Question about HP Office Equipment & Supplies
I have a C7280 All-in-One and have repeatedly tried to fax a number in Canada. The recipient's fax if set up to receive but no luck. Error report always says Error 344:and notes that Image on Fax Send Report is set to Off (but I have no instructions how to turn it on if needed). Can you give me any suggestions?
  • HP Master
  • 1,879 Answers
First, you got the error due to the following reasons:
The remote machine has failed to respond to a fax command from thelocal machine because the connection was interrupted. These errors canoccur if the phone lines in the area are old or if noise is present(static on the phone line). Other reasons could be power outages andother power-related problems.
OR
The call waitingservice can cause this error. The click, heard for an incoming call, isactually a momentary disconnect of the line.
OR
The remote user has pressed the Stop key while the reception was in progress.
OR
Under rare conditions, incompatibility between the two machines can cause the remote machine to simply abandon the call.
*Reattemptthe fax reception at a different time when telephone line conditionshave improved. Call the telephone provider if line conditions fail toimprove.
*Disable the ECM. Errors might still occur, and mightresult in a degraded image quality on the received page. However, theability to transmit the entire document will be improved.
*Try sending at a lower transmission speed.
Second, the note "Fax Send Report is set to Off" - after the above fax transmission failure, the printer by default prints the possible reasons why it failed but the report function is set to off.
Here are the links that will help you setup your fax properly and a reference for those 3-digit fax codes.
Faxing
Resolving Three-Digit Fax Communication Error Codes
Mabuhay!
ohms
Posted on Nov 13, 2008
    New Friend:
  • 144 Answers
You can solve your problem by looking into the Instalation Guide, the User Guide, and Basic Concept Guide
You cand download the Manuals you need in the links above.
In the User Guide
you can find the way to solve this.
Best regards,
  • HP Master
  • 13,433 Answers
344:
The remote machine has failed to respond to a fax command from the local machine because the connection was interrupted. These errors can occur if the phone lines in the area are old or if noise is present (static on the phone line). Other reasons could be power outages and other power-related problems.
OR
The call waiting service can cause this error. The click, heard for an incoming call, is actually a momentary disconnect of the line.
OR
OR
*Reattempt the fax reception at a different time when telephone line conditions have improved. Call the telephone provider if line conditions fail to improve.
*Disable the ECM. Errors might still occur, and might result in a degraded image quality on the received page. However, the ability to transmit the entire document will be improved.
the fax send report is off, it doesn't print out a report of the fax. that is unlikely to fix the problem but might give out some details to the problem.
  • 734 Answers
Try service manual to shortout your problem--
Service Manuals
  • 1 more comment
  • futureloginn
    futureloginn Nov 13, 2008
    err. codes problem is under link go to--
    Link
  • futureloginn
    The remote machine has failed to respond to a fax command from the product because the connection is interrupted.
    The remote user has pressed the Stop button while the remote machine was receiving.
  • futureloginn
    1.Attempt to send the fax again when telephone-line conditions have improved.
    2.If the fax session was using error correction, disable ECM.
    thanks for using fixya
    Sergeant:
    Novelist:
  • 196 Answers
Try sending to any other fax number and check out if same problem occurs.or it gets received properly.
  • 3 more comments
  • mmechanics Nov 13, 2008
    The following error codes can appear on a fax communication error report or the fax history report. The definition of each error code is given, but the solution depends on the cause. Use the following basic troubleshooting tips to help determine the cause. However, if these errors occur every time a fax is sent or received, larger communication issues might exist
    Check the following items:
    • Make sure that the phone cord is plugged directly from the wall jack into the back port of the fax machine that is marked "Line" or "To Wall Jack", or that has a wall-jack symbol.
    • Verify that the line interface unit (LIU) (the box that the phone cord plugs into) is seated fully into the back of the fax.
    • Remove any other device from the line such as splitters, credit card machines, or telephone answering machines, and retry the fax communication.
    • Try sending and receiving faxes on a different fax line.
    • Try using a different telephone cord.
    • Have the phone company test your line for static or noise problems.
    • Disable Error Correction Mode (ECM) if the same error occurs repeatedly.
    344: ERROR MEANS
    for more details check out this link by clicking on it
    http://h10025.www1.hp.com/ewfrf/wc/fastF...
    thanks.
    also check out this anoter link for to avoid  further problems.
    thanks.
My faxes are going through but I get error tx reports. Why is this?
because the fax is not going through as transmitted
the fax report will have OK if it was sent and received correctly
call the recipient of the fax direct and ask what the fax looks like or if they got it alright
Oct 24, 2016 | Office Equipment & Supplies
I keep getting "image on fax send report is set to
Hi!!
Press the Setup button on the front panel of your All in One
Go to Print report
Check for Fax report it may be off turn it On
Apr 16, 2011 | HP Photosmart C7280 Printer
How to print a fax confirmation?
USER MANUAL Page 3-34
Press STATUS key 3 times. Press YES. Press UP and DOWN keys to select the report you wish to print.
TX Result Report The document number, recipient name, date sent, starting time of transmission, number of document pages, time required, mode.
RX Result Report The document number, caller name, date received, starting time of reception, number of pages received, time required, mode, and reception result are printed.
The machine can also be set to print this report automatically after every 60 transmissions/receptions.
Jan 26, 2011 | Konica Minolta Minolta FAX3900 Digital...
What does coms error 00E8 mean?
Canon FAXPHONE L120 Laser Printer Please follow the instruction as given below may this will help u any
Error Codes
An error code is a four-digit code displayed on the LCD or in the bottom row of a TX Result Report or an RX Result Report when an error occurs.
See the table below for individual error codes.
