Question about Panasonic NV-DS60 Mini DV Digital Camcorder
Dew symbol on panasonic NV-DS60
Hi, I have a Panasonic NV-DS60 camcorder. when i turn the camera on the Dew symbol comes up and then the camera turns itself off. I've put it in the airing cupboard overnight and also tried drying it with a hairdryer but no joy. Is there anything else i can do or does it sound knackered.
My panasonic camera does the same- from what research I've done online the only method (that REALLY works) is removing the battery pack and hitting the camera (where the battery was at, don't hit it too hard) with the palm of your hand. I didn't believe this until I tried and *poof* it worked back normal.
Posted on Dec 03, 2008
I get a button battery discharged symbol on my panasonic NV-DS60 camcorder and the camcorder will not do anything is this because of the button battery ?
No, This is the Main Battery Symbol. Try Charging Battery then try if it still has same discharged symbol then replace this battery with new one. thanks Keith
May 18, 2012 | Panasonic NV-DS60 Mini DV Digital...
I have a Panasonic NV-GS 35 digiatl video camera. 'Dew Indicator' error is coming . How can I remove this problem??
hi,dew means you got humidity level to high inside the camera
,press eject,removed the battery and try to use an air dryer an blow air inside the mechanism
thats where the dew sensor is located , for few minutes the let it cool down in a dry place
thats should reset the sensor system, if its not work that mean you will have to
replace the dew sensor.
hope that will help you,thats all i can do from here.
regards Alan.
Dec 25, 2010 | Panasonic NV-GS35 Mini DV Digital...
Panasonic DV mini camcorder error message
Inside is a sensor that detects moisture. If there is dew inside the unit, the tape will adhere to the head and create all kinds of problems. This sensor is there to to prevent problems. That being said, the repair for this could be as simple as ejecting the tape leaving the unit open and letting it dry out. It could also be a bad sensor. In the case of the sensor, the parts cost would be in the $10-$20 range. Add in the local labor rate ($175 here in Mass) and you have the total repair cost. While this is not the easiest repair because of its size, anyone that works on camcorders will find it straightforward.
Dan
Sep 12, 2008 | Panasonic NV-DS60 Mini DV Digital...
Exact location of dew sensor for panasonic NV-DS29B
You can easily locate it pasted on the mechanism , either on the motor driving the mechanism or nearby capstan motor.
Sep 04, 2008 | Panasonic NV-DS29B Mini DV Digital...
Dew warning on Panasonic NV-DS29B Mini DV
I had the same problem, and solved it by having the heads cleaned.
Aug 27, 2008 | Panasonic NV-DS29B Mini DV Digital...
Dew problem
it is on the mechanical section and have two connection,use a 1k resistor to convert it..
Aug 23, 2008 | Panasonic NV-DS29B Mini DV Digital...
Warning Dew Detected
Where are you keeping that camera? I would return this camera if it keeps happening (before warranty expire).
May 14, 2008 | Panasonic Proline AG-DVC7 Mini DV Digital...
HELP, my panasonic keeps shutting off. Dew? condensation?
Put it in a very dry place, and let it sit for a few days. How is it getting either dew or condensation? Once dried out, keep it in an airtight plastic bag.
Sep 06, 2005 | Panasonic AG-185 Camcorder
Panasonic camcorder (NV-DS65) - Dew Indicator Problem
I found this on another site, but it WORKED great for me, and was a VERY easy fix, so I suggest everyone to try it before you go disassembling your camera. I know this sounds very stupid, but it actually somehow fixed my problem, so everyone should give it a go:
1) Turn the camera on.
2) When the dew icon is displayed, take off the battery and then hit/smack the spot on the camera where the battery goes a couple of times (not overly hard, but with some force).
3) Put the battery back and see if it's fixed. If it isn't, repeat the whole procedure. It took me about four tries but now miraculously my camera seems to be working, for the first time in about 3-4 years!!!
NOTE: I don't know what the exact "fixing" spot is, so I just hitted different places of the battery spot (both the upper and lower region). Take it easy first and don't hit too hard, see if it works and try again putting more force if necessary. I still can't believe this solved the problem, wish I'd tried it back when the problem first occured!
NOTE #2: I think this fix will probably also work on some other Panasonic cameras with the same dew problem - in fact, I think the guy who originally came up with this solution actually had a different camera model than I do.. I know it's a late reply, but hopefully this helps at least someone!
Panasonic NV-DS60 Mini DV Digital Camcorder Logo
217 people viewed this question
Top Panasonic Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
zimcloud
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
