Question about Panasonic TH-42PX60U Television
    Brigadier General:
  • 6,966 Answers
Initially, the standby light or the red light flashing indicating that the unit has switched to protection mode., the unit in its self diagnosis has detected a fault. In order not to extend the damage, the unit prevents itself from turning on. Eventually the unit has to be opened up for a look and see. This of course would require a fair familiarity of electronic components/circuitry and safety procedures, use of a DVM and a soldering iron. It would be to your added advantage access to a service manual or at the very least a schematic diagram with voltage readings. Should you be uncomfortable performing a DIY (do-it-yourself), perhaps your best bet would then be to seek the services of a qualified professional or claim warranty repair.
Incidentally, in the hope that this is a simple glitch, perhaps you can try unplugging from the mains and removing all connectors. After an extended period, reconnect and verify connections and try again.
Additionally, was there anything out of the ordinary prior to the incident such as power failure/interruptions, thunderstorm, TV used for an extended period pf time, the remotes has been inadvertently played with, or anything noteworthy.
Or have you tried just running the Panasonic with all eternal devices others removed specially HDMI connections?
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Posted on Nov 13, 2008
  • Louie  Role
    Louie Role Nov 15, 2008
    Hi again,
    Any development so far?
    Have you tried just running the Panasonic with all eternal devices others removed specially HDMI connections?
  • 196 Answers
Unplug the wire of the tv for some time then replug it sometimes it get resetted.after this. thanks.
  • mmechanics Nov 13, 2008
    Here is a list of the problems that might have occurred indicated by the number of blinks. The words in parentheses are those which you will see for each of these faults on a diagnosis screen described later in this article. Unit is dead and there are no blinks---- Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open). Continuous blink once a second, No pausing as discussed above---- No reply from the jungle IC301 (data bus is busy, shorted to ground or held high), IK video path is defective.
    1)One blink---- not used for the self-diagnosis.
    2)Two blinks---- B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
    3)Three Blinks---- B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
    4) Four Blinks---- No vertical deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505.
    5) Five Blinks---- AKB circuit (AKB), the timer/ standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board. Also check Q218, 219, 220 on the A board. Also, unit can be in IK blanking. Try turning up screen slightly.
    6)Six blinks---- No horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 and 516 and the jungle IC, IC206.
    7) Seven blinks---- High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
    8)Eight blinks---- Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401 and 402.
TH-42PX60U power red light blinks 3 times
The blinking is a symptom of power supply failure
Mar 22, 2013 | Panasonic Viera TH-42PZ80U Plasma TV
find the remote model and look for the instructions on how to program the remote. it seems that it may not be programmed correctly.
Mar 20, 2013 | Panasonic TH-42PX60U Television
Replaced 2 TH8AH blown fuses. led flashes 10 times
Fuses do not blow (more than one) for no reason---which fuses and where?
10 blinks is usually power supply board but can be something connected to it.
May 22, 2012 | Panasonic VIERA TH-42PX60U 42 in. Plasma...
Panasonic TH-42PX60U plasma TV: red blinking light
are you using a PC to feed a signal or maybe a cable with an adapter?
I had the same issue when I used one of the rear HDMI ports to show a PC display. Apparently there is a software difference between the rear and side/front ports. Inputting the PC through the side HDMI port has solved the problem for me (so far!)
Mar 12, 2009 | Panasonic Televison & Video
TH-42PX60U red light blinks 10 times wont come on
On a Panasonic TV the 10-blink error code can sometimes be caused by low voltage running through an HDMI cable, particularly from a Media PC or some video game consoles. Try disconnecting any HDMI cables and unplugging the Television for 30 seconds, then power it on without the cables attached.
If this works, connect the cables to the front panel (usually HDMI-3) which uses a different controller board.
Dec 08, 2008 | Panasonic TH-42PX60U Television
5 red flashes on your Sony indicates the power supply for lamp is not working .Or 5 pin harness to it is not seated properly.Possibly needs replacement..
Aug 01, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Panasonic TH-42PX60U Television Logo
70 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