Error Code Description Action 0001 The sender may not be using a G3 fax machine. Make sure the sender's machine is compatible with your machine 0070 Reception was manually canceled on the machine. Ask the sender to resend the document if necessary. 0071 The machine's memory is full. Print, send, or delete any documents stored in memory. 0080 The recipient's machine did not respond within 35 seconds. Resend the document. Ask the other party to check their machine. If you are making an overseas call, add a pause to the number. 008D The recipient's machine has run out of paper. Ask the recipient to make sure that paper is loaded in their machine. 00A0 Transmission was manually canceled on the machine. Resend the document if necessary. 00A1 There is a document jam. Clear the document jam. 00FF All redialing attempts have failed. Check if the recipient's number is correct or the telephone cable is properly connected, and try again.
Aug 18, 2010 | Canon L120 Fax Laser Printer
Can't use fax on HP C7280
Go to menu option and choose the option fax and set the parameter like auto receive or manual set the ring auto answer mode after certain ring. If it is in auto receiving mode it will receive the fax after the ring which you set. Make sure the phone wire which you insert in fax machine getting proper dial tone and getting out going calling facility.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Mar 17, 2010 | HP Photosmart C7280 Laser Printer
How do i set up the fax to print a confirmation sheet when it sends something?
Try this:
Press the Setup button (it might be the sign of a monkey range)
  1. Press the Down arrow (c00844971.gif ) to highlight Print Report , then press OK .
  2. Press the Down arrow (c00844971.gif ) to highlight Fax Confirmation , then press OK .
  3. Press the Down arrow (c00844971.gif ) to select one of the following options in the table below, then press OK
On Fax Send Prints a fax confirmation report for every fax you send. On Fax Receive Prints a fax confirmation report for every fax you receive. Send and Receive Prints a fax confirmation report for every fax you send and receive. Off Does not print a fax confirmation report when you send and receive faxes successfully. This is the default setting.
Select the one you would like to choose ;
For further help click on the following Link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01083680&cc=us&lc=en&dlc=en&product=3204785
Regards Soumajit
Sep 21, 2009 | HP Photosmart C7280 Laser Printer
C7280 fax error code 232
They might be trying to send from a DSL phone line.
Aug 18, 2009 | Office Equipment & Supplies
HP C7280 All in one wont send faxes
First clear the fax memory and then go to go fax menu and then settings
then DRPD set it 9600, and then try to send a fax ...
Good luck...
Feb 02, 2009 | Office Equipment & Supplies
Setting up fax machine to receive
Receive Mode Setting
On the operation panel, press the following buttons to select the appropriate receive mode.
  1. Press <Fax>.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode set], then press <OK>.
  4. Press the right or left arrow button to select the receive mode that best suits your needs, then press <OK>.
    FAX ONLY MODE: When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only.
    MANUAL MODE: When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually.
    ANS MACHINE MODE: When you want to receive voice messages on your answering machine and receive faxes automatically.
    FAX/TEL AUTO SW: When you want to receive faxes automatically as well as voice calls.
    DRPD: When you have subscribed to a DRPD service with your telephone company.
  5. Press <Stop/Reset> repeatedly to return to fax standby mode.
Sending Methods Sending From Your Machine (Memory Sending)
  1. Load the document on the Platen Glass or the ADF.
    Sending from the platen
    Important: When sending a double-sided document, set the document on the Platen Glass. You cannot scan double-sided documents from the ADF.
    Sending from the ADF
    *MP830 shown
  2. Press <FAX>.
  3. Adjust the settings for your document as necessary.
  4. Dial the recipient's number using the numeric keys or speed dialing.
  5. Press <Color> for color sending, or <Black> for black & white sending.
    • When the document was loaded on the Platen Glass:
      1. When the following message is displayed, load the next page on the Platen Glass.
        If you have only one sheet to scan, press <OK>..
      2. Press <Color> to send in color, or <Black> to send in black and white.
        IMPORTANT: If you do not press the same button you pressed in step 5, the machine does not start scanning.
      3. Repeat steps 5a and 5b to scan in all pages of the document.
      4. Press <OK>.
    • When the document was loaded in the ADF:
      The machine starts sending automatically after the document is scanned in.
      Note: Color sending is available only when the recipient's fax machine supports color faxing.
  • To cancel sending before sending a fax, press <Stop/Reset>.
  • To cancel memory sending while sending a fax, follow any instructions on the LCD after pressing <Stop/Reset>.
  • If the document remains in the ADF after pressing <Stop/Reset> during sending a fax, press <OK>. The remaining document is automatically fed out.
Sending From Your Machine (Manual Sending)
Use manual sending when you want to talk to the recipient before sending a document, or if the recipient does not have a fax machine that can receive automatically.
Caution:
  • With manual sending, you cannot use the Platen Glass to send documents.
  • You will need to connect a telephone to your machine if you want to talk to the recipient before sending a document.
Follow this procedure:
  1. Connect a telephone to your machine if you want to talk to the recipient before sending a document
  2. Load the document in the ADF.
  3. Press <FAX>.
  4. Adjust the settings for your document as necessary.
  5. You can lift the handset if one is connected to the machine.
  6. Dial the recipient's number using the numeric keys or coded speed dialing.
  7. Talk through the handset to the recipient. (If you hear a high-pitched signal instead of the
    recipient's voice, go to step 9.)
  8. Ask the recipient to set recipient's fax machine to receive faxes.
  9. When you hear a high-pitched signal, press <Color> for color sending, or <Black> for black & white sending. Then hang up the handset.
Jan 07, 2008 | Canon PIXMA MP530 All-In-One InkJet...
Ben Johnson
