Precise Hidden Line computation failed-AUTOCAD200I
I get this message error when converting from model space to paper space in autocad2000i.
I am using the commands SOLDRAW AND SOLVIEW
  • 3 Answers
SOURCE: Persistent paper jam message
In response to a question by Fixya. I solved it by searching throgh all references to paper jams on Fixya. I found a solution which I have already described. This is a very helpful site.
Posted on Feb 28, 2008
shbuckler
  • 126 Answers
SOURCE: HP Officejet 7410 All-in-One Error
reinstall
Posted on Dec 25, 2008
suzeroo
SOURCE: Photosmart 3210 - A Printer alignment failed error
Mine has done the same thing.
To fix this you have to reinstall the software, then reboot your computer.
I did that, and the printer alignment function worked fine for a while, then I started getting the same problem again, possibly after I had installed other software not related to the printer -- I don't really know.
In any event, it's doing the same thing again, so I just "cancel" the alignment and continue to use the printer. My prints are fine.
Posted on Aug 07, 2009
MNfisherman
  • 11896 Answers
SOURCE: can you correct my error message? command line
In computer science a syntax error ( IPA: /ˈsɪntæks ɛrə(ɹ)/ ) refers to an error in the syntax of a sequence of characters or tokens that is intended to be written in a particular programming language.
For compiled languages syntax errors occur strictly at compile-time. A program will not compile until all syntax errors are corrected. For interpreted languages however syntax errors cannot be detected until runtime and it is not necessarily simple to differentiate a syntax error from a semantic error.
A syntax error may also occur when an invalid equation is entered into a calculator. This can be caused, for instance, by opening brackets without closing them, or less commonly, entering several decimal points in one number.
copy and paste this link in your internet address bar for more information:
http://www.google.com/search?q=SYNTAX+ERROR&ie=utf-8&oe=utf-8&aq=t&rls=org.mozilla:en-US:official&client=firefox-a
feel free to ask any other questions
Posted on Oct 13, 2009
desmondploft
  • 29 Answers
SOURCE: Pri Master Hard Disk:S.M.A.R.T. Command Failed
You do not seem to have a smart capable hard drive, disable the setting in the BIOS by pushing F2
Posted on Jul 06, 2010
Model samsung ce1068
Sounds like you don't have enough space to install. Clear some space and try installing with it plugged into the wall charger
Mar 19, 2014 | Samsung Computers & Internet
When trying to install Fix-It Utilities 10, I get the error message 1935. "An error occurred during the installation of assembly" 'Microsoft VC90.CRT,type"win32" and it won't...
Sorry Martin. We don't have a lot of choices here! After re-starting your computer, check you have enough hard-drive space if in doubt, Clear all junk in memory, close all programs running, go 'off-line' (it may require you to go back on line later to Register) Then check disk is clean and unscratched, and try to install again. If it fails you will have to return to your supplier for a replacement. good luck!
Aug 02, 2011 | Avanquest Fix-It Utilities 10...
The fax appears to dial the number successfully. The receiving fax is turned on. It apprears to try for a long time. The error report says "no answer."
It is not your fax line is the other party.did you try any other number?
Post back.
Solution one: Perform a fax line test Perform a fax line test to check whether the fax line is properly connected. Step one: Run a Fax Test
  1. Press the Setup button (c01395353.jpg ) on the product control panel.
  2. Use the Arrow keys (c01073166.jpg ) to select Service , select Fax Service , select Run Fax Test , and then press OK . The Fax Test prints.
    • If the report passes, try to resend the fax.
    • If the report fails with the message 'Fail - the phone line is not active,' plug the cable into a working telephone jack, and then try to resend the fax.
    • If the report fails with the message 'Fail - the cord is in the wrong port,' continue to 'Step two: Change the cable to the correct port.'
Step two: Change the cable to the correct port Make sure the telephone cable is inserted in the correct port. Remove the cord for the fax line from the port labeled with a telephone, and then insert it into the correct port. Figure 1: Fax portsc01756259.gif Scanner error message The message 'Scanner error ' displays on the product control panel while sending a fax. Solution: Check paper size This product only supports paper less than 381 mm (15 in). Use only letter, A4, or legal sized paper for sending faxes. To send this fax, copy or print the original document onto shorter paper, and then resend.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | HP Laserjet M1319F Laser Multifunction...
My canon has an error b200 and it doesn't print or do anything I command.
Well every advice is the same except a little altered (use a warm cotton swab to clean inside machine and on print head channels) but then it says if possible replace print head but honestly this has become a primitive Machine for turning humans into corpses - buy a new one.
Nov 02, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Paper Jam
hi y'all -
you share a frustrating problem... error message but no apparent error (jam)! it's one that's common to many models of printers and the result of many different causes.
