabric softener into the fabric softener
dispenser, if desired.
■ Do not overfill. The dispenser holds 3 oz (94 mL), or a
capful of fabric softener.
■ The fabric softener is dispensed in the final rinse. If Extra
Rinse is selected, the fabric softener will be dispensed
during the Extra Rinse.
■ Do not spill or drip any fabric softener onto the clothes.
NOTE: Use only liquid fabric softener in this dispenser.
6. Close the washer lid.
7. Press POWER. This turns on the washer display.
8. Select a Wash Cycle. See “Cycles.”
9. Select the desired Modifiers. See “Modifiers.”
10. Select an Option, if desired. See “Options.”
11. Select Delay Wash, if desired. See “Delay Wash” in the
“Modifiers” section.
12. Press START. The wash cycle begins, and the display shows
the estimated remaining time. The lid will lock.
NOTE: If you do not press Start within 5 minutes of pressing
Power, the washer automatically shuts off.
The way that I read the manual, your color safe bleach would go in the detergent dispenser. Your liquid chlorine bleach would go in the bleach dispenser.
Please rate this solution
Aug 03, 2008 | Whirlpool Washing Machines
Fabric Softener Won't Dispense
The fabric softener dispenser is notorious for clogging. Liquid fabric softener is essentially a liquid form of wax. After a period of time it begins to gunk up the inside of the fabric softener dispenser. If you remove the dispenser drawer and look into the cavity, there should be a series of holes in the upper part of the compartment where water sprays into all the dispenser trays. These holes get gunked up and clogged and water will not dispense properly. As a result, the washer goes through a complete cycle, but the dispenser stays full. If this is the case, you can take some cotton swabs and/or toothpicks and clean these holes real good. It may be a bit meticulous, but it should take care of the problem. Post back and let me know if this helps.
Feb 11, 2008 | Maytag Neptune MAH6700A Front Load Washer
Soap Dispence problem on GHW9200LW
In applications with low water pressure, insufficient water
volume is introduced during the fabric softener dispensing
portion of the cycle to flush the dispenser.
RESOLUTION:
The holes in the dispenser housing were enlarged to allow
a greater volume of water to flow through the fabric
softener dispenser to properly dispense the fabric softener.
Order and replace the dispenser housing, Part
#8181719, to correct the condition
Feb 01, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Problems with fabric softener
check the water solenoid for open circuit, this is the water valve that supplies water to the compartment
Sep 28, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Bosch WFL 2463 Front Load Washer Logo
2,501 people viewed this question
Top Bosch Washing Machines Experts
Marvin
Marvin
Craig Butler
Craig Butler
Carmen Mikulic
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
