Question about Panasonic KX-P3196 Matrix Printer
Tear off issue
I use my printer exclusively for printing 3" H x 5" W labels. When i need to advance the labels up to tear them off, I hit the "tear off" button and it will advance approximately 2 1/2 labels up and will throw the alignment off for the next string of labels. How can I program the printer to advance up just one label, then return back to the proper alignment for the next batch to be printed?
dodgecharger
  • 254 Answers
SOURCE: Tear off
First, if you have your manual, look it at for possible solution. Does this printer have a "load" or "top of form" function? There may be a "programmable" setting which will back the paper back down to the correct spot. The college where I'm employed used to have several Panasonic dot matrix printers, but almost all are now long gone.
Posted on Sep 19, 2007
SOURCE: Panasonic Kx-P1150 Problem
xupala mejor asi se te va a arreglar tu wea
Posted on Feb 15, 2008
XboxModifier
  • 123 Answers
SOURCE: Problem Printing Lables from ByPass Feed
hello, can you check the settings on your printer in the menu functions, and also in the advanced properties of windows... good luck ;-)
Posted on Feb 19, 2008
jigeo
  • 57 Answers
SOURCE: label not advancing to tear-off perforation
Try this to have the printer auto-sense the size of the labels:
1. Make sure that printer power is off.
2. Press and hold the feed button.
3. Turn printer power on.
4. When the status light blinks, release
the feed button.
5. The printer advances the media to
measure and verify the length of
individual labels or tags. The printer
then prints a status summary and
remains in diagnostic dump mode.
6. To begin normal operation, tap the
feed button. The printer prints "out of
DUMP" and advances a label.
Posted on May 30, 2008
  • 257 Answers
SOURCE: Our Zebra 105se printer has started missing
Clean your platen roller. It's the white rubber roller (that turns and pulls your labels through your printer) located under your printhead. When this gets slick it causes your labels to slip while printing.
You should use rubbing alcohol to clean it. Your computer guys may also have some cleaning wipes in a foil packet that you can use.
Posted on Jul 13, 2009
Printer will not advance to tear after print
I can't give the exact solution for this printer, however, I use the Epson POS thermal printer and here was our solution. In Windows 7 go to Devices and Printers. Click on Printer Properties. Then see if you see a tab that says Document Settings. Under that setting click on Paper Source. You should now see several options; I have mine set on Document(Feed, No Cut). There are other options but we prefer to tear ours off. You can chose Document(Feed, Cut) and it should advance then cut the paper for you.
Jul 10, 2014 | Datamax E-Class E-4205A Direct Thermal...
How do i adjust the printer to the tear off position
Print a config label by holding the cancel button and powering on 15seconds. Check print mode = tear off. If it is in rewind mode the label stops under the print head and does not backfeed before printing. Tear off pushes the perf to the tear bar and backfeeds before printing.
Dec 19, 2012 | Zebra S4M Thermal Label Printer
HOW DO I MAKE THE PAGE ADVANCE AUTOMATICALLY TO THE POSITION I NEED IT TO BE TO TEAR OFF ?
Setting Top of Form, Forms Tear-Off ON
(Step A)
! If you turn the platen knob when the printer is turned
on, you will cause the Top of Form to mis-align. Always
turn the printer off before turning the platen knob!
1 Turn the printer ON.
2 Park the paper.
3 With paper out of the unit, (red alarm light should be on)
press SHIFT (1) and QUIET/TOF (5) to reset the current
Top of Form.
4 Press FF/LOAD (3) to load the paper.
5 Press SEL/MENU (6) to take the printer off line.
The SEL light goes out.
6 Wait until the paper moves up to the tear position, then
press and hold TEAR (4).
The paper moves to the current Top of Form.
Keep pressing and holding TEAR.
7 Press and hold SHIFT and release TEAR.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Jan 26, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
Zebra 90XiII - sometimes when adjusting the tear off position using the arrow keys. The printer (motor) doesn't move the label media in/out. When it does actually move the label media to the desired...
Print a configuration label and see if it is in the correct mode - tear off mode. If it is in rewind or peel off, then the label is not suppose to come out to the cut bar, but stop under the print head and not backup.
If you want it to align with the cut bar make sure that the driver is set for tear off with backup enabled. The printer driver in the software will override the printer setting and change it as soon as you send a print job.
Dec 02, 2010 | Zebra 90XI II Printer
Why does the label wrap around the bar every other label I print?
possible becouse the tear off position stop the gap on the wrong spot and wen you cut the label, left some label with glue expose, and wen you send other print, the printer make the backfeed and the label go stuck on the white rollar.
go througt the setings to TEAR OFF, and ajust to the front or back, untill hav the best gap/label rest possition and cut proply. don't forget to save (press setup button twice)
May 10, 2010 | Zebra Z4Mplus Label Printer
Zebra LP 2844 doesn't feed label all the way out for tearing off. When I print a label everything prints fine, however the last 1/4" or so is still left in the printer. Technically, it's like the printer...
Hi Brian,
When the last label printed is still under the printhead, that means the printer is in "rewind mode". There should be an option for "tear off" mode in the printer driver. This is the mode that pushes the last label printed out to the tear bar. The printer will then "backfeed" when printing the next label. Peel off mode is used if you want to print a label and have it "peeled" off the liner so that you can just pick up the label off the liner and apply it. That takes the rewind option to be installed.
Watch out though, if you are using a label software package, there might be a setting in the label format setup for "tear off" which usually overrides the settings in the printer.
Hope that helps !
May 06, 2010 | Zebra LP 2844 Thermal Printer
Zebra QL420 portable printer label gets misaligned frequently
There are two things to consider here: 1) Is the printer set to the correct media handling setting? Look in the manual for the terms BAR-SENSE and GAP-SENSE and make sure that you have sent the correct command to the printer. 2) There is a TOF or Top of Form setting that you can send to the printer to align the perforation of the labels with the tear bar. Look for the syntax in the manual, which is free for download at zebra.com, and make sure that your perfs line up with your tear bar.
Oct 19, 2009 | Zebra QL420 Thermal Printer
Label not advancing to tear-off perforation
the feed button.
May 14, 2008 | Zebra LP 2844 Thermal Printer
Label won't retract
It is possible that the "Present" sensor is dirty, mis-adjusted, or has failed.
Steve W
LazerTek, LLC
Mar 30, 2008 | Zebra 140Xi II Thermal Printer
Z4MPlus barcode printer
I have had this problem, but only when I used a label of a size that isn't within specification. Technically, this printer isn't specified for a label that is under 1 inch in height. I have a label that is only 0.2" in height and it will get sucked down inside the machine. I have asked the people who work on the manufacturing floor to advance the label two rows after a print job so that this doesn't happen. Then I ask them to cut the label off leaving the two rows sticking out. So, the next print job will start with the label stock sticking at least 1/2 " out of the printer.
I believe that also my printer doesn't tear the labels cleanly, so there is sometimes something that can catch right at the tear bar. You can probably fix that problem if it exists for you by adjusting the tear bar, or having a machinists slightly sharpen it. I hope this helps.
Dec 27, 2007 | Zebra Z4Mplus Label Printer
Panasonic KX-P3196 Matrix Printer Logo
52 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