I've seen it when I've printed on cheaper paper, or different (lower) grades with odd surface finishes. the sensors get dirty, or the printer/computer 'thinks' there's paper stuck where none exists. I've opened/closed paper trays 2-3 times and rolled feed rollers around multiple times, then closed printer paper drawers only to have the 3rd time of doing the exact same steps be the time it cleared the error message.
there are often very tiny pieces of paper stuck in weird places in the paper path in printers, too. if you did have a jam before the message started, is every little scrap of the page accounted for? there are also hard to get to places to find paper scraps in larger printers, but I'm going to assume you're all talking about home printers.
here are a few general HP support links you may find helpful for future paper jam messages for this model of printer.
this link is for general info for this model:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&dlc=en&product=304535&lc=en&jumpid=reg_R1002_USEN
this link is for general support for this model:
http://h10025.www1.hp.com/ewfrf/wc/solveCategory?lc=en&dlc=en&cc=us&product=304535
here's a link addressing paper jams in general:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bud09189&lc=en&dlc=en&cc=us&rule=26353&product=304535
and here's one on cleaning your printer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00016484&lc=en&dlc=en&cc=us&product=304535
hope this helps a little bit for future refs. remember that using good paper helps print quality and lessens printing problems. also, when you take a stuck page out of a printer, doing so gently will help ensure little scraps of paper do not tear off paper edges and get stuck in weird spots. it some times helps to gently, manually, roll the feed rollers a full turn around in the printer, too. patience pays! -JW50
Sep 02, 2008 | HP DeskJet 3650 InkJet Printer
I have an ACER ASPIRE 5720 laptop - it is less than a year old and it is showing the memory is full - the memory is meant to be 32 GB and from what I can see from the programme menus there is less than 4...
Hi j0shuatsb,
Acer like many other manufactures seem to design their system to fail or have issues just after their 1 year warranty is up. Like other Microsoft windows operating systems, when you receive an error message that you're memory is full. This does not mean you have run out of RAM = memory. You're notebook can only run a max of 4GB of memory. The error message refers to hard disk drive space. Depending on you're operating system, windows will lock out so much drive space so it can move about. All notebooks also have a hidden partition which holds drivers & programs used in combination for running the system restore.
This hidden partition can range in size from 2GB up to 4GB.
This also lessens you're total hard disk drive space. Bottom line is there is nothing wrong with your memory.
What you need is a larger hard disk drive. Notice the Technical specifications from this link:
http://www.acer.co.uk/public/page9.do?sp=page4&dau34.oid=24360&UserCtxParam=0&GroupCtxParam=0&dctx1=17&CountryISOCtxParam=UK&LanguageISOCtxParam=en&ctx3=-1&ctx4=United+Kingdom&crc=512458878
It does not show what size you're SATA hard disk drive is.
Since you are still in warranty, now would be the time to increase you're drive size. On another note, if you're HDD is the standard 160GB than there is an issue with your current HDD.
Please run a full system virus scan.
Suggest you back up all you're personal data on to a DVD & run you're system restore CD including a format to help you regain you're HDD full space. A temporary fix would be to uninstall any non needed programs through Add/Remove programs. This should free up some space. Many Acer programs you do not use at all or need should be the first to go.
Mike
Aug 08, 2008 | Acer Computers & Internet
Burning to cd
According to hp help and support
When using iTunes for Windows you may get a disc failed error. An unknown error occurred (4280)
In this situation, if you attempt to burn a disc, the following error message may display: The attempt to burn a disc failed. An unknown error occurred (4280) You can resolve this error message by modifying a file in the iTunes CD Configuration folder. First, you need to verify the model of optical drive present. Verifying the Model of the CDRW/DVD Drive Verify that your PC has a Sony CD-RW/DVD CRX830E optical drive installed:
  1. Open iTunes.
  2. In the iTunes Help menu, click Run CD Diagnostics .
  3. Insert an audio CD in the optical drive.
  4. Click OK .
  5. View the results in the CD Diagnostics window:
    • If IDE/CdRomSONY_CDRW/DVD_CRX830E is listed, proceed with the procedure below to resolve the error message.
    • If another drive name is listed, this document does not apply to your computer.
Resolving the Error Message When an IDE/CdRomSONY_CDRW/DVD_CRX830E model optical drive is present, do the following steps to resolve the error message: CAUTION: Take care in using the following steps.
  1. Close iTunes and any other files and software that are open.
  2. Click Start , My Computer , Drive C: , Program Files , iTunes , and CD Configuration to view the files in the CD Configuration folder.
  3. Locate the file gcdrtype.cfg in the CD Configuration folder.
  4. Right-click the file gcdrtype.cfg .
  5. In the drop-down menu, click Open (you may need to select Notepad ) to edit the file gcdrtype.cfg in Notepad .
  6. In the Notepad window, scroll to the bottom lines of the file gcdrtype.cfg .
  7. Locate the line that reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05
  8. At the end of this line add " | NOSENDOPC " (the first character is a blank space), so the line then reads: DRVGENERALFLAGS = MODESEL_NOPAGE01 | MODESEL_NOPAGE05 | NOSENDOPC
  9. At the top of the Notepad window, click File , Save .
  10. At the top of the Notepad window, click File , Exit to close the window.
  11. At the top of the CD Configuration window, click File , Close to close the window
  12. Restart the computer.
You should now be able to burn an audio CD without displaying this error message. ---------------------------------------------------------------------------------------------If this answers your question please rate this as fixed.
Thanks for using fixya support..You have a wonderful day
Jun 03, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
Feb 27, 2008 | OKI B4100 Laser Printer
EVERYTHING VANISHED ANY ONE PLZ HELP
The folder is hidden. You need to enable hidden files and folders in Folder Options on your computer. If you have the refresh database failed message often., you will need to format the device. Best of Luck.
Sep 09, 2007 | SanDisk Sansa e250 MP3 Player
Computers & Internet Logo
63 people viewed this question
David Payne
David Payne
