Question about Panasonic NN-P794SF Microwave Oven
Cuts off know heat
Comes on and runs seems fine but cuts off after about 40 seconds. We have done this several times in a row with food in it but does not get hot.
    Scholar:
  • 181 Answers
Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Posted on Nov 13, 2008
Panasonic NN-S563 no heat
hmmm...well..did you do a power setting? that is what is needed in the sequence just stated..try one of the presets like popcorn, to see if that works.
Oct 19, 2008 | Panasonic NN-S563 Microwave Oven
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
My EWave Microwave cuts off before time is done.
you have problem with a) power diode b) high voltage capacitor short, c) Magnetron defective.
you must consult to qualified tech for repair. or go to some repair shop TV for fix it.
God bless you
Jul 10, 2012 | Microwave Ovens
Flavor wave oven cutting off before food is done
It is possible it is in the circuit that controls the on time---also possible a issue with the inverter (power unit for this unit) or even the Magntron itself which does the heating--
Consider taking to a repair shop for an estimate---both the inverter and Magnatron are expensive parts.
Jun 15, 2012 | Microwave Ovens
My H5640 microwave has stopped heating food and cuts out after 40 secs - is there a reset button or is it a "bin and buy another one" job
Sounds like it's time for a new oven. The magnetron tube that makes the microwaves is overheating and causing the safety thermostat to cut off power. Normally, with the cost of the replacement tube and repair labor, it's more economical to buy a new oven.
Jun 13, 2010 | Neff H5430 Convection Microwave Oven
Does't heat and time goes off after 8 - 10 seconds
really need make and model but if it is a panasonic and it has inverter on the door it maybe the magntron and or the inverter pcb u need to unplug the unit and remove the outer screws when the lid is removed then on the right hand side of the unit as you look at it you will see a square box in the middle will have the number 210 or 236 on it if u can take a look down the open side of the box this is the magnetron you may see a crack in the magnets of the magnetron if you do not see a crack it may still be the magnetron you will not know for sure until you fit a new one also you will not know if the inverter has become faulty when you fit the new magnetron then test the unit if it still cuts out then you will know if the inverter pcb is ok or not if it still cuts out then it will be the inverter as well this info is only for panasonic inverter microwaves only
Dec 28, 2009 | Panasonic Microwave Ovens
Microwave cuts off after using for about three minutes and then comes back on in five plus minutes. Does this every time. Now it does not heat at all. It is 4 years old and has been doing this for a year...
you what??? you hate to replace it after 4 years??? stone me!
its worn out girl!, done in!, had it!, claped out!, (sounds a bit like me)
well they dont make am like the did,,,if its been over heating and turning off, for a full year, its dead now, and as there are microwaves on the market for less than £50.00p whats the problem get a cheepy use it till it drops dead then get another one,,, ok?
oh, by the way,, my first microwave i got way back in 1978!!!!! lasted till 2005 it was used every day to cook for 6 children, one unhappy wife, and me? (who is all ways happy now wife has gone?) beet that one?
Oct 21, 2009 | GE Microwave Ovens
Cuts out everytime you put food in, any mode any food, then displays sensor on panel displayed. May run for a few seconds then cuts again Rob.
It could be either the magnetron thermostat or the cavity thermostat would be faulty, depending on the microwave but in most cases it would be a thermostat.
First of all you can try cutting the power to the unit for 5 minutes, then retry it.
Call 800-626-2005 GE costumer care You will probably need to provide your serial number when you call so be sure you have that ready.
Good Luck!!
Thanks
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave not cooking and cuts out prematurely
Hi! the problem you have stated indicates that the magnetron its not functioning, check for busted fuse.
Sep 16, 2009 | Sharp R-1510 Microwave Oven
Panasonic NN-P794SF Microwave Oven Logo
153 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
