Question about Panasonic TH-42PX60U Television
Center electronics vidal alvarez tv tech
I am working on this model and the red light
flashes 5 times
  • christm1 Nov 16, 2008
    No picture no sound . when turned on ,red blinking light, clicks on then off . this tv has been very lightly used and is not quite 2 years old.Please help also do we have any recourse? It seems that with so may persons having the same problem that perhaps panosonic could take responsibility and issue a recall.
4 Suggested Answers
  • 326 Answers
SOURCE: Lamp indicator flashes red 3 times every 5 secs.
Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
Posted on Jan 31, 2009
circuitworld
  • 335 Answers
SOURCE: th-42pd50u TV comes on for 5 minutes and then turns off
The tv needs servicing, you may have a bad power supply board if so contact me...
circuitworld@comclast.net
Posted on Feb 20, 2009
AJIN G
  • 6694 Answers
SOURCE: Our Tv (Panasonic TH-43PV30) turns itself off and
hi,
there is some problem with ur tvs power supply.
ok
Posted on Jan 05, 2011
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
I have a sony rear projection TV model number kfws60s1 that will not turn on I press the on button and green light will flash 5 times then goes red again please help shed light into the problem pleaz
Understanding Sony Television Blinking Codes ' Techlore
www.techlore.com/article/understanding-sony-television-blinking-codes
Now the red light blinks 5 time while watching it. Is there any way of ..... 2006 that willnot power on and the green LED is blinking 6 times. We had a service ...
Sony KDF E55A20 - 5 Flashing Read Lights - TV Forums
www.tv-forums.com/.../TV.../TV.../Sony_KDF_E55A20_-_5_Flashing_...
Mar 17, 2012 - 14 posts - ‎4 authors
We have had a Sony KDF E55A20 since January 2006 and it has been trouble free. ...The TV will switch on fine green power lights. Then after about 20 ... If I turn off and turn on the power light will flash red 5 times. Leave it off ...
Sony TV - How to troubleshoot a red or blinking light ...
? 3:36
https://www.youtube.com/watch?v=BLkyFXv2-i4
Apr 6, 2012 - Uploaded by SonyListens
Sony TV - How to troubleshoot a red or blinking light ... and power lights, these easy steps will help you determine what the... 5:17. Easiest TV repair - How to Fix Power [TV turns off, freezes, ... Get video URL at current time.
Dec 02, 2015 | Sony Televison & Video
I Have a Sumssung HCL4715W Tv timer flashes 40r 5 times and Tv turns off
A constantly blinking light means shutdown.
The most common issue in this model is convergence-----if the convergence circuit has railed (this means shorted parts) it can cause the set to do what you describe.
Before I suggest a course of action----what is your skill level with electronic repairs? Can you solder and or do a visual inspection?
SD TECH
Oct 28, 2011 | Samsung HCL4715W 47" Rear Projection...
TV doens'nt start
Take to repair shop, must have a loose connection. I am an electronic Tech, 20 years experience. When you turn on a late model TV they do a self test and if they detect a problem then they shut down. I'm not really up on LG, I work for Panasonic and our LED's flash, and depending upon number of flashes it tells you where the problem is. I would suggest phoning LG for the address near you of their Authorized Service Agent. Get the guys who fix them everyday to do the job.
Cheers
Gordon.
Sep 27, 2009 | LG 32LC51 32 in. HD-Ready LCD TV
Flashing red center light
With most flat panel TVs, the TV turn itself OFF when it has a fail electronic part and the red light starts flashing. They call this "Protection Mode". The flashing red light should be a error trouble code.
But, it's weird that everything is working and the red light is flashing. Since you just recently bought the TV, I would get it check out while it's still under warranty. Better safe, than sorry.
Jul 20, 2009 | LG 26LX1D 26 in. LCD HDTV
KF-WE42 Indicator flashes red.
Try leaving the TV unpugged for 30 minutes so the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you flashing red light codes, circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 29, 2009 | Sony KDF-E42A10 42 in. LCD Television
Red stand by light blinking
5 blinks = lamp driver (ballast) failure.
1-468-798-14 for the 610 model
replacement is done from the back of the set, should be straight forward, keep the red ballast wires apart for best results
if a tech replaced the red tube, you have an older tv where 5 blinks is the AKB error meaning your CRTs are getting old.
Nov 17, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
PICTURE ON LCD TV GOING IN AND OUT
it works!! First i took off the front panel. Just check your manual for instructions, very easy to do. If you do not have a manual just down load one from google.. The instruction are easy to follow. The screw they have you loosen with a alan wrench is attached to the plastic, so you do not have to worry about dropping it inside the tv. Removing the lamp was simple. once out you will notice on either side are two small mesh screens. One of mine was 80% blocked with dust, the other side was only 30-40% covered. I used a vacuum to remove the blockage, i did not want the dust and dirt to go inside the bulb. i then cleaned all around the lamp. Reinstalled, and we are go to go. The kids are happy and i am happier since my wife not be buying a new TV.
total cost of repair $.00
time required to fix, less than 15 minutes.
Also when my TV was loosing sound and picture and then return. I did turn off my TV, then turned on. I nothiced a red blinking light. Mine flashed 5 times. After some reserch, 5 times is video related, bulb or video board. google red flashing light with the model you have and you will find what all the codes mean.
So if yours is flashing 5 times try the above, it might work for you and it is well worth the time before you call a tech and drops hundreds of dollars.
hope this helps.
when your tv blanks out, turn off the tv and then it back on. below the power button usually flashes green light. does yours flash red? if so you need to count how many flashes. the number of flashes will help in resolving your problem. then google red flashing light sony and you will find what the red flashing lights mean.
Oct 04, 2008 | Sony KDF-E55A20 55 in. LCD Television
Red light flashing 5 times every 2 seconds
The 5 blink code in dicates a loss of video. There could be a number of reasons for this. I need to look up your specific model to get you the probable parts. Stay tuned...
Dan
Jul 29, 2008 | Sony KP-53HS10 TV
Sony Tv repair
it is not possible for you to get it corrected as it requires tech knowledge. please call tech person at your place to do needful. it is not a serious problem.
Sep 22, 2007 | Televison & Video
Panasonic TH-42PX60U Television Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
