Question about Zanussi FJS1225W Front Load Washer
Zanussi ZWD 1680 W drainaing problen
I have checked hose it seems clear..
I think I may need a new drain pump but would like to check old pump first.
The problem I have is how do you get the covers off to get at the parts
cover seems to be in one piece. I have fixed many washers over the years for me and my kids but have never had a problem getting covers off.
Thank you Ged Scott
  • 135 Answers
Sounds like a split cabinet. There are screws behind the plastic caps at side of machine.remove lid and remove screws to rear of split on both sides and at bottom rear of machine. tease out plastic frame holding mains cable and the back end can now be removed.
Posted on Nov 13, 2008
E31 error on zanussi ZWD 16270w1
Sounds like a slow drain problem.
It would be suggested to check the drain hose, the filter and pump, and maybe replace the pressure switch if that does not work.
Sequence:
1. open up the filter and clean it
2. check the drain hose, and let it drain out freely into a bucket
3. run the machine without clothing to see if it starts working again
4. check if the pump runs
5. replace the pump line pressure switch.
If it still does not work, consider buying another machine, since the cost of the logic board is significant. (maybe the machine is old enough and needs to be replaced)
Sep 05, 2017 | Zanussi Washing Machines
Clothes still wet after cycle
you need to check
1 pump for things that should not be there
2 both hoses to the pump are not blocked
3 worst case change the pump it may be worn
Feb 07, 2014 | Zanussi Washing Machines
I have a Zanussi DE6850 free-standing dishwasher. Have just put on a 65 degree programme. After approximately 1 minute the machine has stopped functioning and the top two lights are flashing and water...
You seem to have a blockage,have you checked the filters lately.Also check the drain hose and the pipe that the drain hose goes into,if they are clear then the blockage is down in the bottom of the dishwasher in the pipes or the drain pump.
Hope this helps.
May 21, 2010 | Zanussi 24 in. DE6850 Free-standing...
My Zanussi ZWD 1470W won't fill up with water. I
Story could be lengthly so in brief, check to see if drain pump is not blocked and if door latch is functioning correctly.(use a multimeter if you can). If it all measures out as good, then your control is faulty. Does the water fill up to the correct level when you start the cycle? Does the motor hum when trying to run. If so check the capacitor.
May 20, 2010 | Zanussi ZWD1470W Front Load Washer / Dryer
I am getting a Code E20 on Zanussi Washer Dryer ZWD 1271W
E20 is an error code for drainage failure.
Check where the appliance drain hose connects to the house drains for a blockage.
If it's onto a spigot under the sink, take them off and check both for a blockage.
If these are ok then it's likely to be a blockage in the pump.
You'll need to drain the water out manually.
Put a shallow dish below the filter and slacken the filter.
Tighten it to stop the flow of water while you empty the dish.
Once empty, take the filter out, clean out the debris and ensure nothing is left jamming the pump.
Before refitting the filter, put the machine on drain or spin and listen at the filter housing to see if you can hear the pump running.
If you do, fit the filter and try the machine again.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jun 17, 2009 | Washing Machines
I am getting a Code E21 on Zanussi Washer Dryer ZWD 1271W. This is on the Dryer cycle everything else seems to work. Thanks
E21 Problems with water drain in wash phase
Check the drain hose and pipe for blockages.Replace the component if necessary.Good luck with the machine.Please do post comments and results.
Apr 15, 2009 | Washing Machines
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Jan 27, 2009 | Washing Machines
Zanussi washer dryer jet system does not work
Hi, this problem is caused by the recirculation pump which has either gone faulty or has been clogged up by to much washing powder/liquid! you will need to strip the machine top off first then the rear and the pump is located at the rear of the machine (depending on model ) it is easy to spot as it is the only one that has the hose attached to the pump which leads to the door seal. take it off check for blockages in the pump and pipe and hose if no blockage then replace pump. It will then work like new.........!
Good luck...................
Nov 20, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
I have problem E40 on Zanussi zwd 1680 w
E40 is door interlock error, it means that either the door interlock is stuck or faulty, or the wiring from door interlock to main control board are not connected.
Oct 03, 2008 | Zanussi FJS1225W Front Load Washer
Zanussi FJS1225W Front Load Washer Logo
157 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
