I have stanton t62 turntable and want to connect it to marantz sr9200 with preamp
If you are talking about a phono preamp, take the output rca cables from the turntable, "red and white" plug it into the preamp input, "labled" next take a red and white cable wire male ends, "3 to 6" feet long, and plug the one end in the output of the preamp, "labled" and finally plug the remainder into the AUX input of the Marantz receiver matching the colour codes so the left and right channels don't get mixed up, you now should be good to go.
SOURCE: Rotel PReamp, Can I directly Connect my powered speakers to the output
Based on your post, the pre-amp is doing its job. What might be the mismatch would be the powered speaker system plugged into the output of the Rotel. Depending on what the "powered speaker system" is, it might be that it is a low impedance such as those used in computers whereas the Rotel requires high impedance to be connected to its output. What could be tried is to connect a regular amp or receiver to the Rotel.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
SOURCE: I have a phono preamp hooked up to my Yamaha
Let's figure out which hardware is failing. Connect the phono preamp to the CD or tuner input to see if it works there. It should. If it does, your receiver is at fault. Did the front panel controls get damaged?
How did the turntable fare in this accident? As a basic test of its ability to produce sound, hook it directly to the CD input and raise the volume slowly while playing an LP. If it's alive you'll hear a very weak, tinny sound, but I assume you know that or you wouldn't have a phono preamp in the first place and would probably be asking why the TT sounds so poor. :-)
Testimonial: "Thanks,I plugged the preamp into the CD input and still no sound. I plugged the CD into the aux. and I did get sound. It's the preamp that is shot."
SOURCE: Have forgotten how to hook up turntable to Marantz
What type of TT? Old school should work ONLY on the Phono. Self-pre-amplified use the Aux. Perhaps the TT has a problem???
SOURCE: Selecting phono preamp for Onkyo HT-R510
The magnetic cartridge preamp should work with the turntable, as presumably it will have a magnetic cartridge in it. The only reason that the amp states "magnetic" is that some very old turntables have ceramic cartridges which should not be connected to that terminal. Even if the turntable had a "ceramic" it could be replaced with a magnetic one!
SOURCE: Marantz SR9200 shuts off intermittently
Check all speaker connections. unplug everything.. start with just L and R speakers. Do a mic calibration..also check all your source inputs to the amp. start from the basics. Is the amp still under factory warranty? I used to install marantz...also make sure unit is well ventilated. IF you are using audio zones in your place..with in wall volume controls..make sure they are impedance matched. VOLUME may be set to high...overdriving the outputs..eventhough audio may not be loud. Set volume to -30...?
If your unit doesn't have a PHONO connection you will have to get a Phono Preamp to connect between the TT and any Line Level input, like Aux.
eBay always has some... http://shop.ebay.com/?_from=R40&_trksid=p3984.m570.l1311&_nkw=phono+preamp&_sacat=See-All-Categories
Google "Stanton T.60 Turntable cartridge" and sift through the multitude of offerings.
For example:
