Question about Kenmore 24032\24036 Top Load Washer
Kenmore washer humms and smells horrible....
During the first cycle the washer doesn't spin/agitate but it humms and produces a horrible smell, not quite a burning smell. I think it still spins in other cycles. Not sure of the model I wasn't able to google the given # 110 207712 991, please help I gotta do laundry!
  • 370 Answers
You have a bad motor. ( very common) If you take your model number to a local used parts store you may be able to find a good used motor for cheap. If no luck finding a used one, Order it from sears. (the motor is deffinately your problem, I replace them all the time.)
Posted on Nov 20, 2008
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
Kenmore 90 Series Heavy Duty Washer - Agitator doesnt spin
THIS IS A TYPICLE PROBLEM . BETWEEN THE MOTOR & THE TRANSMISSION THERE IS A COLLECTOR ASSEMBY (THREE PIECE
SET) REAL EASY TO GET TOO EASY TO FIX . ALSO COST EFFICENT
Sep 21, 2009 | Kenmore 24032\24036 Top Load Washer
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Crown series 12 cycle washer will not agitate and smells like something is burning like a for instance a vacumme belt kinda smell in that cycle it spins fine fills fine drains fine but just makes a so
It doesn't agitate If your washer doesn't agitate, check these:
Lid switch
Motor coupler
Belts
Clutch
Drive motor
Drive pulleys
Transmission
Agitator
Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it.
Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Transmission The transmission could have either of these problems:
  • Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may not agitate properly or at all.
  • The transmission may have a worn or broken gear, or some other internal problem.
If you suspect a transmission problem, you may have to call a qualified appliance repair technician to repair it.
Agitator The inside of the agitator--where the transmission shaft attaches--can become worn, and strip out the spline that allows the agitator to properly grip the shaft. Then the transmission shaft rotates back and forth as it should, but the agitator doesn't move properly. If this happens, you may need to replace the agitator and/or the transmission spline.
May 07, 2009 | Frigidaire FWSB5700DS Top Load Washer
Maytag SAV 3652 AWW Washer: During spin cycle, burning smell occurred while making unusual noise. (For months, major squeaking during agitation).
Bad water pump. Replace water pump.tip machine back,Look under machine, remove belt, turn pump by hand, if not spinning freely replace pump.
Mar 23, 2009 | Maytag PAV2300 Top Load Washer
Washer smoke during spin cycle...
could be belts slipping or a bad motor going - what's it smell like - burning rubber or an electrical smell?
Aug 28, 2007 | Kenmore 98702 Stacked Washer/Dryer
Kenmore 24032\24036 Top Load Washer Logo
233 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
