Question about Quantum ValueLoader SDLT 320 Super DLT Tape Drive
I get an error code A4 and 8A on the value loader LTO library.
After i got error code A4, i opened the library and took all slots out before putting them back. It worked. But it didn't do backup during night and next day morning i saw error code 8A.
Can anyone tell me the solution ?
Thanks..
I opened the library, removed all slots and put them back in with proper alignment. It's working now..
Posted on Nov 14, 2008
Hie i am a computer technician, and have been doing hardware,software and networking troubleshooting for 2 years. a company doing tape drive repairs and data recovery is interested in my service, especially to do tape drive repairs. i am due for the interview in two daysand hve very little knowledge in tape drives. what basic things do i need to know and doyou think i will manage considering my it technical background
Posted on Aug 05, 2009
Quantum superloader 3 drive error type
Hi Ulrike
I suspect that your backup software has "locked" the drive / library from the front panel.
This is why disconnecting / rebooting the library solves the issue.
If you are using backup exec or similar, try going to devices, selecting the library, right click and "unlock" before using the front panel buttons.
You could also use BUEX to do the tape moves for you instead of even touching the front panel.
If you are in the UK and are still having problems then click the link below and we will do what we can to help.
LTO Repair service UK Based All manufacturers of LTO drives repaired
Mar 10, 2014 | Computers & Internet
Servo init failure stalled xy
Hi Edouard
This sounds like the picker has failed to complete the power on self test (POST).
This may be due to a damaged library or simply due to a tape blocking the picker movement.
POWER OFF!
Try opening the library to make sure your tapes are all properly located in the magazines and have not fallen out.
Also try gently moving the picker to see if you can locate any other obstructions. Be very careful as you obviously do not want to break the picker or anything else accidentally.
If you are in the UK and are still having trouble, click the link below and we will do what we can to help.
Feb 28, 2014 | Quantum SCALAR 50E LIBRARY LTO3HH TAPE...
9E 09
Hi Alan
Error 9E - Elevator range of motion out of specification
The Elevator (the part of the robotics assembly that moves in the vertical direction) range of motion out of specification
If possible, check for an obstruction by powering off the library and either removing a magazine or a drive to view the robot. Gently remove the obstruction, replace all magazines and drives and then power up the library.
Re-try the last operation
If you are in the UK and are still having trouble, please click the link below and we will do all we can to help you.
Feb 27, 2014 | IBM Computers & Internet
Error codes: 8C0A, 8C0D
This sounds like a picker fault (rotation blocked). Remove the mags from the library.
remove the power from the library (and your watch!)
Gently feel about inside the library and remove any additional tapes floating about inside.
Try again.
If this does not work then try going to http://tape-drive-repair.com as they have spare parts and pickers that they can use to fix the library.
Sep 27, 2013 | IBM TS3100 (3573S4S) LTO-4 Tape Drive
Scalar 50
http://downloads.quantum.com/scalar/S50/manuals/81-81539-01_A01.pdf
The above may be helpful but i cannot see the error codes listed. This unit is the same as the PX502 so this may also help
http://www.sandirect.com/documents/PX500_Series_Users_Guide_81-81290-05_A01.pdf
Try also going to http://tape-drive-repair.com/ who have a repair centre to fix tape library units.
May 11, 2013 | Quantum Scalar 50 Library, One LTO-4 Tape...
Our dell powervault 122t shows error code A0
Error Code A0 - Error occurred during carousel movement (Position Not Found). Could be caused by a missing or misaligned cartridge carrier, or an obstruction, or unexpected cartridge in either the carousel path or Import/Export slot.
Remove the power cable and SCSI cables then try open the top cover. Check and see if there are any tape blocking or obstructing the movement. Sometimes it works sometimes it doesnt. I have 5 of these devices, few of them were replaced as its not working anymore due to these codes and as they are pretty obsolete, its not worth to repair them anymore.
Feb 03, 2011 | Dell PowerVault 122T LTO (pv122tlto)...
I caanot ejeect magazines from the drive. It claims host is busy. I have power cycled drive to no avail. Any help would be appreciated TS 3100 library, Fibre connected, Arcserve r 15
You can release both magazine inserting one stick wire in the holes in back of library. In the user manual available in WEB is this manual.
Good luck
Jan 05, 2011 | IBM TS3100 LTO-4 Tape Library, 24 Slots, 3...
I am unable to get IBM UlTrium TD4 SCSI device drivers for windows 2000 server
if you "have not" using Backup Software (e.g. Symantec Backup Exec, CA), you can try this IBM LTO-4 driver for Win2K.
IBM LTO-4 Device Driver for Windows 2000
Ned Huang
Tandberg Data Taiwan
Technical Support.
Oct 15, 2008 | Computers & Internet
Ultrium LTO 3 Tape Autoloader Error
what software are you using? try not backing up the system state to see if that changes anything?
Feb 07, 2008 | HP StorageWorks ESL712e Ultrium (AA934B)...
Sn 3250 router problem
Ok, I'm confused... are you sure this isn't router that you're mentioning isn't a SAN Switch? A StorageTek/Brocade 3250 switch... and this is a StorageTek Scalar 100 Tape Library with Fibre aware LTO Drives. The Library Users Manual can be found at http://downloads.quantum.com/scalar/S100/omS100UsersGuide.pdf. Switch information can be found at http://www.storagetek.com/products/product_page2304.html. I'm not a Sun guy, so I would suggest that you contact them to find out which versions of firmware for the switch that they have certified. With HP, there are certain versions of firmware that they certify with HPUX... and specific versions of HBA drivers that work better with HPUX as well. If it is, in fact a Brocade 3250, I would suggest that you start with a "switchshow"... figure out which port drive 4 attaches to... do a "porterrshow #" (# represents the port found) to see the port error statistics... you want to check the loss of signal and link failure count. I would do an "sfpshow #" to see the status of the transciever as well. Let us know.
Oct 04, 2006 | Storagetek StorageNet Router 3250
Quantum ValueLoader SDLT 320 Super DLT Tape Drive Logo
1,181 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
Jax Planet
Jax Planet
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
